Alba CTV 6688 AK19 incorrect screen settings
After a recent repair our screen settings have changed and we lose a portion of the picture at each side of the screen.
What are the default settings for this TV ?
techman
  • 3130 Answers
SOURCE: bush 2871ntx ak19 28"TV
cold solder joint on the power supply or in the vert curcuit. If you know anything about the proceder to troubleshoot cold solder connections GO for it but if you dont and dont wanna cause any other problems with the set My advice would be to take it to a pro before any other problems arise if they already havent. Its not a major repair most of the time.
Posted on Apr 05, 2006
romsky79
  • 822 Answers
SOURCE: TV picture distorted, bending in from the sides
main board is cold solder. resolder main board.
Posted on May 31, 2009
  • 1481 Answers
SOURCE: travelmate 4202wlmi displays incorrect setting on
some display settings are not compatible with some monitors/lcd displays...
check before u make any changes to the display properties....
some changes done forcebly will permanently damage ur monitor beyond repair....
try to install the VGA driver software of the monitor/notebooks may not require andy drivers as OS would have installed it by default...
also dont make any changes to the refresh rates in the display properties as that also may damage ur monitor...
possible use the chekbox that says "Dont display frequency rates that are not compatible with the system"
Posted on Dec 21, 2009
SOURCE: alba tv remote has stopped working
hi had the same problem with alba 42" (l42m1) spoke to customer services at argos who suggested holding down menu button for 10 seconds then pressing menu again, which aparantly resets remote with tv. Has worked for me, hope it works for you.
Posted on Feb 22, 2010
Testimonial: "Excellent! It works, many thanks for your help"
  • 159 Answers
SOURCE: tune my alba tv CTV
You'll most likely get a replacement from Remotes4U website cheaper than an original Alba, if indeed Alba can supply one.
Posted on Sep 21, 2011
How do i change the brightness, colour, contrast on alba ctv 3410 with URC 2910
Those are usually adjusted during initial set up and can be adjusted by returning to that procedure.
Oct 12, 2016 | Alba Televison & Video
Sansui B2B 21v ctv.my ctv working is good,but recently no video, onely Horizontal line on the screen.
Its seems to me you have faulty capacitors on the boards (it can be see if capacitor are bigger than normal)
Nov 15, 2013 | Televison & Video
Tune my alba tv CTV 5105 SIL lost my remote want to tune to my ps3 Thanx
Sep 21, 2011 | Televison & Video
Hi my 32inch alba LCD tv has fallen off the tv stand and hit the corner of the fire place. This has made the screen all messed up. Can I get this tv fixed??
The LCD is damaged and there is no other option but to replace the LCD screen.
If there is no picture at all it is fully damaged but if a portion of the screen shows a picture then the part of the LCD is damaged.
Please check the cost of replacement before you go for changing as it must be worth the cost.
Sep 20, 2011 | Televison & Video
I have recently bought acer aspire 4750g and when i connect it to my sony bravia lcd thru hdmi it didnot give accurate size screen on my lcd
By not giving an accurate size, do you mean that everything looks stretched, is it not filling the screen, or is it cutting off the picture at the edges?
If it looks stretched or not filling the screen, you need to change the resolution of your screen. To do this in Windows Vista or 7 you need to right click on an empty portion of your desktop and click on "Screen Resolution." From there, click the drop down menu labeled "Resolution" and adjust it to something that looks right. crasher35_12.jpg
In Windows XP, right click on an empty portion of your desktop and click on "Properties." From there you need to click on the "Settings" tab, then move the slider inside the box labeled "Screen Resolution." Change it to something that looks right. crasher35_13.jpg
May 29, 2011 | Acer Computers & Internet
On switching Philips Tv type:21PT 240B/94R no sound,picture
I have Philips CTV 21 PT 240B/94R. and this time a problem are when set on chenel are not stop to change only forward and bottom right side Display Scan+
Jan 29, 2009 | Televison & Video
The problem with my NEC 68T90 TV is that the screen resolution is not correct. At 4:3 ratio, I can't see the sides of any video or TV program that I'm watching. Is there a problem with the hardware?
Try the aspect button on your remote, or if you have this hooked up to a cable or satellite converter, there are screen resolution preferences, you can change the screen resolution here, go the the menu portion and look for video/audio field
May 07, 2008 | Televison & Video
Black screen, small portion of top of picture in view at bottom of screen
your tv has a vertical problem take it to a tech to have them look at it probably on transporting the set to your house it bump around.a look on lose solder could be the problem this could be verified by a tech.good luck.you need the repairman.
Apr 01, 2007 | Sony KP-53HS10 TV
Bush 2871ntx ak19 28"TV
Apr 05, 2006 | Bush 2871NTX 28" TV
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
