Question about Toshiba gigabeat S MP3 Player
Gigabeat S freezes when trying to sync
My MES30V Toshiba Gigabeat had been working fine for almost two years, but now when I try to sync with Windows Media Player, the Gigabeat locks up on the "Initializing..." screen and WMP will not recognize the player. The only way to unfreeze it is to turn off the battery for a few seconds, but it locks up again if I attempt to sync.
  • 6 more comments
  • aboettner Jan 02, 2009
    i have the same issue. any luck figuring it out?
  • w_puck Jan 02, 2009
    Same problem here. I had read about the Zune problem and hoped that by running down the battery last night and trying again today it would be fixed. but no luck.
  • stewartm1 Jan 02, 2009
    Same problem here with my S60. Tried letting the battery run down and then recharge, still completely locked up. Where do we go for support?
  • aki21 Jan 02, 2009
    I have the exact same problem with my S60. Player also freezes when I try to play the few CD's that I ripped and didn't download.
  • Anonymous Jan 03, 2009
    yep, me too....
  • w_puck Jan 03, 2009
    I saw this article but am still having trouble with my Gigabeat
    http://www.engadget.com/2009/01/03/y28-z...
  • aki21 Jan 07, 2009
    All, I tried the solution below. It's kind of an ordeal but it worked. You will have to reformat (and lose all data) but then you can sync again.
  • w_puck Jan 09, 2009
    Sweet! I tried it and it worked. I must say I wasnt quite sure when to unplug the device (everything is written in (Japanese?)), but when it appeared to be done, I unplugged it and everything was pretty easy to go along with from there. Its resyncing my files now.
    Thanks
Toshiba Gigabeat-U MP3 Player suffering "USB ERROR #203"
try reinstalling any software that come with it.
try a different usb cable.
try different usb ports.
Jun 28, 2009 | Toshiba Gigabeat MEG201 MP3 Player
4yr old gigabeat 30gig won"t connect to PC
Try re-installing windows media player 10. It did the trick for me.
Feb 26, 2009 | Toshiba Gigabeat S30 MP3 Player
Vista recognises Gigabeat F40 as a hard drive and not an Mp3
hi had the same problem with mine, you must use the dock and have the connections setting set to media player it will sync then
Dec 05, 2008 | Toshiba Gigabeat MEG-F20S MP3 Player
File transfer Problem
Ok, I figured out a solution on my own.
Remarkably simple - all I did was reformat the player again and then reinstall windows media player.
Although in my travels I came across an article which may help users with a similar problem: http://support.microsoft.com/kb/911091/en-us#appliesto
Apr 20, 2008 | Toshiba gigabeat S MP3 Player
Toshiba Gigabeat
try using windows media player it does work if you go to the setting file on yor f20 and slect media player in the pc connections folder
Apr 20, 2008 | Toshiba Gigabeat MEG-F20S MP3 Player
Wont sync properly
i have the same gigabeat n its totaly frozen, so tell me if u end up fixn urs so i can fix mine.
mike
Jan 02, 2008 | Toshiba gigabeat S MP3 Player
Computer does not recognize Gigabeat Device
the solution is simple. Simply Run both Gigabeat watcher and giga-room programs as administrator if u have windows vista.
How to do this :
Click on start in the taskbar at the bottom right of your screen,
then click on all programs,
then click on the Toshiba Gigaroom Folder,
then right click Gigabeat watcher and click on "Run as Administrator"
then right click "Gigaroom" and click on Run as Administrator
and then look in the bottom right of the taskbar, the little Gigabeat watcher symbol should be there with a green square instead of grey. If its green then it means Vista has recognised your gigabeat and u can now transfer music to it via gigaroom. i hope this helps people as i was on the verge of buying XP myself again... Peace all and HAPPY GIGABEATIN!
DREZO 9/3/2009
Oct 12, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
Toshiba Gigabeat F40
Toshiba Gigabeat support is 1-877-250-8595
Sep 29, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
Gigabeat wont Mount or Sync
Hi Ben, Make sure you have Windows Media PLayer 10 installed and working or download "Gigabeat Home" - that might help. Good luck. JayMac
Feb 23, 2007 | Toshiba gigabeat S MP3 Player
Toshiba gigabeat S MP3 Player Logo
378 people viewed this question
Top Toshiba Audio Players & Recorders Experts
James DuPont Jr
James DuPont Jr
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
