Question about Bulova Watch
Don't know how to set my Patek Replica calendar
I have a replica Patek Phillipe with year + month day of the week, date and moonphase. I can set the month and date but not the others. It is stuck on 2005, how do I change the year?
    Filmmaker:
    Uploaded 5 video answers.
  • 26 Answers
Most Likely they are non functioning. If there is little buttons on the sides of the case try and push them in with a pin. But most likely you are stuck with them the way that they are
Posted on Jan 03, 2009
I replaced the battery. The watch started time from Jan. 1
You have to set the year, the month and the date. Then you set the time zone. After that you can set the local time. You may also have to set the Daylight Savings Time.
The watch has a built in calendar that may run from let's say January first 2000 to the year 2070 (just a guess). If you set the calendar correctly you do not have to adjust the date when a month has 30 days, or when it is a leap year.
Sep 27, 2013 | Casio GW330A G Shock Solar Atomic Watch
Nivada wristwatch
I'd look on eBay at the completed auctions as a guide.
Jul 29, 2013 | Panerai Nivada Grenchen Mens Swiss Gold...
The date and day have stopped working on my replica rolex daydate i have adjusted the pin several times but it is still not moving?
Your calendar wheel is damaged. Unfortunately, it is illegal to own or work on a Rolex replica / fake Rolex as it is a trademark violation. I would suggest purchasing a genuine Rolex as a replacement, as there are generally no identifiable movements, and therefore no identifiable replacement parts for the movement in your timepiece.
Be aware, however, that all automatic and mechanical watches, such as Rolex, must be services regularly, every 3-5 years, for them to last and work properly. Thanks for the rating!
Dec 16, 2012 | Rolex Oyster Perpetual DayDate 118239BKSP...
How does its year calendar work?
The day at a glance calendar system used in this Orient watch, has been used in a number of watches over the past 40 years, perhaps most famously in the Wittnauer "2000" watch (which Orient actually made for Wittnauer under contract). Orient itself has used this system in a number of different styles of watches. Note that the daily date window is separate from the day of the week / month at a glance system; the date window is driven in traditional fashion by the movement.
The day/month at a glance system is based on a single disc inside the watch that is manually advanced by the user. If you look at the top of the watch, where the months are listed, you'll see little two-digit numbers. These represent different years--"04" refers to 2004, "11" to 2011, etc. To get the right days of the week at the bottom of the dial, you move the appropriate year under the current month. That will line up the days of the week--Monday, Tuesday, etc.--with their correct dates. You may see the same year repeated more than once on the upper part of the dial because the calendar has a specific pattern that can be replicated.
On older watches using this same system, the top pusher was used to adjust the date window, and a separate winding knob controlled movement of the year/monthly calendar disc. On this specific watch, which I have not handled in person, I cannot see a separate crown to adjust the date, and so I am guessing that you would pull out the set stem part-way to engage the disk setting mode. This would make sense because unlike the date window, where the date is always advanced, the year must move both backwards and forwards to align with all the months in a given year--you'll see that January and October are in the same place on the dial, for example.
If you're interested, here's an example of a vintage Orient that uses this same system for its calendar. Note how the monthly calendar and year/month alignment are flipped from the watch you asked about. Please note that I have no connection with this web site, make no endorsement as to the price being asked for this watch--but it has a nice picture of a classic Orient:
http://forums.watchuseek.com/f30/$128-all-steel-orient-perpetual-calendar-xl-case-vintage-watch-526811.html
On a final note, you'll see a number of people refer to these as "perpetual calendar" watches. That's not accurate. The year / days of the week disc holds about 20 years of calendar information. After that, the disc is no longer accurate, though you can easily keep aligning the monthly calendar just be referring to a printed calendar and adjusting it that way. For a period of time (not sure if they still do it), Orient would accept older watches with this system and change out the old year/day wheel with a new one that went further into the future.
Jun 03, 2011 | Orient CEUAA002WW Wrist Watch
How does moonphase work>
The moon phase is based on the Lunar calendar.
Lunar calendars differ as to which day is the first day of the month. For some lunar calendars, such as the Chinese calendar, the first day of a month is the day when an astronomical new moon appears in a particular time zone. For others, such as some Hindu calendars, each month begins at full moon. Others were based in the past on the first sighting of a lunar crescent such as the Hebrew calendar.
Aug 14, 2010 | Tissot Pr50 Moon Phase T0124231105200...
Can not change the date on a rolex watch it is a replica one. Not a real one. ONly brand new and the hands are not moving and is not ticking. does it require a battery?
No, Rolex replicas did not require battery and do not work quite often. Movement in your watch is very poor quality and to start it going you have to see the watch repairer. Only if he/she will accept to lay hands on replica watch, you have a 50% chance your watch will work.This is why replicas are cheap.
Mar 16, 2010 | Watches
Just been given an Audemars watch - don't know how to set it.
I was unable to find any instructions on their web site, so if you haven't got the instructions, then I suggest you try ringing them on one of the numbers below. (You might ask them for a set of instructions as well as how to solve your problem).
Toll Free: (800) 595-5330
Phone: (239) 262-4545
Jan 31, 2010 | Audemars Piguet Watch
Patek Phillipe replica watch starts & stops
Try to wind it up using crown (winder). If it has automatic winder it will wind itself up while you wearing it on wrist.
Dec 14, 2008 | Bulova Watch
Replica cost
This is a cheap replica fake. No daytonas are engraved on the case back. If new and everything works... I mean it runs... then it's worth is what you are willing to pay for it. Anyone else who knows this watch would not give you much if anything for it. Maybe in a pawn shop it might fool; someone and they may pay $100 for it but that's a rip off. These watches usually have a 21J auto Japanese mov't., fairly reliable, but far from being capable of supporting the true function of running a chronograph.
Better off to search for a quality daytona replica if you like the watch, and get an automatic asian copy of the 7750 valjoux movement, running at either 21600bph or 28800 bph, where all the chrono's function and support the sub-dial true functions of counting seconds, minutes, and hours. You can get a replica Daytona of this quality and reliability if you search the web and ask lots of questions before you buy. You should not have to pay more than $250.00 for this quality of Daytona, but be careful, lots of dealers out there will advertise this same datytona for as much as $625 to $1000, and it's the same Daytona replica, from perhaps the same factory in China, have the same asian auto mov't. and they'll ask much, much more. Don't be fooled. Know who you're dealing with. Get some facts and really know the watch, and learn more of the replica watch market before you ever place an order. Read what people are saying and talking about in "Replica Watch Info." or "Replica Geek" newsletters available to all replica watch collectors and enthusiasts. So, to sum up... If any daytona you see has 24 hrs. at daytona on the case back... beware.. a red flag say's this is fake. By the way, the case back if knurled, is removed with a common jewelers watch wrench. Some of the cheaper daytonas might even be quartz.. but most I've seen with 24hrs. at Daytona have a 21J automatic mov't.
Regards,
Doug
Mar 03, 2008 | Rolex Daytona 116520 Wrist Watch
Band Replacement
The replacement bands for the Cartier 21 Chronoscaph are a complete rip off. Get a replica one!
Now, where can I get a replica one... anyone know please? Thanks.
Feb 22, 2008 | Cartier 21 Chronoscaph W10125U2 Wrist...
Bulova Watch Logo
114 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
