Question about Microsoft Xbox 360 Console
My xbox 360 will not turn on at all, the power pack has the usual orange/yellow light on but it will not turn on! I have had no prior warning like the lights of death or anything. I would very much appreciate any help on this matter. thanks
  • 5 more comments
  • dee
    dee Jan 03, 2009
    my xbox 360 doesn't come on at all I don't have no red ring of death
  • Anonymous Jan 05, 2009
    its the same with mine
  • Anonymous Jan 13, 2009
    ive got the same problem, the only way my one turns on is if i lift up the power cord at the back of the console and push it into the socket and hold it inplace with something
  • Anonymous Jan 14, 2009
    yes I do
  • jim1916woo Feb 07, 2009
    orange led status light on power pack how can i get it off standby
  • Anonymous Mar 06, 2009
    mine is doin the same thing
  • Anonymous Mar 20, 2009
    same
    Novelist:
  • 174 Answers
This is a similar fault to he dreaded 3rrod, the mainboard warps with the heat generated whilst playing the console and it cracks the lead free solder. what you need to do is something called a reflow, strip down the machine and get the mainboard itself. either use a hot air gun (paint stripper) or something called a reflow station (what i use). you then need to go over every part of the mainboard with the heat for about 5 mins each side paying particular attention to the part of the board near the a/v output. look for something called the ANA chip and put the heat onto this in a circular motion for 20 seconds.
reflow also the gpu and lan areas and you should see some improvement.
we can do all this for you and we also change the x-clamps and use team-xecuter parts. we can get consoles working again for only £40 which includes return delivery to your door.
www.fixmyconsole.co.uk
Posted on Apr 12, 2009
Power supply light stays orange and wont turn on the XBOX PRO. HELP!
I hope this helps The power supply light is orange for one of the following reasons:
  • The console is turned off.
  • The power supply is not plugged into the console or the connection is not tight.
  • The power supply is not functioning properly.
Note An orange light usually indicates that the power supply is connected to electricity and ready to power the console. When you turn on the console, the power supply light should change from orange to green. If your console does not turn on, please see the following Knowledge Base articles: 907588 (http://support.microsoft.com/kb/907588/ ) Your original xbox 360 console will not turn on
2122656 (http://support.microsoft.com/kb/2122656/ ) Your xbox 360 S console will not turn onIf the console will not power on and you have tried the troubleshooting steps in the above article, your power supply will need to be replaced.
Contact xbox Support to obtain a replacement power supply. For information about how to contact xbox Support, visit the following website: www.xbox.com/support/contact (http://www.xbox.com/support/contact)
Jan 04, 2011 | Microsoft Xbox 360 Pro System Console
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
Aug 26, 2010 | Microsoft Xbox 360 Elite Console
No power in console, but light is on ,on the power pack
This is normal. The light will always be on if the power pack is plugged into the wall. There should be no lights lit on the Xbox if the power is turned off, but the power pack will still have an orange light.
May 02, 2010 | Microsoft Xbox 360 Console
My 360 does not have power to console. the light
Have you tried removing all extra accessories?
Xbox.com states:
Mar 01, 2010 | Microsoft Xbox 360 Console
Xbox 360 won't turn on
I had this problem. Make sure the pins in the USB ports (2 on the front and 1 on the back of the console) aren't bent and there's nothing obstructing them. I unbent some of the metal inside these ports, and voila! I have a working xbox.
Oct 09, 2009 | Microsoft Xbox 360 Console
Power brick colour
Alright, lets fix this!
 Xbox 360 power supply light is orange or yellow.
Usually when the Xbox 360 power supply light is orange it's on standby so there is no problem with your Xbox 360 console but the power supply can't supply it with power !
First you have to try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for a minute then reconnect it all back , also try it on another wall outlet without any extension cords at all.
If it's still doing the same it will be definitely a fault with the Xbox 360 power supply.
So, in this case please contact Xbox 360 customer support to fulfill the Xbox 360 power supply.
Xbox 360 power supply light is red.
There is something wrong with the Xbox 360 power supply connection so try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for minute then reconnect it all back , also try it on another wall outlet without any extension cord at all.
If it's still red that would be for sure a fault with the Xbox 360 power supply .
So, then contact Xbox 360 customer support to fulfill your Xbox 360 power supply .
You can also find replacement power cords many places online. See if you can get your hands on another cord and try that to see if its the current power cord.
Hope this helps you out! Please don't forget to rate :)
Apr 10, 2009 | Microsoft Xbox 360 Console
I have a Yellow Led light on power bar, xbox will not turn on
Here ya go! This should help you out, I have also had this happen to me. Don't worry, its nothing like the red circle of death.
http://xbox-360-problems-fix.blogspot.com/2007/11/xbox-indicator-lights.html
Hope this helps you out! Don't forget to rate me :)
Apr 09, 2009 | Microsoft Xbox 360 Console
Won't turn om
Check that the Power Brick that comes with the XBOX 360 has a yellow/orange light. If it is red, then you may be using the wrong voltage or the is a fault in your power supply.
If it is orange, check it is plugged into the back of your Xbox 360. If not, then plug it in at the bottom of the back of your Xbox 360.
If its plugged in and still doesn't turn on, then call Microsoft (US Number is 1-800-4MY-XBOX) and tell them the problem.
Thanks, Venturer
Dec 27, 2008 | Video Game Consoles & Games
Xbox360
Sep 06, 2008 | Microsoft Xbox 360 Console
Xbox 360 red lights power supply light stays yellow
you have to disconnect and reconnect the power cables to the 360. Orange/yellow light means that your power supply is on a standby mode and the 360 is not getting enough power/electricity inside
Mar 04, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
357 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
