Question about Nintendo Wii Console
Adding remote for "Monster Truck World Circuit"
Have checked instruction booklet in options, multiplayer. Currently use remote for other Wii games, same console. Player profile has been added. Screen still says ready, not connected for extra remotes.
    Problem Solver:
  • 25 Answers
You can check out Wii Fix Guide to fix the problem yourself. This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
Posted on Feb 20, 2009
I have Wii NHL2k11 and would like to play a team against my son's team. It only appears to let one person play against the computer and we would like to play each other. Can you tell me how you can play...
If unsure always check the instruction booklet. If nothing is noted in the manual, experiment with the multiplayer options, and make sure both wii remotes are turned on and are ready BEFORE you load the game. Hope this helps!
Feb 21, 2011 | Video Game Consoles & Games
Wii hand will not show up we tried syncing, taking out batteries, unplugging and plugging sensor bar and nothig works
Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
There are two different modes of synchronizing (syncing):
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please click here.
  • ONE TIME MODE - This mode allows you to temporarily use your remote on a Wii console other than your own, or to use a friend's remote on your console. It can also be used to change the order of the Wii Remotes, without the need to turn off the Wii console. One Time Mode does not delete the Standard Mode setting stored in the Wii Remote. In this mode, the Wii Remote will only communicate with the Wii console while the power is on. When the power is turned off, the Wii Remote will lose its sync with the Wii Console. For instructions on One Time Mode setup, please click here.
Note: Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
    Standard Mode Synchronization
    Note: Make sure you have placed batteries in the Wii Remote (how to).
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote added to your system.
    Go to the Next Step (Playing Game Discs) >
    One Time Mode SynchronizationNote: This mode temporarily removes Standard Mode synchronization setup for all Wii Remotes until the power of the Wii console is turned off. When the power is turned back on again, the Standard Mode settings will return.
  1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
  3. Select the Wii Remote Settings option from the Home Button menu.
  5. Select the Reconnect Option.
  7. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
Jan 27, 2011 | Nintendo Wii Console
I hate it
Maybe you should trade it at a store like GameStop if you don't like it.
May 14, 2010 | Ubi Soft Entertainment Monster 4x4: World...
How do I add players/ controlers to wii 4x4 circuit?
press the button on the wii remote with a picture of a home and then press remote settings and then press reconnect and then press 1 and 2 alternatly on the remotes u want to connect
Mar 30, 2010 | Ubi Soft Entertainment Monster 4x4: World...
Steering on monster 4x4 world circuit
the controls are VERY sensitive for this game.
But for the "circual driveng no matter what" is more like a problem with the wheel itself rather than the game.
I suggest returning the wheel and buying a new one or simply not using it and playing with just the Wii-mote itself.
I hope this helps!
Jan 19, 2009 | Ubi Soft Entertainment Monster 4x4: World...
Can't play multi-player in call of duty
For COD5 on the wii, there is no split screen or local (in your room) multiplayer. Only online multiplayer and co op in the single player campaign.
Jan 11, 2009 | Nintendo Call of Duty: World at War for ...
We have been playing gutar hero band and now our remotes only work on side how do i fix
  2. Select the Wii Remote Settings option from the Home Button menu.
  3. Select the Reconnect Option.
    1. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
  • this may reset the remotes for you
    info from nintendos customer service
    Jan 01, 2009 | Nintendo Wii Console
    Nintendo Wii Console Logo
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
