Question about Lexmark X5470 All-In-One InkJet Printer
Printer not communicating with computer
It's been printing fine and then it just quits and gives me the message, Problem with printer communicating with computer. I've unplugged and replugged everything, shut it down and it still will not print!!!
    Scholar:
  • 107 Answers
(1) Try a power cycle: Try turning the printer off, then unplug the power supply from the printer, then unplug the USB cable from the printer then the back of the computer; wait 30 second; then plug the USB cable back into the computer, then back into the printer then plug the power supply back into the printer and turn it on – run a test print: Start>Settings>Printers>Right-click on the printer>Properties>Print Test Page
(2) Update the USB drivers
Posted on Jan 03, 2009
My Lexmark 2400 series quit printing - error message says cannot communicate with printer/computer. It's worked like a beast and i love this printer. I am still using Windows XP. I've checked my USB...
try plugging the usb cable into another computer, load the printer driver onto that computer and try to print to the printer, that will tell you if it is a printer or computer problem.
Nov 02, 2013 | Lexmark X2350 All-In-One InkJet Printer
Printer does not communicate with computer.
your problem must be not selecting the right printer...
find your printer in that drop down menu (i.e: in my pc is the 692c) and then accept everything else..ffe6acd.gif
Dec 27, 2007 | Lexmark X2550 All-In-One Printer
My Lexmark Platinum PRO905 does ot print it gives me the message " Communication Not Available, The Printer cannot communicate with the computer"
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if usb-connected), reboot your computer and unplug/replug your printer into the power source to reset it. When the printer turns on, reconnect the printer into the computer. Try to print again.
You may also refer to this article (for Wi-Fi connection issues): How to identify a Wireless Communication Problem and Resolution Tips
Aug 09, 2011 | Lexmark Platinum Pro905 multifunction...
I have two computers and both have the proper drivers downloaded. For some reason my laptop will not communicate with the printer. I get an error when I try to print and when I try to print a test page...
This seems to be a problem with a lot of laptops, I get it too. How to fix this is quite simple.
Go to your control panel on laptop. Look for Hardware and sound then click on View Devices and printers.
You should see a list of said devices and printers. See if you have the printer listed twice.
If you do , you must delete one. The one to delete is the non default printer. This should cure the problem.
Hope this helps
Mar 27, 2011 | HP Photosmart C5180 All-In-One InkJet...
Printer error
Here a few common problems that your Epson printer and ink cartridge can suffer from.
Improper Installation of Cartridges
A common Epson printer and ink cartridge problem! If you have changed the ink cartridges then you might just receive this error message. The message might state that the cartridge is not installed correctly in the printers. In such cases, re-install the cartridge in the correct manner. If the problem persists then it is advisable that you replace the cartridge as it might be defective. If you still get the same error message on installation of the replacement cartridge then its time that you clean the print head. You could do this yourself or could take it to a repair facility.
Printing Failure
Failure to print documents is yet another common problem with respect to Epson printers. The print heads of Epson printers are sensitive and this sensitiveness is the culprit behind such problems. If the print head is clogged or blocked you will have to unclog or unblock them. This can be done by using a special fluid that is available for just this purpose only. This fluid flushes the print head, and your printer is once again ready to print.
Communication Error
'Communication Problems' are yet another one of the common problems surrounding Epson printers. Once you give the print command you might be shown the message that there is a communication error between the printer and the computer. This means that there is the occurrence of a minor problem. One of the reasons for this problem could be the inappropriate selection of printers from the print options menu. Cable connections should also be checked. Another solution could be the re-installation of the driver of the printer.
Print Jobs that are Slow or Incomplete
These are problems that occur during an ongoing process. The printing might stop midway and then start again after some time. At times, the printing process will repeat itself several times and then finish printing the page. There are times when the page will finish printing, but you will find that it is an incomplete print. More often than not, this is not a printer related problem.
What might have happened is that the driver might have corrupted or a virus might have infected the computer; or a spyware might be affecting the working of the printing process. If such a problem occurs, the best solution would be to scan the computer for viruses and spyware. As can be seen these common Epson printers and Epson ink cartridge problems can be sorted out quite easily.
hope it helps..
Thanks for using fixya...
Dec 04, 2010 | Epson Office Equipment & Supplies
Printer wont print after ink cartridge change
Hi pater_g:
Have you tried to reinstall the old cartidge to see if it would give a different problem ( light print ect.) if not try that. If the problem stays and you just can't communicate with the printer try rebooting you computer or go to www.hp.com/support to download a new print driver. I hope this helps you.
Apr 17, 2009 | HP LaserJet 1320n Printer
Epson dx3800 stopped printing. I get a communication error message. All cables etc checked, scanner works and printer will print scanned article when not connected to computer. Seems files cannot be...
To get over this problem, First uninstall your printer and reboot your computer and again install the driver of printer and if the problem persist then consult Epson Printer Support team and get connected with the expert technicians of the customer service by just dialing 1-800-243-0019(toll free) and get your issue resolved in a short span of time.
Sep 02, 2017 | Epson Office Equipment & Supplies
All in One Scanner/Printer problems
Go to this link and type "cannot communicate with scanner" in the search box. Click Search. Then select the "ERROR: Cannot communicate with scanner" link. You will see several things to try to correct your problem. Usually, this error shows up if there is another USB device connected which prevents the computer from "seeing" the scanner, even though it can print without problem. So do try to disconnect any other USB device (except mouse or keyboard) and reboot the system.
May 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Printing e mail
When you click on the Print button located in File, a dialog will open asking to you to choose your printer. Make sure to select your printer (Lexmark E238) in the printer name field.
Let me know if it works.
Feb 06, 2008 | Lexmark E238 Laser Printer
Cannot print
i rebooted my computor and now my printer wont work i dont have the download disc that it came with so when i try to print it says error 20 not activated
Oct 02, 2007 | Brother DCP-7040 Laser Printer
Lexmark X5470 All-In-One InkJet Printer Logo
74 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
