Question about Vtech DECT 6.0 Cordless Phone with Digital Answering System
Need help setting answer service
I need help in setting up my 6.0 answering service ,we lost power and it does not work now.help
    New Friend:
I have the same problem. Lost power, I don't know how to set up my announcements.Model # L56425-3 SN:MP500264667
Thanks, Angela
Posted on May 21, 2013
  • kakima May 21, 2013
    Angela, if you have the same problem then the same answer will work. Just make sure enter the model number properly. It's "LS6425" ("ell-ess" not "ell-five").
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vtech Master
  • 102,366 Answers
Since you declined to specify the model of your VTech DECT 6.0 system, I can only suggest that you enter it into the search box here to download a copy of the manual.
Posted on Feb 13, 2012
5 Suggested Answers
SOURCE: how to set up answering system for a vtech dect 6.0
Here is the link to see and download your manual.
http://www.vtechphones.com/vtechui/support/ManualView.cfm?manualID=309478
Posted on Jun 07, 2009
thedayos
  • 57 Answers
The model number on the bottom of the unit is all you need.
From there you can get support and manuals at...
http://www.vtechphones.com/vtechui/support/index.cfm
If you wish me to dig deeper, just ask and we'll be glad to help!
Len
Posted on Mar 02, 2009
  • 102366 Answers
SOURCE: need manual VTECH 914 ADli
http://www.vtechphones.com/vtechui/support/manual.cfm?manualID=103
Posted on Jul 19, 2010
  • 102366 Answers
SOURCE: Hi. I can't find the
Since you declined to specify the model of your VTech DECT 6.0 system, enter it into the search box at
http://www.vtechphones.com/vtechphones/index.cfm/support/general/manuals/
Posted on Oct 13, 2011
Hi my hp 640 will not answer a fax call, but will answer only if we pick up the hand set.
Issue When the all-in-one product is sharing a phone line with voice calls, some calls are interrupted by fax tones. Follow the steps below to solve the problem.Step one: Check the Rings to Answer setting If Auto Answer is enabled, the HP fax product will answer the phone line when the number of rings reaches the number of rings specified in the Rings-to-Answer setting. When voice calls will be received on the same phone line as faxes, set to rings-to-answer to 6. If you do not want the fax to answer automatically, either turn off Auto Answer from the front panel and receive faxes manually (this may result in lost faxes) or subscribe to a distinctive ring service from the phone company (if available). Refer to the Answering faxes manually section below to learn how to answer faxes manually or refer to the Using distinctive ringing section below for more information about using distinctive ringing. The Rings-to-answer setting for the HP Officejet 500 and 600 series products can only be checked or set using the all-in-one software on the computer. The Rings-to-answer setting for the HP Officejet 500 and 600 series products can only be checked or set using the all-in-one software on the computer. Follow the steps below to check or change the setting for all models except the HP Officejet 500 and 600 series:
  1. Depending on the model, press either Menu , Setup , or Fax Setup repeatedly until Basic Fax Setup appears in the display.
  2. Press Enter (or Start or OK ).
  3. Press the right arrow button repeatedly until Rings to Answer is displayed, and then press Enter .
  4. The number of rings before the HP fax product answers will be displayed.
    • The setting is correct if it is 6. Press Cancel or Stop (Stop Fax) to exit the menu.
    • If the number is not 6, press the right arrow button until 6 appears in the display and then press Enter (or Start or OK ).
Aug 30, 2011 | HP 640 Inkjet Fax Machine
Lost the manuel need to re set answering
you can contact the service provider.........
Aug 13, 2011 | Uniden DECT 6.0 Cordless Phone ID
Radio shack cordless phone and answering machine - manual lost, son can't come help at the moment, don't know how to re-set answering machine for the outgoing message I previously had, I either touched the...
There should be a greeting,greet,record,or rec button on the front.Press it and hold it down.It will prompt you what to do.
Please write back if that does not work.Good luck!
Jul 25, 2010 | Radio Shack 3822 Digital Answering Machine
How to set hp1040 fax to work with aout answering
If you are using the same phone line as your fax, you can start by connecting the answering machine on Line2 or 2-Ext at the back of the fax. Set the fax to answer on two rings higher than the Answering Machine. (for example: if answering maching is 4 rings, fax is 6 rings)
And then, turn on the auto answer.
Mar 22, 2009 | HP 1040 Plain Paper Inkjet Fax
Machine not answering. new battery. lights on with 0 messages.
When the power went out it may have set the machine to its default setting, "answer function off". Press the "On/Off" button to check for sure. A battery really wouldn't help in this matter because it's only there for backup; when the power goes out the batter will save your settings, outgoing and incoming messages. Perhaps when the power went out you lost your outgoing message, and now, when people call, they don't realize that that they are supposed to leave a message. One more thing you can check is the switch on the side of the phone which tells the machine to answer after 2 or 4 rings.
Nov 17, 2008 | BellSouth Digital Answering System 2006C...
Home phone rings,fax cuts in when talking to caller!
First try a reset on the unit: Try the steps mentioned bellow
Unplug the power cord from the All-In-One as well as the power outlet when there is still power in the All-In-One. and wait for atleast 1Min
Plug the power cord directly to a wall outlet without surg protector. (if possible connect it to a different power outlet)
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
All the setup seems to be right. Except it seems you need to check the rings to answer in your answering machine if it is set to lower than that of the Fax (it should be atleast 4 or 5 Rings)
And the rings to answer in the All-In-One is set to 6 Rings
And make sure you have the right distinctive ring pattern as triple (If possible confirm it with your telephone service provider) and set it appropriatly, to me it seems it sould be clarified first with the telephone service provider
Check the above and let me know if any problem
Good Luck
Oct 02, 2008 | HP PSC 2210 All-In-One InkJet Printer
Answerer won't pick up
i lost the book how to put numbers in memory.
Dec 08, 2007 | GE 29897GE2 Corded Phone
Power outage lost fetaures
Contact these guys (sorry they dont still have a manual online); http://www.alcatel-lucent.com/wps/portal/ContactUs Hopefully they can help you out :)
Jun 27, 2007 | Lucent 1872 Corded Phone
Vtech DECT 6.0 Cordless Phone with Digital Answering System Logo
147 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
