Question about Compaq Amarda M700 Notebook
Clarifying my question
Ok when i tried to put it in safe mode, its starts to start up with windows 2000 but then it goes to the ble screen again??? any ideas???
My Acer aspire turns on shows windows logo then goes to black screen, what can I do?
Depending on your version of windows, I would trying starting in safe mode to see if the computer does boot. If it does, then you want to restart again, go to advanced boot options and select "start windows with last known good configuration." Access advanced boot options following the steps at this link. Need to Start Windows 7 in Safe Mode Here How
Jul 18, 2015 | Acer Computers & Internet
My dell m90 will not start up.It goes through the starting windows routine and then goes to a black screen?
when you start up your computer press f8 a menu will come up select Last know configuration that worked press enter.see if that works.If not press f8 again and select safe mode press enter see if it will boot to safe mode.if it boots go to my computer right click your boot drive select double click tools then click check now button a menu will come up tick automatic repair then start repair.It will ask you to shedule a repair click ok when you restart it will check and repair your hard drive.If this does not work you can put your operating system disk in your drive and boot to it and click repair and follow the on screen instructions
Oct 26, 2012 | Dell Precision M90 Notebook
My A30 ibm laptop wont start up??
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Mar 03, 2010 | IBM ThinkPad A30 2652 Notebook
Starts up then goes to safe mode screen cant get
Sounds like an infection. Your best bet is to start it and keep pressing F8 for safe mode. Once in there do a restore point. If that fails im sorry to say it may be a complete reinstall with a disk...Hope this helps....
Nov 17, 2009 | HP 510 Notebook
It starts with the lenovo screen and then goes to the Windows XP screen but it goes back to the Lenovo screen. What can I do so I wont have to restore my system again?
ok, press f8 key as the system is booting up, this will put you in safe mode,
if the system boots okay goto command prompt mode and type chkdsk /r to repair any files etc ,
Try booting up again, if the problem is the same then it a startup file that need repairing so goto safe mode, command prompt type bootcfg etc and try repairting it that way, us e the help command to point you in the right direction.
Regards
GeWiz
Oct 01, 2009 | Lenovo 3000 C200 Notebook
Technically Black Screen
when u power up the system press F8 key untill u get safe mode menu.
then goo to enable vga mode set your resolution to 800*600 or 1024 * 768.
also u can try safe mode or last known good config.
Oct 22, 2008 | IBM ThinkPad T20 2647 Notebook
Blue screen of death
The problem is really on your operating system. You have to reinstall the O.S. of your pc. Have your windows installer ready and repair the damaged operating system and it will go back to normal.
Dec 04, 2007 | Compaq Deskpro 2000 PC Desktop
Compaq Amarda M700 Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
