Question about Canon PowerShot A620 Digital Camera
Memory card error after inserting SDHC card on powershot A620
I recently purchased new 4 GB Transcend SDHC memory card.
My canon A620 works fine with SD card but once i put the SDHC card i get memory card error.
I have formatted the card on my laptop with file type as FAT 32.
Is canon A620 not compatible with SDHC cards? cause the same card works fine on my friends camera who is having canon powershot SD 750
  • 6 more comments
  • Anonymous Feb 17, 2009
    same problem, didnt know camera does not support SDHC
  • Anonymous Mar 07, 2009
    Purchased SDHC 4 GB, SanDisk. Memory Card Error. Tried HP SDHC 4 GB. Memory Card Error. Will drop down to 2 GB based on last comment. Seems silly considering other cheap Airtek video accepts anything.
  • Anonymous Mar 24, 2009
    today
    i bought SDHC 4 GB
    when i insert this card in to my canon A620
    it show memory card error
  • CameraR
    CameraR May 11, 2010
    I'm also a happy owner of the very fine A620 camera. But I've also unfortunately discovered the hard way as you have that it does not support SDHC cards. Hang on to the card, you'll eventually find something else that can use it (mine ended up in my wife's SD1000).
  • Anonymous Mar 15, 2014
    SDHC give error or damage message when inserted into computer
  • Anonymous Mar 25, 2014
    worked fine earlier today. Downloaded my pics and then went to take more and camera says no card.
  • Anonymous Mar 27, 2014
    I just purchased the canon powershot sx50 hs. The manual directs me to format the memory card before doing anything else. It said I need to access the format screen but does not tell me how to do this. How do I access the format screen?
  • Anonymous Apr 01, 2014
    Bought a brand new SDHC memory chip and the camera will say there is an error. Sometimes it says the memory chip is locked even though I've made certain it is not.
  • 3 Answers
The a 620 only goes up to 2 gb no higher
Posted on Jan 28, 2009
When i insert memory card into my canon a620,it is unable to read the card.memory card is what i see on the camera when i try to take pictures.please how do i solve this problem?
What type and size memory card? The A620 works with MMC and SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
May 29, 2013 | Canon PowerShot A620 Digital Camera
I have a canon powershot a520 camera it it says memory card error only when I use the 8 gb memory card?
The A520 works with SD cards. Your 8GB card is actually an SDHC card. While SDHC cards fit into the slot, they are electronically incompatible and will not work in devices not specifically designed to use them. You need to use SD cards, 2GB and smaller.
Oct 10, 2012 | Cameras
Can I use 8GB SD cards in my Canon Powershot A620 camera? I thought I once read that it will only support up to 2GB SD cards.
The A620 uses MMC and SD cards. SD cards max out at 2GB in size. Larger cards are actually SDHC or SDXC cards and will not work in the A620.
Jan 11, 2011 | Canon PowerShot A620 Digital Camera
Bought new sdhc memory card and it reads memory card error please help
The A620 is designed to work with SD cards, not SDHC cards. SDHC cards will fit into the slot but are electronically different. You'll have to stay with SD cards, 2GB and smaller.
Jul 03, 2010 | Canon PowerShot A620 Digital Camera
Cannon Powershot A540 SanDisk SDHC 4 gb I insert the card and receive a memory card error. Can't format
A 4 gb memory card is beyond the capacity of your Cannon A540. It is too large. I would stick with a 1 gb card in that camera.
May 28, 2010 | Canon PowerShot A540 Digital Camera
When I inserted the new memory card (SanDisk Ultra II, 4GB) into my Canon PowerShot A620, it tells me "Memory Card Error". This is a brand new card. What do I do? It had been working just fine with a...
Some cameras cannot handle over 2GB memory cards. If it works fine with 2GB card - stick to that. If some other A620 you know operates with 4GB card, take yours to repairs.
Oct 24, 2009 | Canon PowerShot A620 Digital Camera
Canon powershot A620 - putting a a memory card and it says memory card locked - it's a new card and it's not locked - what should I do?
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Oct 24, 2009 | Canon Cameras
Camera will not accept any memory card over 2GB. Keeps saying "Memory Card Error"
Most new 4GB and larger cards are SDHC cards (look on the card). Although they look exactly the same as a standard SD card, they are not. Unfortunately, there is no way that these cards will work with your camera, as it was designed before the SDHC format came out. As you've dsicovered, 2GB and less are standard SD cards, and will work with your camera.
There were a few standard 4GB cards produced a few years ago, most notably by ADATA (I have one that I use in my A620). Unfortunately, these are rare now, and are somewhat expensive if found on eBay.
Oct 11, 2009 | Canon PowerShot A620 Digital Camera
Put new SanDisk 4GB card in Canon A620 and get Memory Card Error
The A620 came out in 2005, before the SDHC (high capacity) protocol had been introduced. The A580 came out in 2008 and is compatible with the SDHC protocol. The A620 is only compatible with the SD protocol, and maximum capacity under this protocol is 2MB.
Aug 27, 2009 | Canon PowerShot A620 Digital Camera
I put a brand new SanDisk SDHC 4 GB memory card in and it says "memory card error; card is locked".
I also own an A620, but unfortunately I also learned the hard way that SDHC cards are not compatible with this camera. The A620 was designed before the newer SDHC format came out, thus although they look exactly the same, your camera will never work with these cards. Your camera uses standard SD cards (2GB or less). There are some standard 4GB SD cards, but they are very rare these days, and costly.
Aug 06, 2009 | Canon PowerShot A620 Digital Camera
Canon PowerShot A620 Digital Camera Logo
4,583 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
