Question about Sewing Machines
My machine will not pick up the bobbin theread
I have tried eveythin I can think of and I can't get it to work....HELP!!!!!
  • Anne Jan 03, 2009
    my janome 10001 is doing the same thing-timing is off -need know how to adjust the timing-you can also try changing the needle
Have you tried taking off the pressure plate, cleaning under it and then put it back. sometimes if the pressure plate is not lined up properly it wont pick up the thread
Posted on Jan 07, 2009
Does any one know anything about a sewing machine model 217-APP no 457. Think it may be a singer, have just found it in late mother-in-laws shed. It won't pick up the bobbin thread but runs ok
not picking up the bobbin thread is an indication of needle / hook timing
thread tension problems appear as a mess of stitches under the cloth
the timing can be checked by having the needle full down and the hook of the bobbin case should be at the needle just above the eye of the needle
if it is too early or late then it is not in position to get the thread
May 13, 2015 | Sewing Machines
I just received a new Singer CG-590. Have threaded the machine and bobbin. Each time I try to pick up the bobbin thread, the top thread wraps around the bobbin case. It will not pick up the bobbin...
try turning the bobbin the opposite way, and if that doesn't help then take the machine back and get another one, maybe even a different model
Dec 26, 2013 | Singer Sewing Machines
Juki ddl 8700 my machine was sewing fine I put in a heavier (jean) thread. Now it wont pick up the bobbin thread to sew at all? Help?
try changing the needle to one that will work with heavier thread
you may have to change the bobbin to heavier thread also
try adjusting the tension also
Sep 25, 2012 | Juki DDL-8700
How do i set thread tension on a 306W Singer Zig-zag? Bottom thread all loopy.
Top tension about 4 or 5, make sure the presser foot is up when you theread the machine, make sure you can just pull the bobbin thread through with some slight resistence, if it is too tight slacken the screw on the bobbin case a quarter of a turn at a time anti clockwise.
May 05, 2009 | Singer 8280 Mechanical Sewing Machine
Bobbin not picking up through the needle part of the machine
thread only shows the bobbin thread when i sew and needle thread also please e-mail me the attachment instructions. marybellroberts@msn.com
Oct 14, 2008 | Singer 3116 Simple
Brother VX-1120- The needle is not picking up bobbin thread.
I had the same problem with my brother vx-1120 sewing machine. I set the needle to lowest position by using the hand crank. Then I loosened the knerled set screw that holds needle in place. Then I moved needle shaft till the eye of needle is just lower than the hook on the shuttle loop maker. It made my mechine work. There are instuctions for ajusting timing on machine but I think these mechines are built to not fix and throw out. Just because there where no ajustment marks at all on machine, any machanical machine will needed to be ajusted sometime.
Jul 08, 2008 | Brother CS-8150 Computerized Sewing...
My needle won't pick up the bobbin thread
My sewing machine is a Brother LS1217, well actually it is my son's, and he uses it very seldom. I went over to put in a new needle and I cleaned it top and bottom, put in a new bobbin, and a new needle and the needle won't pick up the bottom thread. What am I doing wrong? Please help me!! It has to be something simple, as this is such a simple machine! roseandjimmy@yahoo.com
Jan 11, 2008 | Brother LS-1217 Mechanical Sewing Machine
Machine wont pick up bobbin thread
needle won't pick up thread I think the timing is off, how do I retime it?
Aug 25, 2007 | Kenmore Drop-In Bobbin 16231 Mechanical...
Sewing Machines Logo
125 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
