Question about Dyna-Glo Double Tag-a-long Heater
20 lb tanks
Can I hook up a 20 lb tank to the heater
Yes you can use a 20lb tank to run the heater. I purchased a adaptor hose it hand screws into heater & screws onto tank works fine. Bought the adaptor hose at HD.
Custom Contractor
Posted on Jan 27, 2009
3 Suggested Answers
baugh55grfmj
  • 225 Answers
SOURCE: Propane Tank Size needed for Reddy Heater TB101
Yes it will work but it will heat more efficiently with the 100 lb tank
Posted on Jan 05, 2010
  • 3253 Answers
SOURCE: My Mr Heater Buddy heater 4000 to 9000 btu unit
it could be down to the draw off the tank pipe too small or reg is not for a 20lb tank , going to lock out check reg pressure should say on the side , or take hoes and reg off tank , put it back on and turn gas on slowly see if this helps
Posted on Jan 30, 2011
Big buddy Heater - 20 lb tanks won't keep pilot lit,
I had the same problem I called tech support and they said to turn the valve on the 20# cylinder on very slowly for the first 1/4 turn then all will be fine. There is an excessive flow check valve that causes restricted flow when the valve is opened quickly----------mine works fine now
Apr 09, 2013 | Mr. Heater Mr Heater Portable Buddy...
My Mr Heater Buddy heater 4000 to 9000 btu unit work fine with 1 lb propane tank but when I connect it to my 20 lb tank with hose it will not stay lit. Acts like there is not enough gas pressure. My 20 lb...
Jan 30, 2011 | Mr. Heater Mr Heater Portable Buddy...
I have a ProCom ML150HPA for propane and would like to use a 20lb bottle the manual states that at least a 100 lb tank is required. With the 20 lb the pilot lights but will not stay liit without the...
The reason for a larger tank is so the LPG can vapourise enough to supply the heater using a smaller bottle it may freeze and not produce enogh gas
Dec 13, 2010 | Procom MN100HPA Heater
What size propane tank do i need with a Mr. Heater 45,000?
Rule of thumb is that you have 100,000 btu's per gallon of propane. This only translates into the length of time you have available in a tank of gas. The problem arises when you consume too much too fast. The gas can't produce enough vapor to continuously run and becomes dormant which is commonly known as "freezing up". You can use a typical (20 lb.)5 gallon propane tank (barbacue size), but it will more than likely freeze up in 2 - 3 hours of continous use. I'd suggest going to the next larger size a 30 lb. or 7.5 gallon size. The best way to work this system is to have two 5 gal. tanks so you can switch one out when it freezes and let it thaw while your using the spare.
Oct 04, 2010 | Mr. Heater Natural Gas Garage Heater -...
Jan 05, 2010 | Desa International TB101 Heater
Can a vent free heater be connected to a small 20 lb tank?
if the heater is made for propane then yes you can hook it up to a 20 # tank
Sep 01, 2009 | Procom Heating & Cooling
Hayward heater not working
You'll never get enough gas from a 20 pound tank. Even 100# tanks struggle to evaporate enough gas to keep up with that heater.
In the mean time, what is the output pressure on your regulator?
Jun 15, 2009 | Hayward H Series Induced Draft Abg 100,000...
Could not get more then 72hours using 20lb tank on low
HI. propane has 91000 btu's per gallon. 20# bottle has 4. divide btu's of heater by #of gallons for hours of use. I have the same heater and I think the med. setting both burners on is more the 7000 btu's.
Mike
Nov 25, 2008 | Dyna-Glo Double Tag-a-long Heater
Endlessly pushing the ignitor button
In reading about ventless propane heaters a month ago or so, most require a 100 pound or larger propane tank so there will be enough pressure. Could that be the problem?
Nov 03, 2008 | Heating & Cooling
Dyna-Glo Double Tag-a-long Heater Logo
155 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
