Question about Maytag MER6772 Gemini Electric Kitchen Range
Cleaning in between the glass on the doors
Something spilled down the vents of the top door and it went down the glass of the top door - how can I clean this???
  • goldschlag Apr 18, 2009
    I spilled chicken soup down the vent of the top oven door and the soup ran down between the glass in the door.  What can I do??? It looks absolutely awful!
  • Anonymous May 15, 2009
    I have trouble with dust and food particles between the panes of glass. Maytag won't do anything about it. We purchased the stove in August 2008. You expect a better quality product for $ 2,000.00
    Gloria Hays
    haysbobgloria@aol.com5P6SQ10
My Maytag Gemini double oven "ON INDICATOR" light won't go off even if everything is switched off. What can I do? Please help. Thanks.
Posted on Jun 17, 2009
  • 126 Answers
The door will have to be removed an taken apart. Be very careful l with any seals and gaskets possibly even insulation and take note of where all screws and various parts go so that it all goes back together properly.
Posted on Jan 01, 2009
2 Suggested Answers
SOURCE: frigidaire double oven - stove top oven had a
I had a similar problem with a spill running into the vent and between the glass. I had to take the door apart clean it and then put it back together. It sounds hard, but it was just a few screws and a little time.
Posted on Jul 09, 2009
Spills went through bottom oven vents messing up inside door glass front
Yes, you can clean it yourself but be sure to take note of the way you dismantle the door. I usually take pictures to be sure of the process.
Nov 27, 2012 | Kitchen Ranges
We have a Kenmore double oven. Awhile back something spilled as it was being removed from the top oven, and spilled onto the door of the lower oven. Now the glass inside the lower oven door is streaked and...
Please follow the below steps
1)Open the door.
2)Check the hinges and let the door be opened in half way.
3)Use Philips screw head at hinges screws.
4)remove the door and take the inner part alone.
5)Just follow the picture for more help.
Clean it and place it again.
It is very simple you can easily clean it.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Feb 07, 2011 | Ovens
Oven door window has streaks
you have to let the oven dry and clean and you should not put any oily foods on it..
Apr 11, 2010 | Frigidaire 27 in. Electric Double...
Frigidaire double oven - stove top oven had a spill. The spill went through the bottom oven's door vents and is now in between the glass and I cannot get to it to clean. How can I get this glass clean?
Jun 27, 2009 | Kitchen Ranges
Spills in between glasses of the oven door.
The door must be taken apart at least most of the way to clean glass. Just so you know, this is a problem with a LOT of the newer makes and models. If there are 2 screws behind the handle, take them out and some of them come apart enough to get your hand a paper towel in to clean. Otherwise, the door must be removed and completly diss-assembled.
Mar 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Very simple I thought- Cleaning the inside of the glass on oven.
Don't have one here at home to look at, but the best way to go about that would be to remove the door from the range to work on in on a table, allowing access to any screws at the bottom of the door for disassembly and easier reassembly. To remove door: open oven door. Use a small screwdriver to poke in the small rectangular hole on the hinge and flip down the little lever toward the door. It is mostly hidden at the top of the rectangular hinge opening in the range frame. (do both hinges) Now with the levers down (locking the door hinge) you can lift and pull the door a bit, removing the door and hinge in one unit from the range body. Sounds more difficult than it is. It really only takes 10 seconds. To replace the door, just reverse procedure, remembering to flip the little levers back up after attaching door to range frame.
Nov 30, 2008 | LG LRE30451 Electric Kitchen Range
Spill into oven vents
The best way to clean the inner glass is to remove the door from the oven. With the door in the broil open position (first stop) pull up for about 2 inches until the hinge brackets are released from their stops. Close the door all you can and lift the door off the hinges. Lay the door on a padded surface and remove the 4 screws on the bottom. The outside glass will now slide out of its rail and you can clean the inside. To install just reverse the process. If you take your time and observe, it's not that bad of a job...Catriver..post back.
Nov 26, 2006 | KitchenAid KESC307 Electric Kitchen Range
Maytag MER6772 Gemini Electric Kitchen Range Logo
540 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
