Question about Columbia All Sport Digital watch
I can't set my Surge plastic watch.
I have a blue plastic Surge watch. I've lost the directions and have to reset it due to a battery change. I tried the Columbia post above and it didn't work.
  • 1 more comment
  • bean-drake Jan 17, 2009
    I also have a blue plastic surge watch. We cannot get the watch off of military time and we can not get the alarm off as well. any help would be greatly appreciated. thank you kindly in advance.
  • Anonymous Mar 12, 2009
    i can't change my watch from the 24 hour mode to 12 hour mode. can you help me please !!!
    i have a surge watch and can't get it out of the 24 hour military mode to the 12 hour regular mode. can you help me please, i've tried all different ways in pushing the buttons but it does nothing to help. tony
Replacing a battery on a C9 by Champion Womens watch
to change the battery in a champion watch:
(1) remove the back, (2) carefully peel loose the foam strip and set it aside (3) release the battery retaining bracket with a needle or awl and tweezers, (4) grasp the case with your thumb and forefinger so that your thumb is holding the works inside the case, (5) turn the watch over and the battery should fall out (6) put the new battery in the holder, (7) snap the retaining bracket back in place (8) replace the foam strip (9) replace the back 5b238361-61b1-4b0d-ab40-54fb346f5586.jpg
Dec 07, 2013 | Geneva Watch Group C9 by Champion Womens...
Timex Rush Indiglo Watch: shorting the AC pad to the battery
If you take a jeweler's lupe near where the arrow is you will see the word "reset" in the plastic.
There is a deep hole in the plastic with contacts below. That is the reset, and that is why you must use very sharp pointed tweezers to make contact with the back of the battery.
I think if you do not have sharp tweezers, you can probably put a sewing pin down the hole, and then connect with a small screwdriver to the back of the battery..
Sep 05, 2012 | Timex Indiglo Watches
I received my suunto t3d black watch yesterday and accidentally set the contrast too high and it saved. I've tried everything but can't seem to find the setting to fix it. I've even removed the...
To reset contrast on the sunnuto t3d hold down all 4 corner buttons at once, this will place the watch in sleep mode. Wait a few seconds and press any button to wake the watch back up. This will allow you to run through the inital set up just like when you got your watch, alot of your info will be saved so you can just quickly confirm them with the mode button. I also set my contrast too high, I have reset it to 3 and found it much easier to read in all lighting.
Aug 13, 2011 | Watches
I have an old Casio watch 863 SDB-500W, I have just change the battery . Light is working but nothing is display. How to reset it ?
To reset the watch, you need to 'short' the reset point with the battery. To do this, with the watch face down and the back removed the 'Reset' point is in the bottom right hand corner (a gold-coloured contact point). Use a pair of metal tweezers or an unbent paper-clip (anything as long as it's metal and will touch the reset point and the back of the battery at the same time). Maintain contact for about 5 seconds and you should get the display back.
I've just changed the battery in my SDB 500W and the above method worked. I did lose the audible 'beep' though and I'm currently on the net trying to find how to get it back. That's how I found your question... :)
Jul 24, 2011 | Bulova Watch
Just change the battery on my Nike Anvil WC0020 watch and the alarm won't sound for the timer as well as the two alarm settings.
If you changed battery yourself, you've lost the tiny spring without noticing it. Carefully check around the place where you changed the battery. The spring itself is very, very tiny, so, be as concentrated as much as you can. That spring (coilspring named by watchmakers) transmits the signal from watch movement to the watch back cover where the sound membrane is located. In case if you find it, open the watch and insert that spring with the bent out end first in to the desired hole in watch movement (should be named COIL SPRING). After that re-assemble watch and the sound should work.
Jun 02, 2011 | Nike Mettle Anvil Super Watch Obsidian...
I have a Pulsar w861-x002. The battery went dead, so I took the watch to a jewelry store (that also sells Pulsar watches). They replaced the battery, but now the time/year/and everything else cannot be...
I replaced my battery too...same watch same ugly condition where you can't set time nor does the light work.
I do know what the problem is: there was an ultra small copperish spring...about 1/6 the size of the other little wire spring that you have to short with twizers to reset time. Anyway, I lost this part...and even if I found it, I wouldn't know where it goes. I came on-line to find where the missing part goes...but everyone has the same issue as me. any jeweler would loose this parts just like me...it's the master contact the enables power to all the side pushbuttons
Sep 15, 2010 | Watches
How do I replace the watch battery for Casio DW-6900?
mcdevito75 here, Casio uses an LCD crystal, Liquid Display Crystal, during a battery change any, any un do pressure remopveing or replaceing the battery could destroy the LCD. Take my advise, with a casio watch, look for a small watch repair shop in your area for the battery change. I"ve ruined many of my casio watches during battery change.
Aug 27, 2010 | Watches
No sound
If you lost the spring, I can't help. But repairs like this SHOULD be done carefully on a mat or table to help contain parts. My Timex watch made no sound after I changed the battery. I was unsure what the internal plastic sheet meant when it set something like short to reset. BUT, as shown elsewhere on this FixYa site, simply turning the back cover 180 degrees restored the sound, and the watch works great again!
Sep 03, 2009 | Timex 50-Lap Ironman Triathlon 59221 Wrist...
Setting the time
Dear Sir,
It appears that the watch was malfunctioning which I thought was due to a change of battery being required.
(It was running slow and giving the wrong time - so my mother told me)
I subsequently found instructions for the watch on an internet site, changed the battery and the watch is still failing to set to the U.K. time zone therefore, I deduce that it is a failure in the watch rather than the need for a new battery or ranything I have or have not done.
Please delete my question from your system
Thank you.
Regards
Jan 17, 2009 | Bulova Watch
I have a seiko flight watch, unknown of the model, second hand doesn't reset
I guess the blue faced SEIKO is a Flightmaster (Model: 7T92- OCFO)and it is a great watch. This is a common problem with most chronographs and this happens due to misalignment with usage.
All you need to do is pull out the locking crown all the way out (2nd Step) as if setting time. and then press and hold the top / left button and at first the milli seconds hand resets. after which you have to press the borrom / right button to move the seconds hand in to place. and then reset the time and lock the crown. You can repeat this for Milli Seconds, Seconds, Minutes & hours hands.
Hope this helps,
Krishna Chaitanya GT.
Apr 27, 2008 | Seiko 0512039FA Wrist Watch
Columbia All Sport Digital watch Logo
215 people viewed this question
Top Columbia Watches Experts
Nalin DSouza
Nalin DSouza
Are you a Columbia Watch Expert? Answer questions, earn points and help others
