Question about Logitech Harmony 890 LCD Remote Control
My Logitech Harmony One remote stopped working last night with the new year.
  • Anonymous Jan 02, 2009
    I ha dmine quit working....says "missing License" then " Battery ADC Not calibrated" would not change after connecting to Logitech website either. what to do?
5 Suggested Answers
SOURCE: Harmony 880 universal remote re-charging problem
For Battery and charging related problems with the Harmony 880 checkout the following very useful post and thread:
http://dan.langille.org/2005/11/27/harmony-880-remote-battery-problems/
Hope this helps folks with a variety of different issues.
Posted on Jan 06, 2008
  • 3 Answers
SOURCE: Need instruction manual for Logitech Harmony 525 remote control
Hi there, You can download the manual at the following location:
http://images.harmonyremote.com/EasyZapper/Downloads/UserManual/525/enu/525_UserManual.pdf
regards,
Craig.
Posted on Nov 27, 2008
SOURCE: Harmony 880 Logitech tv remote - won't change channels on direct tv
If you have an infrared remote and your Direct Tv remote is using an RF signal then you need to call Direct Tv and they will help you program your DVR to the remote.
Posted on Dec 30, 2008
SOURCE: lOGITECH harmony 510 remote has locked up-
Hi! This is a really easy problem to fix. All you need to do is update the firmware of the remote!
1. Log in to the software.
2. Click 'Downloads' at the top of the screen
3. Click 'Firmware'
4. Update the remote
And it's fixed! Enjoy :)
Posted on Mar 18, 2010
Testimonial: "This was all i needed!!! Thanks so much- I will let ALL my friends know about you guys!!!"
  • 101 Answers
SOURCE: logitech harmony 550 volume problem
I would call or email in to logitech and suggest that they copy some of the learned commands for your bose system into your harmony remote account.
The commands they add are learned from other customers and they will only copy the best ones. Give it a shot.
Posted on May 06, 2010
My logitech harmony 1000 doesn't work after charging overnight. I have to hook it to the computer to update it. Is this a battery issue?
When was the last time u replaced the litium battery?If 2 years or more the litium battery has not been change.Yes,it is the litium battery issue.
Apr 24, 2011 | Logitech Harmony 1000 LCD Touchscreen...
Dropped the remote and now I can't turn it on!
I dropped my 650 remote last night and it no longer worked - one of my batteries was loose, so I carefully bent one of the battery tabs out - now it works!
Jan 19, 2011 | Logitech Harmony 650 Remote Control
My harmony 520 simply stopped working.
Have you tried resetting your Logitech Harmony 520 remote by updating your remote's firmware? Firmware replacement fixes several Harmony problems.
To upgrade or reapply the firmware on your Harmony remote:
  1. Launch the Harmony remote software and log into your account.
  2. Click on the Downloads button at the top-right corner of your screen.
  3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote.
  4. Once the firmware upgrade is complete, click on the Update Remote button.
I hope that helps.
_____________________________________________
Harmony 520 Manual Download
Logitech Harmony Firmware Update
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
Apr 10, 2010 | Logitech Harmony 1000 LCD Touchscreen...
We have a Logitech Harmony 550 remote that has all of a sudden stopped working. I have gone back through the down load and set up but it still does not work. We bought the remote on 11/28/2008 so we are...
I´d had same problem with my Harmony 520 and I solved the problem, it´s a little trick but you can repair it.
First, you need to open it. After remote is open, check if it come back to life. If OK, them the problem is (probably) that Activity buttom was pressed all time. To repair the remote, cut about half of the Activity pin and remount it.
f3528d7.jpga64b4ab.jpg7115325.jpg039f3dc.jpg9db5f5e.jpgd10cf68.jpg912e486.jpge4dfd76.jpged341b7.jpgaa41aa6.jpged0c4d7.jpgc19d9cb.jpg29aadad.jpg
Jan 12, 2010 | Logitech Harmony 550 Remote Control
Harmony one setup for new hardware?
go to www.logitech.com
click on support,
product support,
choose Harmony Remotes.
Choose your Harmony One.
Click on downloads
Choose your OS (VISTA)
Click download.
this is the newest version of the Harmony Remote Software.
Never download the software from the disc. it is never up to date.
Jan 08, 2010 | Logitech Harmony One LCD Touchscreen...
The power flickered on and off last night and since then I cannot get my Harmony 890 remote to change channels. We have Direct TV. It will control the volumn and turn the tv on and off, but will not...
You DirecTV device may have been reset ack to RF. You'll have to make sure the device is set to accept IR commands in order for the Harmony remote to work on it.
This link will help you.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=12985
-D
Oct 31, 2009 | Logitech Harmony 890 LCD Remote Control
Compatible TVs
I can help you with your Logitech Harmony 550 remote control.
The Logitech Harmony 550 remote control is programmed through the
Harmony Windows Setup Software.
Once installed, you will simply run the program and select the devices you would like to control from menus. The software finds the right codes for you and loads them into your remote control.
I hope that helps.
Harmony 550 Manual Download
Harmony MAC Software Download
Jun 06, 2009 | Logitech Harmony 550 Remote Advanced...
2 remotes....same problem
try a firmware upgrade if a firmware upgrade doesnt work, try e-mailing them from www.logitech.com go to contact us and send an e-mail:
1. Log into the Logitech Harmony Remote Software on your computer
5. Test your remote.
Apr 04, 2008 | Logitech Harmony 880 LCD Remote Control
Logitech Harmony 890 LCD Remote Control Logo
113 people viewed this question
Top Logitech Televison & Video Experts
Brian Sullivan
Brian Sullivan
Andrew Taylor
Andrew Taylor
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
