Simply no image on screen completely black with words'operating system not found' at top.
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty. . Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
SOURCE: Operating system not found, hard disk not found message showing in IBMT20
Your hard drive is most likely bad or the ribbon cable is not connected.
SOURCE: operating system not found
the laptop is unable to read operating sistem from disk - you have to try to insert recovery disk after changing in the bios (you can read on laptop manual how come in bios for changing to first boot is hard disk to first boot is cdrom or dvd or cd ) after that you can try to recovery the operating sistem - it may be not so easy delfo
SOURCE: help on my fujitso siemens MS2212 please...
The clicking is from the hard drive. This clicking , along with the error op system not found, indicates that the drive has crashed or failed. You will have to replace the hard drive.
SOURCE: Error loading operating system
Press the F2, and laptop will go to the bios where you will be able to change the boot order from the hard drive to the optical drive.
SOURCE: t 43 says "operating system not found"
Sounds like you have a bad hard drive. Boot up with a Windows CD and select repair at the setup menu. It should dump you to a command line. Type "chkdsk /f" without the quotes and it will check the hard drive for errors. When it's done, reboot normally and it should get you into windows. If it doesn't, replace the hard drive and install windows on the new HDD.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
