I am short and would like to know how much is safe to lower the bike.
Anything much lower than an inch and a half, the ride quality suffers bad! Put a lowering kit in the front forks and use shorter shocks in the rear. DO NOT install any type of aftermarket kit that moves the rear shock mount rearward. If the bike still isn't low enough, check into purchasing a thinner seat. Good luck!
SOURCE: lower 2008 triumph rocket touring?
You need a rear suspension lowering kit, made in UK for loadsa different bikes
These are available from 1 of my wholesale suppliers
Contact me for more information
The other ways (smaller back wheel &/or smaller & stronger shocks) are trial & error which usually ends in bigger problems
Ride safe
Bike-Doc
Please mark this as very helpful (if it has been!!)
SOURCE: How do you change the rear tire on a 2008 Street
1) Remove hard bags.
2) Use a marker to mark a position of the belt tension cams on the axel. This will help you put the proper amount of tension on the drive belt when you put it all back together. The left cam is welded to the left side of the axel. The cams are used to tighten or loosen the belt tension. You will see what I'm talking about when you get there and look at it.
3) Remove the two bolts from the rear of the left side bag support. Then loosen the front bolt of the bag support. (Remove the left fusebox cover to access the front support bolt.) Lower the bag support. This is necessary to slide the rear axel out.
4) Remove the two banjo bolts from the rear brake bracket and slide off from the rotor. Support brake with something so you don't damage the brake line.
5) Look carefully at the spacers on the axel and note, along with the order.
6) Loosen the cone nut of the axel on the right side of the bike, but don't remove.
7) Use a bike jack to raise the bike so that the rear wheel is barely touching the ground. Just enough that you can turn the rear wheel and feel the treads rubbing the ground.
8) Remove the cone nut from the right side, along with the right alignment cam washer
9) Genlty tap the end of the axel from the right side of the bike until it slides out from the wheel hub.
10) Pull the axel from the left side, take note of IDS washer and spacer order and position.
11) Slowly jack up the bike until you can pull off the belt pulley...that also contains the IDS (Isolated Drive Sprocket) NOTE; Check that damned IDS bearing in the drive pulley. I have gone through 4 of those crappy bearings...usually every 10k. If the seal is broken on the IDS bearing, get it replaced. This is the wicked gremlin of the 08 FLHX. The rear IDS pulley should just pull away from the hub at this point.
12) Jack the bike up until you can roll the tire, or get it out from underneath the bike. Did I tell you to strap the bike so it doesn't fall over? Just in case ya'know.
It all goes on in the reverse order. I never mount the tire on the rim...I have someone else to that and the balancing. Make sure none of the rubber isolators in the drive pulley have fallen out. Once you have the axel back in, tighten the cone nut enough so that you can tighten the drive belt by turning the cams from the left side of the axel. Use the paint marks you put on the right side of the axel cam to get the drive belt tension where it was at the time you started this whole process. Tighten hand tight, then loosen one full turn, then tighten the cone nut on the right side to torque specs. (Damn, I can't remember what that was. I think 90 - 110 foot pounds but I can't say that with certainty. I think the brake bolts are 35 to 45 foot pounds.)
Hope the helps. You can get cheap PDF shop manuals online if you look hard enough. The best investment I have made was a Harley Shop Manual for the bike...but they ain't cheap.
SOURCE: 2007 street glide misses and wonts to stall out when taking off??
my roadking just did the same thing, check the gasket between carb and intake
SOURCE: changed handle bars on 2009 flhx street glide -will not start
I would be inspecting the kill switch. Only thing on the bar that could be it other than the start button.
SOURCE: bike won't start, new Harley
I'm not too familiar with the later model bikes but if I were getting a clicking noise under the seat and the bike was not starting, I'd investigate the source of the noise. It's possible that it is a starter relay that engages the solenoid that is an integral part of the starter. Look at the starter from the right hand side of your bike. You'll see a single small wire that connects to the end of the starter just above the end plate of the solenoid. Disconnect this wire and connect a test light or volt meter to the wire. Turn on your ignition switch and press the start button. You should hear the click under the seat and see voltage at the end of that wire. If not, replace the relay, a plastic cube about an inch in dimension.
Good Luck
Steve
