What you need to do is backup your data first! Data would be your My Documents folder or other data files you might have! Some PC's come with an option while booting to Restore or recover your PC and usually starts like for example "Press F11 for system recovery"!! OR If you have all the original CD's that came with your PC there should be a system restore disk somewhere in there! With these CDs you can boot to them and restore your pc to like when you bought it! Some are pretty straight forward some aren't! But this is more likely the way to go cause recovery CDs come with all your applications, drivers and stuff! After you do the recovery then you can restore your data and you should be good to go! hope this helps, regards, babb
1. Turn on the computer and
hold down the "F11" key once the BIOS prompts appear on the monitor.
2. Click
on the button labeled "Advanced Options" in the Welcome Screen once the
Recover Manager opens. Choose the "System Recovery" option and click
"Next."
3. If the "Microsoft System Restore" window appears, select "No"
and click "Next."
4. The Recovery Manager will then prompt you to back up
any important files as the restoration process will delete all data on
the computer's hard drive. If you wish to perform a backup first, select
"Back up your files first," click "Next" and follow the on-screen
instructions. If not, choose the "Recover without backing up your files"
and click the "Next" button. The computer will then begin the
restoration process and restore the HP DV4000 to its original factory
settings.
I don't have slightest clue how to recover my data
I don't Know How to restore my computer because I being having a lot probles with viruses also
