Question about APC Conext 900VA (cnb900) UPS System
Erratic beeping unit started making erratic beeping that runs approx. 1 minute and then quits, it does this at least 3 times a day. no apparent reason(spikes, brown outs etc.) Could this be that the battery is going bad ? it is 7 years old now and started doing this about a month now.
This is a signal that the battery is dying, and is failing the self-test. According to Conext, the battery replacement alarm goes off for one minute every five hours. You should also see the replace battery light on the front of the unit lit. Changing the battery should solve your problem.
Posted on Mar 25, 2009
  • 192 Answers
That is probley it it is going bad or it has been unpluged from the sorce to charge it.
Posted on Jan 04, 2009
What's causing the beeping and the unit to not work (apc ups rt 3000)
Its because your wire joint to the ups may have gone or its internal bridge may hace gone off. So try to exchange the wire with a new wire supporting high voltage.
Apr 06, 2013 | Computers & Internet
We have a dryer model LEQ1442ES0 and after running for a few minutes all lights go out ,unit stops and starts right back up and all lights on right side will blink 9 times as unit stops. lights continue to...
Replace the thermistor to take care of this problem. When it is bad, it thinks the unit is too hot so it opens the circuit that is why the unit stops.This erratic behavior causes what you described. It looks like this.ef36731.jpg
Apr 18, 2010 | Dryers
I was playing music off PS3 HDD when we had a power cut for approx 0.5sec. Surge/spike protecter was fitted to power source, but no power back up was fitted. Error msg was on screen saying to turn off PS3...
This is a processor error. There is no way to get to the restore screen when you have the yellow light issue. Try CPR in NYC. They usually have a 1-3 day turnaround time, and are pretty cost effective. You can easily ship them your unit. They are faster and cheaper than Sony!
website is www.cpr-nyc.com
Hope it helps!
Mar 30, 2010 | Sony Playstation 3 (PS3) Console
Frigidaire Range - Model #PLGFMZ98GC - Beeping
Turn or unplug from wall, let sit for five minutes then plug back in. If unit is ok and then in a day or two does it agin or starts beeping agin, then replace clock control. Common problem with this unit after about two years of use. Usually caused by defective touch pad or "endless loop" in programing code of micro-processor. One other problem, is if you had just used the self cleaning mode, then you may have a oven lock problem, doubtful though, clock control is majority of prob on these units.
Oct 01, 2009 | Frigidaire PLGFMZ98GC Kitchen Range
Frigidaire refrigerator making beeping sound
Unplug your refrigerator from the ac outlet, and 0open theref door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door. wallah it's fixed.
Dec 21, 2008 | Frigidaire FRS3R5EMB Side by Side...
Audi A4 strange beeping
I just had the same problem and read on another post how to fix it. Unlock your car, open and close all the doors, and lock it manually with your key. It worked.
Jul 01, 2008 | 2000 Audi A4
NewAir AirConditioner on "Dehumidifier" Mode Only
I have a 3 ton a/c system that removes about 5-6 gallons of water from the air per day. Most portable dehumidifiers/air-conditioners rate at approx 1/2 to 3/4 of a ton. Your water output is pretty much normal.
Jun 23, 2008 | NewAir Heating & Cooling
Red caution light
The red light is in conjunction with a safety. This is there in case something goes wrong, the heater doesn't overheat and possibly catch fire. If its not getting too hot, and its sounds like its not. The safety needs to be replaced. It will be a little disc shaped thing with 2 wires connected to it. If this heater also has a tip over safety, there also may be some type of mercury switch too. If you are so inclined, when you find the safety disc it should have some numbers on it. This indicates the temperature it is made to turn off at. After removing it, connect the 2 wires together and turn the unit on with a thermometer in the spot where the disc was. If the temp. doesn't go higher than the #'s on the disc after 45 seconds like you said, then you know positively that is the problem. If it gets hotter very fast, then the elements need to be looked at for defects. If there are no numbers on the disc or you cant find a replacement, then it may just be easier to buy a new heater.
Mar 03, 2008 | Patton MH761 Utility Heater
What is brown out
Brown-out .... What is it? Brown-out is a condition of lower than normal power line voltage being supplied by your local utility or generating equipment. This condition may be short term (minutes to hours) or long term (1/2 day or more). A power line voltage reduction of 8 - 12% is usually considered a Brown-out.
What causes Brown-outs? Electric utilities (your local, lovable Power Company) may occassionally reduce line voltage to Brown-out levels in an effort to adequately manage power generation and distribution during periods of heavy usage. Very hot days, when most air conditioning and refrigeration equipment would be operating almost continuously, is an example of such a situation.
Even without utility intervention, extreme overloads caused by most air conditioning and refrigeration equipment operation could tax the electrical distribution system to the point where a permanent brown-out state could exist over much of the power company distribution network.
Locations at ends of long electric distribution lines may experience chronic Brown-out conditions due to line loss. Intermittent heavy loads on this trunk circuit may cause the Brown-out effect to fluctuate with the load.
Installations using ship-board or temporary power sources are especially prone to operation in a Brown-out mode. Usually of limited capacity, it is quite easy to overload the power source, giving rise to permanent Brown-out. (Permanent Black-out, if users are not careful).
What are some common effects of Brown-outs? Brown-outs are the mother of all sorts of Bad Stuff.
Power supplies in some electronic equipment may fall out of regulation. Errors, due to erratic power supply performance, may creep into computer operations.Other electronic equipment may function poorly - or not function at all.
Marginally performing devices (electronic or electric) will probably cease operation entirely.
Motors will overheat. Some motor types will slow down.
Electrical interference will greatly increase. Increased interference may affect computer and communication operations.
Off-line UPS units (the vast majority of lower cost units) continuously cycle between power line and internal battery operation. UPS batteries (generally sized to provide only 5 - 10 minutes back-up) will soon be discharged, unable to generate additional Back Up power. You are out of business. If system has not been shut-down, the entire system (UPS & computer) may snap back to life when power rises slightly, only to again shut down when the power line voltage falls back into the Brown-out zone. Such "ON-OFF" operational cycling is unhealthy for UPS, batteries and connected electronics. For Brown-out correction see our Voltage Regulator Page.
Spikes generated by electrical machinery also greatly increase. Air conditioners, refrigerators and other motorized devices generate local spikes. Industrial machinery (often miles away) create additional spikes which may find their way unto the electrical distribution system, and into your sensitive, valuable equipment.
Oct 25, 2007 | Samsung RS2630SH Side by Side Refrigerator
APC Conext 900VA (cnb900) UPS System Logo
517 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
