Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
Hdmi hook up with 5.1 dolby
Hooked up hdmi cables to my cable box and sony stereo 5.1 system television does not broadcast in 5.1 unless using a patch cord setup is there somewhere in the menu i should be changing something
  • rdupuis15 Jan 02, 2009
    thanks lebones this should help a lot ron dupuis
  • 152 Answers
Yes. its going to be in the cable box that you will have to change the resolution to whatever the highest your tv is. if it is a directv. go to menu-settings-tv resolution
Posted on Jan 01, 2009
  • lee r
    lee r Jan 02, 2009
    need anything else just holla
Sony BDV-370 DVD/5.1 theater hooked to Sony Bravia TV and cable box. No sound comes from rear or center speakers with HD cable.
Three things can cause this:
1) not all HD is recorded in surround sound. You can very well watch an HD program that just has Left/Right stereo audio. Tombstone on bluray is even only in Dolby 2.0
2) wrong connection is used. If you only use red/white analog stereo cables you will only get sound out of the left/right mains.
3) setting on the cable box is set to stereo and not surround. Changing this varies by cable box manufacturer.
Mar 01, 2011 | Sony BDVE300 Theater System
I hooked up a new lg hd tv via hdmi through my digital cable box. I am not receiving true surround sound, only dolby II. I have my box digitally hooked up to the receiver and the HDTV digitally hooked up...
It's possible that the TV broadcast isn't in true surround, and is only dolby encoded.
You can try going back to the component hookups, but I am not sure that will solve your issue.
Feb 27, 2011 | Panasonic SA-HE100 Receiver
I am trying to hook up my tv through a onkyo receiver with polk audio speakers what is the best way to hook this up my cable system is from comcast with their hd converter box.
Use either an optical cable to your reciever or a digital coax, which ever you can or do use will give you dolby digital. Unless your onkyo has hdmi swithching. In that case you will need 2 cables, those are the best for picture and sound all in one cable.
Aug 06, 2009 | Hitachi 43UWX10B 43" Rear Projection...
When i hook up my hdmi cable box how do i get my stereo to run sound..? or can i..?
HDMI is audio and Video in the one cable, if your stereo has HDMI in and out you can run it from your box into your stereo then into your TV, but only if everything is supported by your componets, I would suggest, HDMI into your TV, then from your box, stereo or optical into your stereo, by just using RCA cables. ALSO remember with audio compontes, more is MORE, more cable better quality (not length but size)
Jul 05, 2009 | JVC LT-42E478 42 in. LCD Television
Low volume on LG HDTV
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see
Hope this is useful.
May 19, 2009 | LG 37LG30 37 in. LCD HDTV
Surround sound
How do I hook-up my surround sound system with powered sub woofer to my Sony stereo receiver and sony dvd player?
Sep 19, 2008 | Sony DAV-HDX500 System
No dolby digital signal
Put your optical cables into the amp and not the tv,also make sure the ps3 audio is set to bitstream.
hope this helps.
Jul 12, 2008 | Audio Players & Recorders
How do I hook up the HDMI cables to a cable box
how do i hook up hdmi cables to cable Sony KDL Bravia LCD HDTV
Jan 19, 2008 | Televison & Video
Dolby digital problems
When using analog cables, switch the setting on the amp to 5CH STEREO or 7CH depending on your speaker configuration. This will give you consistant audio. Another option is to use either optical or SPDIF for digital sound. Good Luck.
Dec 30, 2007 | Denon AVR-887
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
70 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
