I am looking for a replacement cord for Salton food warming tray #H6
You can contact Salton here or here or e-mail
[email protected]
We're
happy to help you with free
advice and we'd appreciate your thoughtful rating of our answer.
SOURCE: I have a Salton Hotray
Try to find an old TV "cheater cord" from that era. It works perfectly AFTER you shave down the plastic "ears" on either side of the prongs.
SOURCE: i have salton microwave bought
If there is no action please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Now keeping clear of the microwave, switch on , use a cup of water inside to test.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Make sure that the program controller is working if not check power - step dwon suppy, the pads are responding- if not fauty pads- or the door switches ,if contact is not through the microwave willnot work.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues , you can use the microwave safely
Testimonial: "ya u siagonosis is perfect & u wote the correctpossbile tips to fix the problem thanks"
Hello &
Welcome to FixYa You can find
the cord here or take the tray to a local shop they will give you a similar
cord that will fit into this. Please get back to me if you have any other
questions. Kevin
SOURCE: LOOKING FOR REPLACEMENT ELECTRIC CORD
Please check the lin below and see if the spares you require is available. If not post a query to the suport link.
http://www.espares.co.uk/search/microwaves/p/1095
