Question about Printronix Line Matrix P5005B Printer
Show the load paper error
I also use the regular paper, printer is working properly but i changed the paper last day, printer don't print and show the message "LOAD PAPER"
pls send me solution.
Sandeep
    Novelist:
  • 125 Answers
There is a paper motion switch behind the tracter feed assembly that might be stuck. Check that and also clean arround the tractor assembly.
Posted on Jan 08, 2009
Error 51.23 after paper jam
**Yellow laser scanner error, replace scanner assem..For tech guys: Remove scanner assembly, remove cover,check for yellow scanner motor rotation. if its hard or struck, gently remove engine motor,lubricate the shaft fix it back & verify rotation, how ever entire unit opened clean all reflector glasses with ear buds gently, fix the unit back properly.(out of four screws, factory wont fit one or two screws for alignment match, same way fix the screws, don't inter change). check for print if its rectified. process end..or else replace scanner assm..
Dec 21, 2011 | HP LaserJet CM1015 All-In-One Printer
My printer light is flashing and I am unable to print
Could be several options
First shut off and disconnect printer from pc and reboot without printer hooked up
once reboot hook it back up and turn on to see if windows found new hardware.check paper and ink
All else fails re-load printer driver
Jun 22, 2011 | Lexmark X1240 All-In-One InkJet Printer
Epson stylus T13 general error
based on my experience my printer show general error every time I print when the printer is about to load paper.. so i check out the loading and found out that part of it was damage and fall off, i don't know what to call it, but it looks like a hook of some sort.. maybe for triggering the loading mechanism that's why my printer give me error everytime it's about to load paper.
So, my advice is to look inside your printer and see if there are foreign object or fallen parts.
Mar 12, 2011 | Epson Office Equipment & Supplies
Printer Canon LBP3300, When was printer it show "Load custom paper in manual feed slot". Have try to slot manual feed but also cant work. Please help to solve this problem. thanks
Load Legal paper in Cassette 1.
If you want to print using only one piece of paper currently loaded in the Manual Feed Slot, click [Resolve Error].
If you want to feed paper from the cassettes, remove the loaded paper from the Manual Feed Slot.
Dec 14, 2010 | Canon LASER SHOT LBP 3300 Printer
Printer is loaded with paper but get message
Although you really haven't given me enough information, I will posit and response for you.
A "Load Paper Error can be caused by the application telling you to change the "TYPE or SIZE" of paper that is in your paper tray.
For example, The application thinks you want the page printed on "Letterhead" paper, but it know that you have plain bond paper installed.
So you are sent a change paper type message.
The fix is to hit go and skip around that error.
The actual fix is to make sure that your printer driver, application and the printer are all set to the same size paper and type paper.
Don
Nov 05, 2009 | HP Hewlett Packard LaserJet P1005 Printer
Changing paper size
please aline the paper according to the paper end sensor
papensor is not enguaged properly
Aug 22, 2009 | Lexmark T640 Laser Printer
Dell 3000cn keep getting load mpf when i try to print but there is paper in the tray. how do I get it to recognize the paper. I've changed nothing on the computer but this just started to happen! please...
I have a Dell 3010n myself, and a few times I did run into that "Load MPF" issue.
1.) Before printing a document, please check and see the properties. i.e. Kind/type of paper, which tray, or if printing envelopes or any other document than a regular 8 x11 paper. Putting all the tray and paper type selection on "Auto" can be very helpful.
2.) On the printer itself, there is a menu button where you can configure the type of paper, i.e. regular 20 llb. copy/print paper, glossy photopaper, thicker paper - after you place a fresh load on the paper tray and slide it in, usually it will ask you which type of paper you just loaded. Make sure it is the same settings as the document that you are trying to print: i.e. if document settings on computer was set to print on photopaper and you have regular paper on the tray, the printer will do a "Load MPF".
The paper sensor on it is amazingly (for a Dell, that is) sensitive and it can differentiate across a lot of paper types/thickness. If you have several computers and user across a network, and there are several paper-type settings done on the printer itself, this "Load MPF" issue will present itself more often.
In my case, it's simply because the person who recently changed the paper-type to glossy cover paper from some user who previously printed to a transparency forgot to revert MPF/Tray 1 to regular copy/print paper. Most cases, the printer setting on the PC has been left to print on to a transparency by default, so even if I stack the tray with copy paper to the hilt, it still will do "Load MPF".
Jul 25, 2009 | Dell 3010cn Laser Printer
Dear Experts, We have just got a Canon iR2022 Copier/Printer. The copier is working properly but for the printer here is the scenrio. The printer is on the network no net work issues. i have installed
if it hapen´s just after you acces it via web and if you turn it off and back on everything get´s right your problem is the firmware.if it´s your problem call me back.
Apr 15, 2009 | Canon iR 2022 Printer
Error E02530 on Canon W8400 PG
Hello
when i load a material in printer, it shows me this error E0200B (size undetected) i loaded another photo papers and photo rolls but it steel show me the same error.
what should i do to solve this problem ?
thank you
Oct 27, 2008 | Canon imagePROGRAF W8400 InkJet Printer
Dell printer 3100 cn laser
I had the dreaded 024-969 and was just able to print a test page.
I removed paper and reached inside the MPF. There's a spring-loaded lever facing upward, toward the back of the tray that the paper rests on and depresses. I toggled this up and down a dozen times.
I vacuumed out the entire tray area and then blew air into the same area by reversing the shop vac hose connection to the output hole.
Printer now prints.
Jun 11, 2008 | Dell 3100cn Laser Printer
Printronix Line Matrix P5005B Printer Logo
124 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Chinmay Joshi
Chinmay Joshi
Cliff
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
