Question about Kenmore 24032\24036 Top Load Washer
Kenmore 92274100 washer leaves lint on everything
Our washer leaves lint on all loads, even though it looks like it spins normally. I've checked for blockage and that the transmission works properly and I'm still stumped. Is there a lint trap that I'm missing? If there is, it is probably full. Any insight would be greatly appreciated.
  • shaddad Jan 04, 2009
    I have a Kenmore 11026902691 with the exact problem, It seems to be going through the cycles ok, but all clothes come out with lint all over the clothes, especially on dark color clothes, we've had this machine for about 6 years without any problems, just the past several months it's getting worst.
  • 198 Answers
Be sure to use higher water level on machine, don't overload machine Seperate lint givers from lint attractors. There is a lint catcher mounted on the bottom of the spin basket but it is self cleaning.
Posted on Jan 05, 2009
Diagnostics ok but only spins slow
Water pump screen is plugged. Will not drain properly even though it goes into high spin.
Mar 14, 2014 | Kenmore HE3T Washer
Washer (total care system) is making a humming noise even though I've taken all the clothes out of it. The agitator works, but there's a humming noise. I've stopped it and re-started it, but...
Hi
1 of 2 things could be the trouble.
Does the washer drain properly if you manually turn the control knob? If not then this sounds like your pump is either plugged with possible lint and can't move or has died completely. 99% chance pump is the problem and 99% chance it can be an easy fix by cleaning the pump where the Drain Line is attached, worst case scenario pump is to be replaced, but not a overall expensive fix and most can do it without a technician.
Second problem is possibly the time itself, but if the washer is going through all cycles except spin then pump is likely the culprit, cause in spin cycle the machine has to drain the water from the unit as it spins, if it cannot the washing machine basically stops and cannot complete the cycle.
One way to tell for sure if the pump is the problem. When the machine enters the spin cycle and starts making that noise. Manually turn the dial a little bit till it passes the spin cycle, if it continues to wash till it hits the final spin/drain cycle then stops again...your pump is in need of help.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 04, 2011 | Kenmore 24032\24036 Top Load Washer
Our Kenmore 92274100 washer will not turn.It makes
Yes it sounds like a belt. You have made a good diagnosis. Belt are inexspensive, but can be a pain in the rear to install.
You doing the work or someone else??? If it's you then probably fix it. If youare calling in service, then get a price before the person comes and decide if it's worth it.
Also if you are doing it you can find the part online easily.
Do a search for "appliance parts" and then enter your model number in one of the websites.
They will have exploded doagrams so you can see how the belt goes and also a parts menu.
Becareful and check pricing on a number of sites as the prices can vary greatly.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 03, 2009 | Kenmore 24032\24036 Top Load Washer
Wet clothes
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
Apr 19, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer spin cycle doesn't leave clothes dry
SOUNDS LIKE THE TRANSMISSION IS NOT ALWAYS SHIFTING INTO HIGH SPEED MODE,TRY A MED. SIZE LOAD AND SEE WHAT THAT DOES,TRANSMISSION MIGHT JUST BE GETTING OLD WHIH IS NORMAL-MIKE
Dec 06, 2008 | Roper RAB2121KW Top Load Washer
Kemore 92274100 washer
counter weight spring hooks in hole left side of rear spring bracket thens hooks through directly below that in base..unless hole is rusted out then just drill a new one ..by the way some wobble is normal a stationary tub would cause a lot more vibration
Aug 19, 2008 | Kenmore 24032\24036 Top Load Washer
Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Jun 29, 2006 | Kenmore 43042 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
409 people viewed this question
Sal De
fordexpert
Robert Rankin
