Question about VIA MSI K8T Neo2-F K8T800 Pro Socket 939 DDR 400 ATX Motherboard w/SATA, RAID, LAN(Gb), USB 2.0&Audi... (MMK8TN2F)
Memory problem i have 1024 ddr 400 if i put it in 2&4 it won't boot put it in slot 2 by itself shows only as 512 if i put bouth sticks in 1&2 shows 1024 should show 2 gigs
  • 167 Answers
Hi, are the sticks all the same type? make sure they are seated well, had same problem on my msi board, i seated them and moved them side to side carefuly. and it saw the sticks not detected before. also if they are not the same specs, there may be a compatability problem, most ram is backward compatable, but if not the same specs could be a problem. in my case the slots were worn from too many upgrades,and seating them properly worked. hope this helps you, happy new year!
Posted on Jan 01, 2009
I have 2 sticks of 512 MB DDR 400 pc3200 in the motherboard but when i use crucials scanner to find out what memory is compatable with my computer it shows 2 sticks of 256. This board is supposed to be...
hi
your motherboard supports following RAM only
Note: PC2100/PC1600 up to 3 DIMMs; PC3200/PC2700 up to 2 DIMMs; 1GB PC3200/2700 with 32 DDR chips up to 1 DIMM only)
Aug 04, 2010 | ASUS P5S800-VM Motherboard
I have 2 slots, currently only one is in use, it has 512 DDR 400 MHz PC 3200U. Can I use both slots and how much RAM will my SiS 963Lua support? Thanks. Richard
Hey Richard, your board has 2 x 184 DIMM slots, that are both usable, with a maximum capacity of 2GB, supported RAM types are 333MHz, and 266MHz..
Hope this is what you are looking for,
Cheers,
Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB
Apr 09, 2010 | Foxconn K7S741MG-6L Motherboard
Only half of the RAM is active
HI,
Well, you need to understand that The first 2 slots on the board supports DDR2 and the last 2 supports DDR, so first off make sure that your using the first two slots. With that said, I assume that the Ram are identical? If not, that can be problematic. The next thing I would check is the bUS speed, and check with the mfg to make sure they are compatible modules. It supports DDR 333/400 and DDR2 533/400
As well as supports 128/256/512/1024 Mb technology up to 2GB. If your memory falls within these specifications, then put one chip on at a time to test to make sure that each one works independently, as well as try each slot independently. , If both work that's a good thing. You also need to update your BIOS which you can do HERE. If you've checked your slots and each memory stick, and you've updated BIOS, they should work. If not, they there is something wrong with the board when two chips are inserted, your connector between the two slots must be damaged. However, most unlikely, If you follow the above suggestion, you should be OK.
Good Luck,
Mark
Dec 29, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
Two 1GB 400MHz RAM's or two 1GB 333MHz RAM's??
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot
So, yes, you can put two 400MHz modules in the slots.
Jul 05, 2009 | MSI 915GLM-V Motherboard
What is the ram limit of HP Pavilion 061 DW234A-ABA A530N I have two sticks of kingston 512 in it right now but want to put in two sticks of 1 GB each. Can I? Nvidia 7800 GS OC with 500 watt power supply,...
From the HP specifications page for Pavillion A530N:
Memory type DDR Memory speed PC 3200/2700/2100/1600 Memory sockets Two DDR DIMMs (184-pin) Maximum HP/Compaq approved memory Two x 512 MB DDR-DIMMS, 1024 MB total (1 GB)
Mar 10, 2009 | ASUS Computers & Internet
Memory installation
Most likely, it is a limitation of your motherboard. Not all motherboards or computers can physically read all types of memory or they may have memory limitations. For instance, I was working on an older Gateway this week. It had 2 memory slots but the maximum amount of memory the computer would recognize is 512 MB. Therefore, if I had put to 1 GB sticks in, provided the computer could use it, the maximum the computer would be able to see or use is 512 MB. In this instance, that is most likely the scenario. The best thing to do is to go to www.crucial.com and run the system scanner. It will tell you how many slots you have, what the maximum per slot capacity and the total capacity of your computer is.
Thanks and please take a moment to rate as fixya.
Nov 06, 2008 | Intel Motherboard
K7VT4A-Pro Mobo
Greetings,
The motherboard will read 1GB DDR400 memory per slot only.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 19, 2008 | Asrock K7VT4A-Pro Motherboard
Cannot Install 2 GIG Memory Upgrade
you got the DDR 2 RAM right? and wont boot you say means you don have even the power on in the CPU or no display?
Jun 16, 2008 | EliteGroup GeForce 6100SM-M Motherboard
Upgrade from 512MB to 1GB
The specs on the memory are correct, so you purchased the correct type of memory for this motherboard. If your getting no video when you power on with the 1gb stick, I would be willing to bet the 1gb stick is bad. Can you return it and try another stick?
Mar 15, 2008 | ASUS P4B266 Motherboard
OS won't work with RAM upgrade
Hi !
if u wanna upgrade RAM ,ur RAM should be of same capacity in both slot. i mean to say if u wanna use 1 GB....then put 512 & 512 or else put single 1 GB. But u cant use 512 in one slot & 1 GB in another slot at a time. if u do the combination like that ,it will never work.
--APARNA (Mumbai)
Jan 12, 2008 | Foxconn WinFast K7S741MG Motherboard for...
VIA MSI K8T Neo2-F K8T800 Pro Socket 939 DDR 400 ATX Motherboard w/SATA, RAID, LAN(Gb), USB 2.0&Audi... (MMK8TN2F) Logo
94 people viewed this question
Top VIA Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
joecoolvette
joecoolvette
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
