Question about NetGear WGR614 Wireless Router
I have a Netgear WGR614v6 , cant get wireless to work with modem
When I remove the ethernet cable it stops working. It works if cable plugged in. Do I have a problem with the IP Address? How do I fix?
  • pirainp Jan 04, 2009
    I just went through the restart instructions and it worked. I was not getting a link between the modem and the router. After shutting them all off and starting the modem; router and finally the computer it worked. This ususally doesn't happen but it has happened twice in the past few days. I wonder if it is because I changed my security from WEP to WPA-PSK.
    Pirainp
  • JDTec
    JDTec May 11, 2010
    What stops working, the router? the computer?
  • 192 Answers
You might of entered the wrong WEP password to asess it wirlessly.
Posted on Jan 04, 2009
Frontier Modem Router
You need to set up the Wi-Fi on both the router and the PC.
It will default to the Ethernet connection, so don't forget to remove the cable if testing for wireless mode.
May 10, 2013 | NetGear Computers & Internet
I cant get internet from my rouder
Wired or wireless? Shut down the computer. Unplug the NetGear. Unplug the ISP modem, remove battery, if applicable, Check ALL cables and connections, reseat ALL connections. plug in the ISP modem, wait for selftest. Plug in the NetGear, wait for selftest. Reboot the computer. Try connecting with a Ethernet cable if you are trying to connect wirelessly to verify. If that fails, contact your ISP to verify signal comming in. Have a ISP tech come out to analyze the signal.
Jan 06, 2013 | NetGear Computers & Internet
Have 2 computers connected to Netgear WGT624NA router via ethernet connectors and have operated well for over a year. Now have gotten DSL and have run phone line to modem and via ethernet cable have...
Have you tried to reset router. It has to be done in order.
1. unplug router
2. unplug modem
3. shut down computer and restart after waiting 1 min
4. after restarting computer plug power back into modem and wait for all the lights to start blinking
5. after the modem is working plug power back to router and plug in the computer with ethernet cable and make sure you have internet,
6. try to link up with wireless,
If this does not work you will have to setup the router for wireless if it is att wireless you will have to call them to give you the password to set it up.
Jan 10, 2011 | NetGear WGT624 Wireless Router
It not let me get internet service i unplug it to move from one side of the room to the other and now its not working
You may need to reboot your cable modem before plugging in the router's power cord.
Are you certain that you re-plugged the Ethernet cable from the cable modem into the correct port on your Netgear router?
If plugging your computer directly into the cable modem allows you to go online, then just re-boot the router once all of the ethernet cables are plugged in to the correct places and then power it back on, and you should be okay.
Oct 17, 2010 | NetGear WGR614 Wireless Router
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Limited or no conncetivity?
Seems to be issue with the switch. If you can get internet after bypassing the switch then it is for sure an issue with the switch. try connecting the cable to other ports of the switch.
If it still does not work then it is time for you to replace the switch.
Rate it,if it helps.
Jun 29, 2009 | NetGear Computers & Internet
Motorola Surfboard 4220 not working with my Netgear WGT624 router
Make sure that you have the ethernet cord from your modem plugged into the WAN/Internet port on your router. Then unplug the power cord from your cable modem and plug it right back in. After the modem fully comes back online, unplug the power cord on the wireless router and plug it back in. wait 30 - 60 sec and then try and connect.
Most cable companies only allow one active"CPE" at a time for internet access. All this means is when you change what is connected to the cable modem you must always reboot the cable modem to allow access.
Hope this helps. Let me know if it does not work.
Please rate.
Mar 23, 2009 | Arris SURFboard SB4220 Modem
Ethernet Port failure new router
Check the socket in either the router or the PC. I had the same problem, only with my modem. When I inspected the port, the pins were misaligned, causing it to drop a connection. I corrected mine with a screwdriver, which is not ideal but it works.
Jul 14, 2008 | Arris SURFboard SB5120 Modem
Wireless routers
Just plug the cable modem ethernet into the input to your router and you will be fine. Just remember, if you decide you want to make any changes to your router settings through your browser, make sure you hook up an ethernet line from your laptop to the router before making any changes. The reason for this is if you make a change in security settings on your router while wireless, the router will reboot and if your laptop did have the settings changed in it, you can be locked out.
Not that you can't get back in, but it is a pain to have to do.
Jan 14, 2008 | Arris SURFboard SB4200 Modem
Server not found} NetGear WGR614 Wireless Router doesn't connect me to the internet.
Dear Loud Nouises,
Your router must be connected properly to the cable modem. This must be to the wan port on the router.
Next, the router must be set-up accordingly to recognize the modem's internet connections. Please ask for the IP address.. and other relevant informations from your internet provider.
Set -up your computer using the internet connections wizard on each of your respective computer.
This should work fine if all connections were correctly configured.
Sidlahora
Nov 27, 2007 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
69 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
