Question about Olympus SuperZoom 115 QD 35mm Point and Shoot Camera
Will not turn on
My superzoom.115 will not turn on even tho I put new battery in it..Does anyone know if I need to have film in it..Also it stopped working, right in the middle of my film, and lost all my pics I had on it..
  • Santol Feb 08, 2009
    Hello
    I have the same problem. I put a new film in it and pressed the on off switch when it did not switch on by itself. I though it was because of the battery. But if putting new battery also did not do the trick, then it could be something else altogether.
  • 3 Answers
Try cleaning the connection, scrubbing at where the battery connects with a wire brush to get rid of corrosion & make sure of a tight connection.
Posted on Feb 20, 2009
I have an old Nikon FG 35mm Camera that I haven't used for a long time. It worked fine when I put it away, however now after loading new batteries and film, I can't ****/reopen the shutter, film doesn't...
Were the old batteries left in when you stored it? Alkaline cells can leak and cause corrosion, no matter what anyone says. A coating of metal salts on the battery contacts could be the problem. I hesitate to suggest that you may have put the cells in the wrong way up, or forgotten where the on/off switch is, but these will certainly stop the cameras working.
Nov 18, 2010 | Nikon F3 35mm Film Camera
My lap top wont turn on i have a blankj screen the
Please try these. After on your pwoer botton wait 2 minites and the press FN+F6.
Let me know what happening.
Thanks.
Jan 30, 2010 | Acer Aspire 6920 Notebook PC
Film has not rewound but has 'reverted' to showing
On the toplate of the camera, to the left hand side, is a button which slides to the left. It is marked with a film cassette outline, and two arrows to the left <| <|
At any time, you can use this button to rewind the film back into the cannister. It should make a whirring noise for 5-10 seconds, and will stop automatically.
If it makes no noise, you may have a flat battery, or the film may already be rewound.
You can insert new power (battery) without affecting the film cassette, if need be.
However, if really unsure, then:
1) Slide the rewind button to rewind(i.e. to the left).
2) Familiarise yourself with where the back opening latch is.
3) Go into a pitch black room. Preferably under a quilt in a pitch black room.
4) Open the back and take out the cassette. If it comes freely, its probably fully rewound. If its still attached to the take-up spool by film, then (holding the film by the edge only) pull on the film to release it slowly from the take up spool. Whilst it can be quite a tug, they are designed to let go of it "under protest". (Do not pull it so hard that you strip the gears, but fairly firmly).
5) Using the spool winder on the top of the cassette, wind the trailing film back into the cannister. If you've never seen a 35mm cassette, then in the dark one end has an elevated round part, the other end has a void into the cassette. You can tell the elevated part, and start winding - it should only wind one way and feel like its winding onto the reel (wind the other way and it feels like its unwinding - even in the dark!)
6) Only when you are sure film is in the cannister, can you turn on the light.
Films are very sensitive to light, so if you do not feel comfortable doing this procedure in total darkness, go to a photo processing store who will do this for you, usually for no charge (other than the hope you'll let them process the film). They put your camera in a sort of black pillowslip, but the procedure is the same.
Hope this helps
Jan 20, 2010 | Olympus SuperZoom 700BF Film Camera
How do you put the film in in a olympus superzoom 105g
Open the back, gently blow out any dust that might have gotten in there. Load film in the shade. Take the film cassette out of the plastic container and insert it with the protruding piece on the bottom into the left side of the film compartment. Gently pull the film out to the right about 3-4 inches. Try to keep the film flat across the shutter opening but Be Careful you don't touch the Shutter Blades! Feed the film under the take-up spindle and through the vertical slot and hook the film into a sprocket. Push down the shutter release button and advance the film a couple times. Close the camera back securely. You are ready to go! Good luck
Aug 03, 2009 | Photography
I can't get my fuji discovery 1000 zoom to read film
A camera is for recording images onto film, not reading the film.
Jul 18, 2017 | Fuji Discovery 1000 35mm Point and Shoot...
Evoca 115 stopped working after 22 shots
I think you have run out of film. 22 panoramic shots is the equivalent of at least 35 regular shots. Did you open the camera in a darkroom because if not you might of ruined the film. You need to try rewinding the film putting in a fresh roll and I think it should work. Hope this Helps.
Nov 22, 2008 | Samsung Evoca 115 35mm Point and Shoot...
Can't take pictures with my camera
If it's showing an "E", then the film is not uptaking properly, even though it may be advancing. Try reloading the film, or, if for example you're shooting Fuji film, try switching to Kodak, or another brand. Mine will show an "E" for Fuji alomost consistently, but not with Kodak.
Dec 30, 2007 | Olympus SuperZoom 115 QD 35mm Point and...
I have and n2 fault code showing on my display
I think you're losing power. Try flipping out the battery.
Oct 26, 2007 | Olympus SuperZoom 115 QD 35mm Point and...
Olympus SuperZoom 115 QD 35mm Point and Shoot Camera Logo
141 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
