Question about Kenmore 42822 Front Load Washer
My Kenmore Elite Frontloading HE3 is flashing a Sud, what do I do
I Have a Kenmore 42822 front load washer that is flashing Sud............What do I do to fix it?
  • 91 Answers
Apply a small amount of cooking oil imside tub ,, must use only HE deteregent if you are ,,, maybe too much
Posted on Jan 04, 2009
This happened to me one time and I could not cancel the cycle or open the door or choose any other options, I was advised to unplug the machine, wait 30 seconds and then plug it in again. This cleared the error and I was able to continue with my laundry.
Posted on Mar 25, 2009
Elite he3 42832
the problem is the oil seal from the shaft to the tub,need to change it!
Oct 03, 2013 | Kenmore 42822 Front Load Washer
I have a kenmore elite he3 front loader; it gives me the "sud" code during a wash cycle. What could be the potential problem?
either way too much soap or the wrong type,run a couple of washes,without clothes to purge excess soap and see if this clears up the sud code
Jul 07, 2010 | Kenmore Elite 45986 Front Load Washer
I have kenmore elite he3 and it is flashing f 02 and then it will flash sud. Water will not all drain out of it,
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Oct 27, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Water leaks from bottom.
This model is OLD , time to get a new one
May 22, 2009 | Kenmore 42822 Front Load Washer
IT wont start washing
if it fills with water or has filled and wont go any further then suspect the door switch< latch assembly has switch> if it doesn't fill then possibly water valve not working,if neither of these seem accurate then please give more info
Apr 20, 2009 | Kenmore 42822 Front Load Washer
Door Seal
Just follow this link and it will explain how to replace the door seal:
This is a very simple repair, if you follow the step-by-step instructions. Take your time and if you have questions, let me know. I hope this helps you.
PS An alternative method is to work through the door with the front panel in place, but this limits access. To make things easier, it is strongly recommended that you remove the front panel.
Apr 13, 2009 | Kenmore 42822 Front Load Washer
Kenmore HE3 model 42822 flashes HF??????
probably fh sure drain hose is at least 30 insches from floor and fits loosely in standpipe to prevent siphoning also ckd all fill hoses for obstructions in inlet valve ends most likely problem is flowmeter remove top round object left side with 2 small hoses try tapping it this may at least let you know for sure it is problem even it doesn't flowmeter is most likely the problem
Nov 20, 2008 | Kenmore 42822 Front Load Washer
Kenmore elite he3 front load
I had the same issue with a brand new wash. The issue I found was the installers installed the drain line too low. The drain line needs to be a minimum of 39" above the floor. Hope this helps -- Kent
Oct 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Front Load Washer...F02 and SUD not draining!!!!
Probably something caught in pump. Remove lower panel if this one has it and you will see the pump. Loosen the round cover in middle to access clean-out.
Nov 08, 2007 | Kenmore 46462 Front Load Washer
Kenmore 42822 Front Load Washer Logo
295 people viewed this question
Sal De
 Brian Main
Brian Main
