Question about Grindmaster 100 Electric Burr Grinder
Replace burrs? I have a grindmaster 100 series and I need to know what a new set off burrs looks like. I think mine may need replacing because when I ajust them they seem to be touching but the grind it still to big.
    Novelist:
  • 137 Answers
Here is solution how to to replace and order burs from producer. also you have diagram for opening and closing the grinder.
http://www.grindmaster.com/literature/operatorsmanual/GR-373-04%20115_250%20Manual.pdf
Posted on Mar 29, 2009
I have a "Brother CE5500PRW" machine. I have
1 - Make 100% sure you are threading the top thread correctly.
2 - Make sure your top tension is set at 5.
3 - Look in your book and make sure you have the black plastic bobbin case inserted 100% correctly.
4 - Remove the black plastic bobbin case and inspect it for burrs or needle damage, if so it needs to be replaced.
Oct 02, 2014 | Sewing Machines
Think question cut off. Need to know how to remove "screw" in back to clean burrs. It is not a phillips head, maybe rivet.
there are a number of 'newer' drive configurations for modern fasteners specifically designed to limit consumers from doing their own servicing. Take the unit to your local tool dealer and get the proper tool. If it actually is a rivet, it will need to be drilled out and then replaced with a new one.
Jul 03, 2014 | KitchenAid A-9 Electric Burr Grinder
I have a Grindmaster model 805 coffee grinder. It worked flawlessly for many years, then suddenly stopped. I took it in to a repair facility and was told the switch had died. I had another machine at...
Most grinders, especially the larger professional models will eventually need to have the grinding wheels (set of 2) changed out. They do wear down. The grinder will struggle as the burrs on the wheel dull out. This increases the time it takes to grind coffee and puts a heavy electrical load. Burnt out switches, tripping breaker, overheating, and burnt coffee grounds on espresso size are all symptoms of a worn burr set.
It's common to find; stones, nails, jewelry, and small loose things found around coffee counters in the grinding wheels or burrs. Have a qualified operator remove all beans and hopper to check and brush out burr set. This should be done every day. Talk to your vendor if you find nails as they can easily correct this with a magnetic pick up.
Another cause is very oily beans. Sometimes poorly roasted beans come out extremely oily which will gum up everything from the burrs, Moving parts, and electrical components. Disassembly of entire machines may be necessary.
.Final note; since you mentioned a switch swap. It's possible the switch is underrated for use in this machine. Most will work in a pinch but like a 'spare' tire in a car, they are only ment to get you to a service center for replacement.
Nov 08, 2017 | Grindmaster Coffee Makers & Espresso...
Coffee grinder wont start
Its been a while since i worked on a grind master so have a little patience with me. First, if the breaker went then there might be something blocking the burr chamber like a rock or screw or other obstruction. Second I would check the micro switch for the bag holder if there is one on your model using an ohms meter.
Mar 16, 2012 | Grindmaster 875 Electric Burr Grinder
New head
Hello Brian, You can give the folks at www.electricshaver.com a try. They typically stock all the replacement and repair parts for most brands of electric shavers.
Here's a link to their site where you'll find part #5646768 for about $38 for a new set of the cutter head and foil (screen). It's always best to replace BOTH the foil and cutter block (head) at the same time, as any mircro burrs or nicks in the cutter blades will quickly ruin any new foil screen.
http://www.electricshaverstore.com/get_item_5646768_braun-foil-cutter-kit-360-complete-8000-series.htm
As you know, this is the simplest and easiest way to get an electric shaver back to a "like-new" shaving experience.
I hope you find this Very Helpful and best regards!
Nov 11, 2009 | Health & Beauty
How do i change the burrs on grindmaster 875
Remove the screws on the knob with the grind setting, that pulls out and gives you access to the burrs.
Jul 17, 2009 | Grindmaster 875 Electric Burr Grinder
Replacement part (exit chute)
I have not heard of a solution yet.... but I did download the manuals for the machine and have the parts numbers from different models which MIGHT be interchangeable.... I only paid $150 for the machine, so I am loath to spend too much more to solve my problem.
Might go on ebay...
May 13, 2009 | Grindmaster 810 Electric Burr Grinder
Rocky Calibration
  1. replacement of burrs after 500 kg grinded coffe
  2. if upper burr holder and the body of grinder does not hold stabile, teflon aplying does not help too much, it is only temporary solution. new upper bur holder would do better.
  3. before inserting upper burr holder you should check if lower burr is rotating syncronized, you should take a bit chalk and sof touch while burr rotates. after that you stop grinder and look do you have circle with same thiknes, that would give you idea where is the problem, if it is in lower burr.
Apr 07, 2008 | Rancilio (RAROCKYND) Grinder
Nemox Lux Burr Grinder
There are a series of gears between the motor and the shaft. Replacement parts are avaialble ad cafeparts.com under ascaso ibertal grinders. You will need to take the grinder apart to find the problem.
Dec 16, 2007 | Nemox X79751250 Electric Burr Grinder
Grind
Love your 'handle'!
I'm thinking that there is something in the burr in the unit. Empty the unit and remove the burr. Usually, this is done with a counterclockwise turn. Note how hard it may be to turn...you'll have to reverse this when you put it together. Now, clean out any coffee debris you find. Then, turn the unit over and tap it on a firm surface covered with newspaper. Reassemble and return to service.
Nov 03, 2007 | Grindmaster 810 Electric Burr Grinder
Grindmaster 100 Electric Burr Grinder Logo
218 people viewed this question
Top Grindmaster Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Grindmaster Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
