Question about Philips 43PP9202 43" Rear Projection Television
Color convergence on our Phillips 46999302/17F
We have a blue "shadow" in the bottom left and a yellow one in the upper right corner of our television. We attempted to use the color convergence from the remote with no luck.
  • Anonymous Jan 19, 2009
    orange screen
  • Philips Master
  • 3,459 Answers
If you are not able to adjust the convergence using the remote you need to replace the convergence chips.
Typical Symptoms
1) Convergence menu does not work for one or more colors.
Example: RED moves up,down, but left or right fails.
2) Screen is bowed looking.
If you have one or more of the problems above you need to replace the convergence chips. You can get a kit and instructions from www.TvRepairKits.com
Posted on Jan 11, 2009
Convergence
did u do a repair in recent days
by replacing the convergence ICs?
Jun 18, 2008 | Toshiba 43A10 43" Rear Projection...
Philips Blue Shadowing
If you have not already done so go into the picture menu and set the convergence. The convergence is the angle at which the three picture tubes meat at a given distance. The tv will have at least 3 and up to 64 convergence points, and those 64 can be set for all three colors. This can be tiresome but I'll be it will solve your problem. What your trying to do is get the color in the cross-hair so you cannot see the color behind the target. On top of the fine setting for each point and color you will probably have 3 gross adujustments for blue and green and maybe red. These adjustments will affect positioning, like what you are discribing. You should do this at least every month, the thermal cycleing of the lamps is what will cause this to creep out of adjustment.
Sep 25, 2008 | Philips Magnavox 9P6034C 60" Rear...
Shadow issues
You need to replace both convergence ICs they are both STK392-110 you can get replacement ICs at the following link with free instalation Instructions with pictures. Here is the link.
http://servicemanuals.vstore.ca/
Jul 09, 2008 | Philips 50P8341 50" Rear Projection...
Hitachi53SDX89B color problem
Blue convergence IC bad...have both IC's changed..insist on
STK394-160E upgrade part # CZ 01341 Hitachi brand.....Original part is STK392-110......Also, check B+ feed resistors next to
convergence amp IC's for burn / damage...after rebuild, press magic focus.......................T.
Dec 21, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Blue Convergence just went out?
High Voltage Capacitor? Leave the set unplugged for 1/2 hour most components will selfdischarge, as for your problem, being a Magnavox, you have one of two problems, the convergence I suspect is what is blown out, this unit probably uses STK392-110 Ic's, I would suggest replacing with STK394-160e chips as they are probably shorted, some of the big resistors (1 or 2) may be opened up also, usually they change color. The only other thing that would cause usually a yellow color in the corners is the CRT Fluid, it changes from clear to Orange in color and clamps off the blue color from the fringes, I suspect the chips need replacement, dont forget to put some heatsink dope behind them, they are usually on the left in the front of the set (from the back) Big long heatsink that is fairly tall (probably the biggest heatsink in the set.) Good luck, and the repair usually runs around $350.
Jul 13, 2007 | Philips Magnavox 51MP392H Rear Projection...
Blue/Yellow in upper left corner
I have the same problem and now there is convergence problem with the entire screen, double images and ghosting ...i was told that some IC's are burned our ...etc..i'm waiting to see if they sell the entire board since the TV's are 10 years old... will let U know what i get as a response.
Jun 05, 2007 | Hitachi 50UX26B/27K 50" Rear Projection...
Philips 43PP9202 43" Rear Projection Television Logo
76 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
