Question about Sharp SF 2020 Copier
Need to know were to reload the staples
My Copier is out of staples and will not do the sort and staple anymore. Need a little help in finding it this copier didnt come with a manual since i got it used. Any help on this would be very helpful.
You check the staple unit and staple pin and staple contro pwb
Posted on May 21, 2007
SOURCE:
I have the Swingline Optima 45. I staple once then the light blinks and I have to open where you put in the staples close it again and it will staple once. Then I have to repeat.
Electric staplers are notoriously unreliable, but the problem you describe sounds like buildup of the adhesive -- a sort of varnish -- used to hold the staples in stick form for loading in the tool. Remove the staples and apply a light coat of 3-in-1 or other thin oil to the first two or three staples. Reload and cycle the tool. This should help you.
Jan 08, 2018 | Staples Tools & Hardware - Others
Where do I find staples for the above Ace 2025 staples?
Most staple guns accept a range of staples of a standard type available from many different suppliers. It is rare that a staple should be manufactured for the exclusive use of a single staple gun.
First you need to know the sort of staple you need. Unfortunately staple gun manufacturers tend to omit this information from their literature and instead use the part number they have allocated rather than the more universal information of type and size.
Fortunately many nail and staple suppliers catalogues contain useful drawings with sizes so identifying any staple, once it has been very carefully measured, fairly simple.
Apr 19, 2016 | Staples Tools & Hardware - Others
Can't reload staple cartridge into canon imagerunner 3030
now do you have a full size finisher to the left of the copier or is it built into the mid section of the copier its self. now if it is a full size finisher on the left side of the copier there is a little door that will open up and the staple cartride is behind that door. from what i have been told of the finisher built into the mid section of the copier it should slide out towards you and the staple cartride is in the back where the finisher slides out. sorry never actually changed one but someone explained it to me.
Jun 11, 2010 | Canon Office Equipment & Supplies
Need instructions to load staples in Canon imagerunner 2270
pull the finisher out
you will see the staple in the end of it
pull up the staple cartridge using the green handle
then insert the new one
Apr 06, 2010 | Canon imageRUNNER 2270 Copier
I have an Arrow T-50 which is missing the staple pusher needed to reload. Can it be reloaded without the staple? If not, where can I get that part? Thanks!
You need the staple loader to keep the tension on the staples. The part is usually not sold separately. Your only chance is to find a used T-50 and cannibalize the part. You can get a new T-50 online for $25.
Dec 09, 2009 | Arrow T50P ARROW STAPLE GUN
(DP) air staple gun won't reload after shooting 1 staple
i have mini blow 8 mm gun automatic after i chut he did not reloaded plz tell how i can fixed
Jun 06, 2009 | Staples Tools & Hardware - Others
Load staples in xerox 430st
I will assume you are talking about the stapler on the finisher. That is a little tricky, but you will see a button on top of the finisher, you have to hold it down for a few seconds and the trays will lower. There is then a small door that opens and the staple cartridge is in there. You can either hold the button down again to raise the bins or turn the machine on and off.
Jan 22, 2009 | Xerox CopyCentre C123 Copier
Can't figure out how to reload stapler
I called a repairman to come and fix it. I am not a stupid person and can generally follow instruction and figure something out, but this is the second time this has happened with this machine & this staple cartridge, and why this is so difficult is beyond me. We have a mainternance agreement so I just called to have him come and fix it....again.
Dec 02, 2008 | Canon imageRUNNER 400S Copier
Stapling from the print mode
Yes, look in the printer properties in control panel to set this option before you print.
Nov 19, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
SHARP STAPLES
For the AR-M335U/455U-they are AR-SC2,5000 staples                            AR-M550U/700U,N-they are AR_SC11 staples                     They are a box of three. Hope this helps
Oct 17, 2007 | Office Equipment & Supplies
140 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
