Question about GE (PSS26MSRSS) Side by Side Refrigerator
I have a ge side by side refriderator I hear a gurgeling sound and then find water on the floor in front of my refridgerator I do not think its a cloged evaporation line I think it is somewhere on the supply side
  • 54 Answers
Sounds like you have a clogged defrost drain. If you see the water one to two times a day then check the drain.
Posted on Jan 04, 2009
Ge monogram refridgerator water on floor
Is the water filter located behind the grille under the doors?. I had the same problem and found the O ring on the filter cartridge was leaking.
Dec 17, 2015 | GE Refrigerators
Ice Maker working, but water not dispensing
There are two sides to a dual water control valve. One side fills the ice maker and the other side is the dispenser. If one side goes bad you will need to replace the whole dual water control valve. If your model is the GSL22JFXLB your replacement is the=> WR57X10032 Water Inlet Valve
This part is found on the rear of your refrigerator near floor where the water from your home hooks up to your refrigerator, Thanks Sea Breeze
Mar 08, 2013 | GE GSL22JFXLB (22 cu ft) Side by Side...
Ge monogram has water droplets in refrigerator side just along top right corner edge where top door gasket closes against refridgerator. Refridgerator seems to be holding temperature. Condenser is above...
The gasket may have worn some causing an air leak,.and you
are seeing water condensation from the leak. Try adjusting
the door hinge. Close the door on a piece of paper and see if
you can pull the paper out. Adjust the hinge until the paper is
tight.You may have to adjust both hinges to align it properly.
Feb 08, 2018 | GE Monogram Side by Side Refrigerator
I have a ge Profile side by side refrig model TPX24PR or BR or BI or SI. When we call for water or the ice maker calls for water, I can hear a hissing sound coming from the front right corner and then...
That hose actually ran Through the floor of your refrigerator on your model. so the leak is most likely under the floor of the fridge in the line coming from the water reseviour to the outlet.
Jun 10, 2010 | Refrigerators
The freezer has frost inside and everything is thawing out, the refridgerator is cool. I have tried to turn both sides up, but nothing.. Is it the compressor?
The pproblem is in your defrost system You have to check the defrost timer, Heating elements, and defrost thermostat. The coils have to be clean to have air flow to the refriderator side.
Apr 27, 2010 | GE GSH25JFR Side by Side Refrigerator
GE Refridgerator leaking
it is possibe the inlet to the drain line may be plugged.The defrost water cannot run down the drain line to the pan on on the bottom.Also make sure it is level
Apr 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
75 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
