Question about Microsoft Windows XP Professional
Print to a USB port in DOS in Windows XP
Is there an equivalent command from DOS to "type (filename) LPT1 I can use on a newer notebook computer running Windows XP that does not have any LPT ports? I use some older DOS software that in my business and need to be able to redirect the output from DOS to a USB port.
    Scholar:
  • 96 Answers
This is an interesting question .... I never thought much about using a USB printer in DOS!
Well ...this is probably the easy fix :
http://www.dos2usb.com/
Program called dos2usb which claims to do exactly what you want (15 day free trial download ....$19.99 to buy the program)
The harder fix that won't cost anything is to do some network jiggery pokery to redirect data sent to a parallel port to a usb port. Here's a link on how the folks at Dataflex did it :
http://www.decompile.com/dataflex/tips/usb_printer.htm
Posted on Jan 01, 2009
WHY DOT MATRIX PRINTER NOT PRINTING DOS BASE PRINTS
It can't.
DOS printing need LPTx parallel port because DOS don't understand/support USB.
YOU can share the printer with windows printer driver, then
go to CMD prompt
Type
Net use lpt1 \\<computername>\<printersharename>
Then print DOS job to LPT1
May 12, 2014 | Parallel USB Print Server 2 Port USB&1...
NOT PRINTING OUT OF DOS PROGRAM
The problem is, the DOS program tries to print to LPT1, which is your parallel port. We need to redirect this to your USB Port. First, you have to set up printer sharing: Go to Control Panel | Printers | Your printer and share the printer. Assuming that you share it with the share name "MYPRINTER" and the computer is called "MYCOMPUTER", then type go to Start | Run and type in: NET USE LPT1: \\MYCOMPUTER\MYPRINTER /PERSISTENT:YES That should do the trick, unless there's a driver problem, which is unlikely for a dot matrix printer. If that doesn't work, let me know and I can troubleshoot further.
Sep 09, 2007 | Panasonic KX-P2130 Matrix Printer
I have a retail store with 7 x Win 7 Workstations. i have 1 x Epson Tm-T88iii thermal receipt printer connected and installed on lpt1 port on my 1 workstation. We use a Dos application for our sales. The...
Hi, details below for creating a ersistent connection from LPT1: to you \\computer\\printername printer. Do the following on the other workstation that is not printing.
Use the net.exe command to establish a persistent connection.
To do this, use the following syntax at a command prompt:
net use lpt1 \\printserver\sharename /persistent:yes
where printserver is the print server that is sharing the printer, and where sharename is the name of the printer share.
For example, to map LPT1 to a printer shared as Laser1 on a print server that is named Pserver, follow these steps:
1. Click Start, and then click Run.
2. In the Open box, type cmd, and then click OK.
3. Type net use lpt1 \\pserver\laser1 /persistent:yes, and then press ENTER.
4. To quit the command prompt, type exit, and then press ENTER.
Note In Windows XP, non-administrative users cannot map an LPT port to a network printer path when the LPT port exists on the computer as a physical parallel port.
Apr 12, 2011 | Epson TM-T88III Thermal Printer
I cant use usb printer to get print out from dos base softwear
If you are using a NT based Windows (ex. win nt, win 2000, win xp, etc...) you could try sharing the printer than MAP it as a network printer and direct it to a virtual LPT port with a DOS command ex: net use lpt2: \\ComputerName\SharedPrinterName /yes
Than setup the DOS software to print on LPT2 it should worke, i've done this many many times
Note: if you absolutely have to use LPT1 dont forget to change the physical LPT 1 port in Windows hardware manager to something els so it do not conflict with the virtual one
Feb 15, 2011 | Epson LX-300+ II Matrix Printer
Print from DOS
Try Start --> Programs --> MS DOS
or Start --> Run --> enter CMD
this will take you to a DOS screen
To print a file use the type command and pipe it to LPT1
e.g. type myfile.log > lpt1
Feb 16, 2009 | Compaq Inkjet Ij300 Printer
Need help installing the firmware for an HP LJ p3005n. I have the download, and the printer is locally connected *USB*
David,
As per the instructions from HP for windows systems:
If the device is shared on the network, then the following command can be issued from a command prompt: copy /b FILENAME \\SHARENAME\PRINTERNAME
where FILENAME is the name of the .RFU file,SHARENAME is the name of the machine, from which the printer is being shared, and PRINTERNAME is the printer's share name.
If the device is attached locally, then the .RFU file can be sent directly to the printer with a COPY command from a command prompt or DOS window:
copy /b FILENAME PORTNAME
where FILENAME is the name of the .RFU file and PORTNAME is the name of the appropriate device port (such as LPT1).
The following can be set on the computer to help address a timeout message that may occur during an update:
From a command prompt or DOS window type the following command and press the enter key:
Mode lpt1:,,p
If the device is attached to a parallel port other than LPT1, then substitute the proper LPT port number in the MODE command. Once this command has been set the file can then be copied to the printer with the above mentioned COPY command.
NOTE: When the upgrade process has completed the LaserJet will reboot. Once the printer is back online, print a Configuration Page and verify that the new firmware has been installed.
Chris
Alkaline Water
Dec 05, 2008 | HP LaserJet P3005n Printer
USB printing through DOS mode
Google for DOS PRINT USB, and you'll find some utilities that do this.
Or, you can include some commands in your batch file.
First, get the device name:
In a DOS window, type NET VIEW ComputerName (or use 127.0.0.1)
Once you know the printer share name, you use it in a batch file.
NET USE lpt1: \\ComputerName\ShareName /Persistent:Y
This captures the print queue to the shared printer.
You must also go into Printer Properties/Advanced/Print Processor and set it to TEXT
Your copy, print and other commands will work.
Jul 12, 2008 | Computers & Internet
Dos Program in FoxPro
To answer the question, I need to k**w if your DOS session is running inside Windows. As this is the most likely scenario, I'll answer assuming that - the answer will be different for DOS only systems.
Has the faulty LPT1 port has actually been removed? If it has, why **t just alter the port number of LPT3 back to LPT1 ? This can be done with jumpers on an old style card, or from device manager inside Windows if plug and play. If **t, you can try the following:
1: If the printer is already installed in Windows on LPT3, skip to step 3:
2: Install the printer in Windows. If you don't have a suitable driver for it, you can use Generic/Text only driver.
3: Right click on the printer, go to sharing, and make the printer shareable. Use a share name of 11 or less characters and ** spaces - e.g. EPSONLX500
4: From the CMD prompt, type the command:
net use lpt1: \\%computername%\Sharename
e.g.
net use lpt1: \\%computername%\EPSONLX500
**te that you do **t need to replace %computername% with your exact computer name - the machine will do it for you.
Finally, for others reading this, you can also use this technique to print from DOS to most "intelligent" USB printers (Hi end Laser, Dot Matrix etc). It probably won't work with "dumb" GDI printers or All-in-ones where Windows has to do all the work. If the printer supports PCL or ESCP printing languages, you are probably going to be OK.
Mar 10, 2008 | Office Equipment & Supplies
Printing from Dos Prompt
1. Save your text file (.txt).
2. On the command prompt navigate to that directory
3.Type "Lpr -S 192.168.1.200 -P lp text.txt"
Substitute 192.168.1.200 for your copier's ip
Substitute text.txt to filename.
Or you can: to print from MS-DOS apps.
1. Share the printer on a networked windows computer. Make sure you make the name MS-DOS compatible.
2. At a DOS prompt, type the following command:
"net use lpt1: \\servername\printer_share/persistent:yes"
NOTE Servername=computer name
printer_share=printers share name
Sep 28, 2007 | Office Equipment & Supplies
Microsoft Windows XP Professional Logo
208 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
