Question about HP Pavilion dv6000z Notebook
Monitor went to sleep and won't wake up
After the screen saver times out, the monitor goes to sleep. This is indicated by the blue power indicator flashing. The monitor has gone to sleep, but will not return to normal operation. There is no picture displayed. I have tried another monitor, that works fine. I have tried rebooting, but nothing seems to help, including a power off/on of the monitor. What's happening? Thanks! Same problem. Put the laptop to sleep manually, or automatically, and the monitor does not wake up. I have an HP Pavilion entertainment PC.  I read a few other blogs, and it seems like the problem may be related to the graphics card.  I think this laptop is using the ATI Radeon graphics card.
  • 192 Answers
It sounds like a driver issue, but more likely the monitor driver, not the video card, since the other monitor works properly.
If you go into the video properties, check the monitor settings. You should be able to switch it to a generic monitor. You also need to make sure that you have the correct monitor refresh frequency set. If you have a mis-match, the video card could send signals at a rate the monitor can;t handle, which is why it won't "wake" even after a reboot and might need to be unplugeed to get it to come back on.
Posted on Jan 01, 2009
How do I turn off the sleep mode on my monitor?
Control panel Power options adjust time for monitor time to sleep you can adjust 5 minutes to never the option available same can be done for hard disk. This is necessary as even monitor is active and when hard disk goes to sleep you may end up in same situation
Alternatively you can activate screen saver by
right click on desktop, settings screen saver choose screen saver set time to activate screen saver.
Sep 03, 2011 | Computers & Internet
My monitor shuts off or goes into a sleep mode. How can I stop this?
go to performance and maintenance settings...follow these;
click windows start>then control panel>then performance and maintenance>then click power otions
navigate below..on the "settings for all on power scheme",set all to your monitor will not encounter that again..
hope this helps for you and goodluck..
Feb 16, 2011 | Samsung SyncMaster 920NW Monitor
I have a desktop XPS 410, it went into sleep mode but will not wake up. I unplugged all the cords and still nothing. the monitor states its in sleep save. how do i get it to wake up?
you may have a computer issue, you may have a monitor issue.
If the computer is powering on, (Green power led on tower and all 4 diags LEDs flash and then finally go out), then the issue is most likely the Monitor. From your description, I'd say monitor, try a different one or try this monitor on another system.
If you have diagnostic LED indications on the tower then this information may help
Aug 30, 2010 | Computers & Internet
I've got a HP w1907v monitor and latly it has been going into sleep mode without warning while i'm using it. All my power saver settings are set to off.
If this monitor is going into sleep mode the normally blue power led will change to yellow. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays blue, you have a backlight malfunction. It can be an inverter power fault but this model mostly has worn out backlights causing a shutdown condition.
Monitor Mike
Aug 18, 2010 | HP w1907 LCD Monitor
Dell screen (1901FP) won't come out of power saver mode
hold down the Fn and F8 keys, and it worked fine for me. or if your problem is you cannot wake from power saving mode (after your PC goes to sleep, then its probably just the driver for your video card). VISTA has some issues with certain drivers that the PC cannot wake from sleep
Sep 24, 2009 | Dell 1901FPt 19" TFT LCD Flat Panel...
Monitor displays slowly after the computer starts.
try to turn off you screen saver just turn off power monitor to see monitor easy wake up after long time.if ok means windows screen saver have problem if still same look like is you monitor something wrong need to check
Jan 03, 2009 | Dell Dimension 2400 PC Desktop
Sleep mode Philips LCD Monitor
I think u need to check monitor properties.In those properties in screen saver mode there is a power button.u need to select that power button and change the turn off monitor option.
Sep 15, 2008 | Computers & Internet
my monitor comes on for a few seconds and then shows monitor going to sleep and then it does. can you please help me as i really need my computer.
many thanks
Aug 11, 2008 | Princeton Digital VL17151 17" Flat Panel...
Viewsonic E53 monitor
Base on the information given to me.
I think your computer is on sleeping mode.
first thing check if the video cable is not loose connecting the pc.
because what would happend, if it is loos it would turn on and off at times.
The other thing you can do.
right click on the desktop.
go to properties
go to screen saver
click on power
adjust the time you want your monitor to shut off.
Dec 06, 2007 | ViewSonic G90fb 19" CRT Monitor
When I select sleep or hibernate mode - the monitor stays black...
Hit the keyboard keys. It is better to just turn sleep and hibernate off and just use a screen saver or tun it off.
Aug 24, 2007 | ViewSonic VX910 19" LCD Monitor
HP Pavilion dv6000z Notebook Logo
336 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
