Question about Dell Latitude CPX Notebook
Blank screen on dell cpx550 laptop
When I boot up I get only a blank black screen-No cursor- The power lights come on-If I hit cntr alt delete, the computer will sound a tone and eventually just cut off- Any ideas are appreciated-
What is the f2,f8, r f12 want work? only the Ctrl+ Alt+ del that wroks
F2 usually takes you to the BIOS setup screen, you need to hit the keys as soon as you power up.
F12 selects on a Dell instant boot menu to select booting from CD-ROM, USB, etc rather than the BIOS options.
F8 goes to safe mode start up for windows, this must be done before the windows logo comes up (ie when it is a black screen).
Control - Alt -Delete Keys together can be used any time, after windows boots as it tells it to re-boot the computer, back to start up.
Jan 30, 2015 | Computers & Internet
I have a dell desktop computer and my cursor is frozen I have a blank screen but I have the icons down the bottom I tried rebooting it and also pressing the control key and the alt key and the delete
OK first try and disconnect from the power for at least 10 minutes. Then when she is restarted hit the escape key and see what it "boots up to. Make sure it boots "optical"(CD etc), and then Hard drive. and then again restart. This time keep hitting F9 or whatever the emergency start is and that will take you to safe mode. If it does not then you may have either a dodgy hard drive or a corrupted windows.
In either case get you master disc out (oh dear you have not got one, then scrounge one of the same genre Vista etc) from a friend and see what happens when you try to boot from the disc.
I am guessing that you have serious problems though, eg us hard drive and or corrupt hard drive that effectively means getting a new hard drive and a new copy of windows which probably is not worth it.
Me, I would get a motherboard bundle, a new hard drive and new windows from someone like Novotech and redo.
Moral, never ever get a machine from a source, if you do a limited build yourself you can always get it going again with limited parts.
Sorry I cannot be more helpful.
Sep 29, 2014 | Dell Inspiron 530 Desktop Computer
Vostro 1500 screen blank except for flashing cursor
The good news is that your laptop powers on and you have a display. The bad news is that you laptop is trying to boot up from an OS (operating system software) like XP, Vista, or Win 7. Ether your software is corrupted or you have a problem with the hard drive or hard drive controller.
Press and hold the <Fn> key while powering the system on. This will run the Dell Diagnostics. Another more intense diagnostic program is located on a Dell CD that you should have received with your laptop. Look for one that has "Diagnostics and utilities" listed under the "Contents". You will have to boot from that CD disk. To do this, power on your laptop and tap the <F12> key to bring you to the "One time boot menu". Insert the CD and then select CD/DVD drive and hit <Enter> key. Select the "Run the 32 Bit Dell Diagnostics".
If diagnostics pass then your software is corrupted and needs to be reinstalled.
Mar 03, 2013 | Dell Vostro 1500 Notebook
When i power up my Acer M3400, everything loads then after the 'welcome' windows part the screen goes black and i can only see the mouse cursor? I tried to restart but nothing happens. It keep
Not sure, but try loading Safe Mode by pressing F8 during boot and lowering screen resolution. In Safe Mode you can even run System Restore. It load to a previous date that you choose.
Jan 11, 2013 | Acer Aspire M3400 PC Desktop
Laptop cursor dark screen
can you tell me more about this situation, i build and troubleshoot computers all the time but this question needs more detail. you say laptop dark screen blinking cursor, the only thing i can get out of that is one thing. while booting up hit the f2 or delete key several times till you get into the bios, then find the tab that says default settings hit save and exit and reboot it, but more information would really help me to help you,
Nov 10, 2012 | Dell Latitude D620 Laptop (Latitude-C620)...
I have a Dell Latitude e5500. when booting the computer the Dell start up screen appears and then is replaced by a black screen with a blinking cursor. I have tried pressing control+alt+delete; this...
You have errors in the boot section, not allowing any of the GUI's to run.
When the system starts press F8 and when you get the menu select Recovery.
That will fix it.
Dec 19, 2010 | Dell Computers & Internet
Dell Inspiron 1501 - black screen periodically
Hi,your problem could be as a result of a bad screen or screen connector(Flex)have a technician look at it.
Jan 02, 2010 | Computers & Internet
When powering up my dell inspiron 1501 laptop, its goes to a black screen that says bootmgr is missing hit ctrl alt delete to restart. Don't have my system restore CD or a boot CD, how can I fix this.
Hi, without these boot cd´s it is not easy to recover from this state. These are necessary.
If you need to access your disk badly, you can use a linux live cd, boot it up store on a usb key.
Sorry to disapoint, but the recovery cd is necessary ( or a windows installation cd ).
Oct 15, 2009 | Dell Inspiron 1501 Notebook
Probs with boot up on a Dell inspiron 530s
When booting enter the BIOS setup svreen and press the following combination
1. Alt + E
2. Alt + F
3. Alt B
this combination will rebuild the IDE configuration and clear the NVRAM. Alt + b will save the configuration.
Alternatively
1. Shut down PC and unplug Power cable from Back of Tower.
2. press the power button and Keep holding for 10 seconds. this will remove static charge from PC
3. Plug in cable and restart.
Jan 13, 2009 | Dell InspironTM 1501 Notebook
Itronix GoBook IX550 PC
hi, try cleaning the Ram contacts or replace.. its a mem issue.. let me know
Jan 02, 2008 | Itronix GoBook IX550 Notebook
Dell Latitude CPX Notebook Logo
Alun Cox
