posted by silvermint on May 08, 2007
My airconditioner has started to leak water into the room, and is becoming noisier. Does any one know what would be the cureent model replacement for it?
Also, the manual says if it is leaking into the room to tilt it back, but it is wedged in tightly, and has also never done this before, so I suspect this may not be the problem. Again, any suggestions?
Solution #1
posted on Jul 15, 2007
Remove the front panel, & look for the drain tube that runs from the drip pan under the cold coil. It is likely blocked & may be cleared with a piece of coathanger wire. Be gentle.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Panasonic CW-1006FU Air Conditioner
Email this problem
Email this problem
Can you Help with these Air Conditioners problems?
Repair Service
Find Air Conditioner Repairman Near You:
