Question about Tomtom ONE 3rd Edition GPS
Installing tom tom on windshield of car.
Does the ring around the speaker disengage. I don't want to break it.
    Problem Solver:
  • 9 Answers
Just pull one side of the unit and it will pop off.
Posted on Jan 01, 2009
My 2003 Chevrolet cavalier drivers side tire is ssmoking and water dripping in side my front passenger side what do this mean
I\'ll treat the 2 problems separately, then as a unit. 1) Smoking tire. You have a really bad out of aligned tire. It scrubs the pavement and starts smoking. Have your rim and suspension on the corner checked at a quality shop. 2) Water inside passenger side. Do you smell antifreeze? This means your heater core or the hoses to it are leaking. If it\'s plain water and only leaks when raining your windshield seal is gone or the seal around your door. There is also spot and parts at the firewall where stuff can break and allow water t splash in. Now together. It sounds as though someone (you or someone else) drove your little car and "curbed" it really bad and has done significant damage to the front suspension and probably "racked" the body which would break the windshield seal. That is why I don\'t loan my car to anyone. The one and only time I did got broadsided. This was in 1973.
Jul 27, 2014 | Cars & Trucks
I need to replace the gas bubble on a McCulloch Power Mac model 600032-54.....32cc i don't want to break the plastic ring around the bottom that holds it.. Thanks
If its a remote primer, it is sold as an assembly and just clips into the tank, if it is on the carb itself it will be retained by the metering cove of the carb held with four screws.
Jun 20, 2012 | McCulloch Garden
Warn hubs, installation
Warn Hubs Installation
A truck or SUV with a four-wheel drive suspension uses locking hubs on the front wheels to engage or disengage the front axle shafts from the hubs. This way, you can drive the truck normally with just rear-wheel drive, or engage four-wheel drive mode when you want to drive off-road. These hubs can wear out, and one improvement is to install a set of Warn hubs. Installing a set of Warn hubs takes about an hour.
1.Park the truck and put on the parking brake. Lift the front of the truck with the jack and put the jack stands under the front axle. Take off the front wheels with the tire iron and put them to the side.
2.Disengage the locking hubs using your hands by turning the knob on the hubs. Remove the snap rings holding the hub locks in place with the snap-ring pliers. Pull the hub off the axle.
3.Install the lock ring wheel from the Warn hub kit in the axle with the factory snap ring and the snap-ring pliers.
4.Make sure the Warn locking cap dial is turned to the "Free' position. Install the locking cap onto the lock ring wheel and hub body with a hex-head key. Reinstall the front wheels with the tire iron and lower the vehicle off the jack stands with the jack.
Thank you for using FixYa. Hope this will help your problem and don't forget to rate me.thanks,
Reymond
Oct 18, 2011 | Cars & Trucks
I don't know how to change the head light on my 1997 Jeep grand Cherokee. there doesn't seem to be any screws to loosen the light.
Hi Clint,
I just want you to know that you are not crazy or blind!
The reason you cannot find any screws is because you are dealing with a snap-together vehicle.
If you only want to replace the bulb, you can reach around the radiator support and twist the bulb retainer to remove it and the bulb. If you are wanting to replace the ENTIRE headlamp assembly, follow the instructions below.
REMOVAL
Grasp lower edge of headlamp lens and pull straight back (away) from Grille Opening Reinforcement (GOR) . Disengage lower adjuster pivots from lens assembly.
Grasp upper edge of headlamp lens. Pull straight back (away) from grille opening reinforcement (GOR). Disengage upper adjuster pivot from lens assembly.
Rotate bulb lock ring counter clockwise. and remove ring and bulb from lens.
INSTALLATION
Replace by seating the assembly in the lamp housing and turning the lock ring 1/8 turn clockwise to secure.
Align upper adjust pivot into headlamp opening and snap into place.
Snap lower adjuster pivots into place.
Oct 16, 2011 | 1997 Jeep Grand Cherokee
Replace front speakers
You would have to open the door panel to replace front speakers. Look for any screws around the door handle. look at the whole door panel for any screws so that you may remove the panel in order to reach the speakers. once the panel is free from any visible screws, use a door panel remover ($5-10) and use it to pry off the panel, use it around the door panel push-in connectors, and don't use extreme force, may break connectors. once the connectors around the whole panel are removed. make sure your window is down before the whole procedure. then pick up the panel from the bottom (push up), then the panel should be off the door, if you want to change the speakers, you don't need to take any of the wiring to the window/door lock. simply remove the cover if any over the stock speakers, usually some screws. once the cover/screws are off. the speaker should come off. You will see two wires off the speakers (the red(positive) the black(negative)), once the stock speaker is removed, simply attatch the new speaker to the wires. make sure the negative and positive from the car DO NOT TOUCH, you WILL short circuit and blow a fuse, maybe worse, and it's not worth the time fixing. hope this helps, good luck.
Jun 12, 2011 | 2004 Volkswagen Beetle
How do I change wiper blades 2001 Chevy blazer
Open the cap at the end of the windshield wiper arm at the cowl of the Blazer. This will reveal the bolt that secures the wiper arm to the wiper linkage.
Unbolt the wiper arm using a 3/8-inch ratchet and socket. Place the bolt to the side, as you will reuse it later.
Pull the wiper arm up at the blade so that the blade of the wiper is pointing into the air. Then pull at the base of the arm, wiggling it slightly. It's a keyed gear, so it may take a little bit of workunderlined.png?1 to break it free, but with the right amount of wiggling, it will disengage.
Read more: How to Remove Chevy Blazer Windshield Wipers ' eHow.com http://www.ehow.com/how_6177302_remove-chevy-blazer-windshield-wipers.html#ixzz1B4pQJ39h
  • 3 Pull the wiper arm up at the blade so that the blade of the wiper is pointing into the air. Then pull at the base of the arm, wiggling it slightly. It's a keyed gear, so it may take a little bit of workunderlined.png?1 to break it free, but with the right amount of wiggling, it will disengage.
  • Read more: How to Remove Chevy Blazer Windshield Wipers ' eHow.com http://www.ehow.com/how_6177302_remove-chevy-blazer-windshield-wipers.html#ixzz1B4pJlPaV
  • 2 Unbolt the wiper arm using a 3/8-inch ratchet and socket. Place the bolt to the side, as you will reuse it later.
  • Read more: How to Remove Chevy Blazer Windshield Wipers ' eHow.com http://www.ehow.com/how_6177302_remove-chevy-blazer-windshield-wipers.html#ixzz1B4p1UYyB
    Jan 15, 2011 | 2001 Chevrolet Blazer
    How do I install the tomtom in my car. It cam with a big round disk with adhesive on back that I assume goes on dash or window.. But ho do I mount the tom tom to that disk? The modle did not come with...
    Some TOMTOM have the EasyFold attachment: It has a large ring that you push against the back of the GPS while twisting it a bit. In some TT GPS, notably the GO series, the windshield or dashboard attachment ends in a rectangular shaped piece that slides on the back where the speaker is located.
    Dec 31, 2009 | Tomtom GPS
    Tom Tom sound only works after 30 minutes
    The reason for your Tom-tom V2 not to have sound is due to a bad connection to the speaker. I am sure you have tried to reset the set. If yes please try to do the bellow mentioned steps.
    Now it’s risky to take the back off as it is easy to damage screw poles if screws are tight. There is no guarantee that the problem will be fixed by tapping it with the back off, you can tap the back of the case where the speaker is anyway.
    Lots of tom-toms have sound problems and it’s the cheap and nasty speakers they put in them in the first place.
    Better to take it to a service centre and if its warranty make a claim
    You need to unscrew 4 torx crews and pop out the back cover slowly. Remove the speaker's wire connector and check speaker resistance 3-4 ohm. Next reattach connector firmly and did a speaker test in volume preferences menu
    Thank You for using Fixya.com
    Jul 27, 2009 | Tomtom ONE GPS Receiver
    Tom Tom One XL Repair Center???
    The cost of having a new motherboard fitted exceeds the cost of a new GPS. Try one of the new Altinas 8010a . Marbella Australia have them on their site and will send to USA quite cheaply they are excellent and quite robust.and the exchange $ has never been better
    Jul 25, 2009 | Tomtom GO GPS Receiver
    Tom Tom GPS X ONe
    Any shop that specializes in installing car audio equipment should be able to hard wire the unit to the car's electrical system. Be sure you choose a reputable shop. But be aware - hard wiring may make it possible to see that you have a GPS unit (visible wiring, etc.) and they are very popular items to steal. If a thief were to see any sign you own one, they may break into the vehicle looking for the unit, even if you have taken the unit itself with you. Good luck.
    Apr 14, 2008 | Tomtom ONE GPS Receiver
    Tomtom ONE 3rd Edition GPS Logo
    Top Tomtom GPS Experts
    LP
    Martin Murray
    Are you a Tomtom GPS Expert? Answer questions, earn points and help others
