Question about Lexicon Omega Pro Studio External Sound System
Interface What do I do when the drivers fail during the installments
  • 661 Answers
Download updated drivers from the manufacturer's website especially if you are using XP / Vista
Posted on Jul 26, 2007
Why did smart card interface failed to install?
ur smart card has no problem, problem have with ur system's USB Drivers , reinstall or update ur system's usb driver ur smart card will easily connect
May 12, 2014 | Sunpak USB 2.0 72-in-1 Card Reader
My printer won't print due to the fact that the troubleshoot says I'm not connected to a computer....but I am. How do I download a new driver to make it work. thanx
Hello Sir, Hi, that is common error with printers today, but this error can be fixed, here are some of the thing you need to do, they may help.
for usb interface. 1. If you are using a USB interface, you need to install first the driver software, along the setup, you will be prompted to power on the printer and plug in the USB cable to your computer and the printer. make your connection here. If the connection fails, do this several times. 2. If the 1. fails try using another USB port.
for centronics parallel printer cable. 1. Make the connection of the printer to the computer before installing the driver software. 2. Power on the printer. 3. Power on the computer and install the driver CD.
If you do not have the driver cd and you did not mention what printer you have. do a Google search, type the printer make and model and search for the driver. download the driver, usually from the manufacturer's website.
Oct 17, 2010 | Computers & Internet
When i attempt to install the driver included with the Tascam 122 interface it says "Your user account must have administrator privleges to install drivers" and I already do have an administrative account.
Boot normally and once you fully logged in, press the [Log Off] button instead of the [Shut Down] button. It will prompt you to log on. Select [Administrator] and go in as the Administrator and not someone who has Administrative privledged.
If that does not work, reboot the computer and press [F8] to get to the boot menu. Select "Safe" boot. Once in the safe boot mode install the device ans Administrator. Some items can not be installed this way but if all else fails, give it a try.
Oct 06, 2010 | Tascam US-122 USB Audio/MIDI Interface...
P62 error code
The IBM 6400 printer uses internal programming software that is specific to the printer based on installed interfaces and graphics options. This software resides in flash memory and when the printer is first powered on the software is executed. During this process it initializes the various processors on the controller board, initializes the optional interface cards, and then loads the necessary operating settings into dram. If the programming software becomes corrupt it will fail during startup, giving you the DC Program not valid error or a number of other error messages. The solution to this is a reflash of the printer. Unfortunately, the flash software is proprietary to IBM and they will not distribute it to anybody. The only way to get the printer reflashed is by calling IBM and having one of their engineers reflash the printer.
Jan 28, 2009 | IBM 6400 Matrix Printer
Dell 1600n printer driver for Windows 2003 Server
I had a similar problem deploying these printers, however i found using the XP drivers in 2003 does work fine. Not sure why dell doesnt have an installer for this printer in 2003 server, but here you go.
ftp://ftp.us.dell.com/printer/R165289.EXE
extract that file, note its destination directory. do not attempt to run the setup.exe, it will fail saying your operating system is not supported.
instead navigate to (if you didnt change the path) C:DelldriversR165289p0nPrinterPCLWINXP
this folder contains the driver you need to install manually.
one stange thing about these lexmark based network printers is the need to select 'local printer' during install, uncheck automatically search for my device, and then create a new TCP/IP port. Use the IP address provided by the network configuration print out you can access on the front panel of the printer. now just make sure to select 'lexmark network card' as the type of network interface. it should now ask you for your printer type, click have disk, and point to the driver folder mentioned earlier.
hope this helps. thanks alot dell.
Oct 30, 2008 | Dell 1600n All-In-One Laser Printer
Acer 5100 PC
Pretty simple. You'll just need to determine whether the system uses SATA or IDE for the hard drive interface. Many machines manufactured in the past couple of years use SATA, but any 2.5" drive will be compatible providing you have the correct interface. ATA drives for laptops are generally called PATA and if it's such an interface any ATA-6 drive will be compatible.
You might need a SATA driver for the Vista installation, so bear that in mind. You'd specify additional drivers during the setup process.
Good luck.
Ben
Sep 17, 2008 | Acer Aspire 5100-3357 Notebook
Sound problem
The message that the installation failed means the drivers did NOT install properly. Uninstall the driver FIRST before trying the installation again. Failure to remove all the sound drivers will insure a failed installation.
Sep 02, 2017 | LaCie d2 Extreme 250GB External with...
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
Installation of JVC USB driver
The JVC USB driver was written before introduction of the Windows XP system. This warning is displayed with other manufacturer’s digital cameras, also, and is not strictly a JVC phenomenon. In order to use the USB interface between the camera and your computer, select the “CONTINUE anyway” option provided in this warning display. To JVC’s knowledge, there are no negative effects to using JVC driver with Windows XP.
Sep 14, 2005 | JVC GC-A33 Digital Camera
Lexicon Omega Pro Studio External Sound System Logo
152 people viewed this question
Top Lexicon Computers & Internet Experts
Tony
Alun Cox
JonSnell Electronic
JonSnell Electronic
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
