Question about Maytag MGS5870 Gas Kitchen Range
How to remove the electronic control section of Maytag MGS5870?
I tried to remove the electronic control section but I don't know how to take off the top portion of the range? Is there a service manual that will show me what I need to do this? Model Maytag MGS5870ADW. Thanks for any help or advise you can give me.
jsrock516
  • 5911 Answers
SOURCE: I dont know the Maytag model - but is has a CERAN top
There are a few screws located under the front edge of the top. You will need to open the oven door to see them. Remove these screws and the top should lift up. Make sure you unplug the range or turn off the main breaker BEFORE servicing. There are still live voltages present with the range turned off. There are a couple of screws holding the element in place, as well as some wires. Make sure you write down how the wires were connected to assist you in reconnecting them in the right order. Make sure you also take note of the numbering scheme on the element and make sure you place the mounting brackets in the same holes that they came out of on the old element. Last of all, make sure you handle the new element carefully. Care must be used not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure. Good luck and I hope this helps.
Posted on Sep 08, 2007
  • 218 Answers
SOURCE: Need manual
Thanks to an earlier solution by huuum, here's a link to the manual.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/8113p293.pdf
Posted on Nov 17, 2008
jumptrout51
  • 3361 Answers
SOURCE: How do I remove the top on a Maytag range
Unplug the range from power.
Open the oven door. Look on the right and left sides of the oven frame just below the top. Remove the 2 screws. Pull the top forward. Remove the wiring harness connector at the back.Lift the top up and off. Set the top aside.
Posted on Nov 11, 2009
  • 906 Answers
SOURCE: Maytag MER5770AAB smooth surface range infinte switch has failed
good day,
hope this link below will solve your problem.
kitchen appliances
Posted on Jul 31, 2010
heatman101
  • 43501 Answers
SOURCE: I ahve a maytag mgs5870
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Sep 07, 2010
I brought a maytag steam clean with electronic controls. What is happening is that all the controls are working except for the start button. No matter how hard or gently we push the start button it will...
THE PROBLEM IS WITH THE SWITCH ITSELF AND REQUIRES SERVICING . WHY NOT CHECK IF THE MACHINE IS STILL UNDER WARRANTY .AS IT IS A ELECTRONIC CONTROL IT MIGHT COST YOU A BIT.
REGARDS.
PLZ. DON'T FORGET TO RATE
Jul 05, 2011 | Maytag Dishwashers
Stove won't light, gas is not getting through
the valves could be bad. since you did not give much detail i'd go with this: the valves could be bad. have the ones involved replaced by a quilified repairman.
May 08, 2011 | Maytag MGS5870 Gas Kitchen Range
I ahve a maytag mgs5870 adc. Oven will light then go off and on.
heatman101
Sep 05, 2010 | Maytag MGS5870 Gas Kitchen Range
Where is defrost timer in maytag MSD2756GEQ SxS
Inside the refrig section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and foreward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrig's , a white box will be seen. Inside this box , is the adaptive defrost control
Jun 13, 2010 | Maytag MSD2758G Side by Side Refrigerator
No gas to oven
The gas will not go on in the oven unless the ignitor is working as it should.
Remove the bottom panel of the oven so you can see the burner tube. Turn on the oven and watch the ignitor. When the ignitor starts to glow it should get a really bright almost hard to look at glow. If it just turns red then it is not pulling the correct amperage to let the valve know to release the gas.
Replace the ignitor and you should be good to go!
Apr 03, 2010 | Maytag MGS5870 Gas Kitchen Range
Maytag Range Model MGR5870 how to convert to propane
set the regulator to propane and change the orfices to the blk ones. copper is for nat gas / black for propane .. thanks hope this helped .mm
Dec 22, 2009 | Maytag MGS5870 Gas Kitchen Range
NoT A GOOD SEAL ON THE DOORS
check the light switch itself
check the door switch
Oct 03, 2009 | Maytag MGS5870 Gas Kitchen Range
Maytag mgr5765dqd temperature problems
Unfortunately, Maytag is now a division of Whirlpool, just one of many. I don't know your range but if it does not have electronic controls, the adjustment is located within the shaft of the oven temperature setting knob. The slotted screw is fairly deep in the shaft and you will need a small flat-blade screw driver with a slim and long blade. If the oven has control electronics, this adjustment will be located on the main board with the rest of the controls and this is normally located in the upright top section of the range.
May 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
OVEN NEVER REACHES TEMPERATURE SETTING
I read my wonderful "user's guide". In the section, Controls at a Glance, I found OVEN TEMPERATURE ADJUSTMENT OPTION & followed 5 easy sets. It worked!!!
Nov 11, 2008 | Maytag MGS5870 Gas Kitchen Range
Oven burner doesn't light
If memory serves me,there are a couple of screws on oven floor.Remove panel.Sounds like ignitor is the culprit.It feeds back to control.It may glow and light but unless it is sending full signal,gas valve will not open fully and oven will take forever to heat.
Jan 01, 2007 | Maytag MGS5870 Gas Kitchen Range
Maytag MGS5870 Gas Kitchen Range Logo
93 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
