Question about HP Officejet Pro L7680 All-In-One Printer
My printer print in reverse letter
I may press something without knowing it, that cause our all in one printer in reverse letter,I can't read it on the front but on the back of the paper printed i can read
    Master:
  • 461 Answers
Check the printer preferences for the "Mirror Image" option and un-check it - this is used for printing Iron-on transfers for T-Shirts.
Posted on Jan 04, 2009
My Epson, when printing from my laptop, prints the long way across on the paper, not the usual when reading a letter. Not sure what I did to cause this or a mind of its own!!
It is nothing to do with your printer but the printer settings on your laptop next time you go to print something open the preferences tab & change the settings from landscape to portrait , save these changes, press apply & this should solve your problem
Nov 11, 2014 | Epson Office Equipment & Supplies
How to solve the pc load letter in konica Minolta Printers & copiers?
Is this what it's reporting on its display panel when you try to print? Most likely the paper stop in the drawer has moved or been changed to something other than letter; so the printer thinks it has something other than letter size loaded (probably got moved to A5) The printer "reads" the the drawer stops, it does not "see" the paper it needs.
Oct 04, 2013 | Konica Minolta Office Equipment & Supplies
It is printing very small...too small to read without a magnifyer. How do I restore the orginal size font?
Set the font number on your favorite text editing program to something legible, for example, in Word, a size from 5 to 10 is normal letter.
If letter stills going little on printer, then take it for repair.
Dec 03, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Printing letters from the computer to a iron on
You don't. Once you have completed your design including the text as it should read when the T Shirt is finished you go to print the design. When the printer dialogue appears then you Click Preferences, Properties, Options, or Setup (depending on the program or operating system) then choose the paper type as the T-Shirt Transfer option if you have one setup so that the print image will automatically be reversed when printed, or you choose an option to flip the image horizontally, or print reverse.
Oct 21, 2009 | Dell 924 All-in-One InkJet Printer
My hp desktop will not operate. It reports a message that I have a paper Jam. I have checked the printer as advised and there is no paper inside. I have also conducted all recommended shut down and...
You need to clean NVRAM on Lexmark X5470 printer. Please follow the steps given below to clear NVRAM on Lexmark X5470 printer:
1. Turn the printer off.
2. Hold down "#5" button and turn the printer back on.
3. Keep holding "#5" button for about 5-10 seconds.
4. Press "Menu" button once.
5. Press the right arrow until display shows "Tools."
6. Press "Check" button once.
7. Press the "Right" arrow button again until display shows "Maintenance."
8. Press "Check" button again.
9. Press the "Right" arrow button again until display shows "Manufacturing."
10. Press "Check" button again.
11. Press "Right" arrow until display shows "Clean NVRAM."
12. Press "Check" button to clear nvram.
Next, try this printer self-test by following the steps given below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
May 02, 2009 | Lexmark X5470 All-In-One InkJet Printer
Jagged edges and misregistration
What printer is it ? Some older ones need manual calibration, where patterns are printed, then you tell the system which is the best one. Newer ones can self calibrate, but still need it done. Go into your printers menu and see if you can find something on calibration or allignment.
Jul 18, 2017 | Konica Minolta bizhub 350 All-In-One Laser...
Having to press paperfeed then enter to print
most likely the paper settings are wrong. it should be set to letter and plain.
go to the menu and look for paper settings
Oct 07, 2008 | Ricoh Aficio AP410N Laser Printer
Will not print with giving an error message
on left side of tray are 3 fingers, for letter size paper bottom 2 are out, next one in. verify slider on bottom of tray is in place. Essentially paper not sensed correctly. print config page and see paper size
Jul 03, 2008 | Lexmark T640 Laser Printer
Check is upside down but printer refuses it
I fail to see how the printer knows which way it's facing?? there is no sensor on any printer that I know of that can do that. The only way is if there is a setting in the printer or the pc that is incorrect.I need more info, is the check the same size as the a letter size paper, does it try to pick up and stalls???? please give more details.
Oct 04, 2007 | HP Photosmart 3310 Printer
HP Officejet Pro L7680 All-In-One Printer Logo
783 people viewed this question
Ben Johnson
