Question about Smeg SE250XUK Stainless Steel Electric Single Oven
No heat when i switch oven on
SMEG SUK31MFX5 heard a sparking noise and bright light beside the fan then oven just clicked off today, thermostat, grill, clock and fan all working, i can put the the grill on with fan then switch to oven and the thermostat works then but no heat at all in oven mode, i think it might be the element, any answers much appreciated.
  • shaun_scott_ Jan 08, 2009
    thanks for our help Guru, did have an idea it was this but thought i'd get a second opinion, many thanks for your help on this.
  • Smeg Master
  • 3,463 Answers
There is no doubt that it is the element that has failed, so all you need to do is replace the fan oven element.
If you can see a removable panel at the rear of the oven ,remove that, and you should see the element.
Remove and replace.
If ther is no removable panel then you will have to access it from the rear of the oven cabinet.
Plz rate my solution.
thanks,
Posted on Jan 02, 2009
I have a Smeg Wall Oven Model No SA710X-5. When I turn the cooking selection switch to the desired cooking setting the green light comes on. But when I turn the thermostat switch to the desired temperature...
It sounds like the element is missing one side of the 240v power. One side may always be hot while other side is controlled. A qualified repairman can Start at the element and work backwards. Trace wiring back looking for burned wire, bad connections and connectors, all the way back to thermostat. Check thermostat for continuity (with power off), replace thermostat if necessary.
Oct 29, 2013 | Smeg Ovens
SMEG SPA 42016, tripping switch after oven on for certain time, is this thermostat or Element issue?
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Aug 13, 2013 | Smeg Ovens
Smeg gb-ie
Jul 12, 2013 | Smeg Ovens
Smeg FU65-5 Oven temperature & timer & function knob lights not turning on and oven does not heat up but the fan comes on.
Dec 02, 2012 | Smeg 24 in 60 cm Stainless Steel Electric...
Smeg oven UK80MFX1 troubleshooting
Nov 30, 2011 | Smeg Ovens
I have a fan assisted double oven smeg tipo R31 mod SP 9000x/1 and my latest 2 batches of muffins have not baked.When I have taken them out of the oven they have not risen and are only half cooked. I have...
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Jul 08, 2011 | Smeg Ovens
Smeg cucina SE375 single electric oven not heating-grill and lights etc working ok and fan making noise-oven approx 18 months old
Jan 14, 2011 | Smeg Ovens
SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Dec 15, 2008 | Smeg Ovens
Smeg oven
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Smeg oven not working
You have a element and or a faulty thermostat
Nov 25, 2008 | Smeg F170 Pyrolytic Stainless Steel...
Smeg SE250XUK Stainless Steel Electric Single Oven Logo
497 people viewed this question
Top Smeg Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
