Question about Black & Decker 9072CTN 2.4V Cordless Screwdriver
How do I replace battery in Black and Decker cordless screwdriver
Model 9076 - I know it's old but I don't know how to get it apart to replace nickel cadium battery
  • 2,176 Answers
Just to clarify you have a model number 9076 and I would assume type 1. If so there are screws holding the 2 halves together that would have to be removed the batterys are in the lower section of tool. They are about 8.60. I would recommend going to and typing in your model number to look at a product explosion before attempting this repair. Keep in mind that I saw that quite a few of the parts are no longer available so it might be time to retire this one.
Posted on Jan 01, 2009
What settings on a universal charger do I use for a Black & Decker 2.4 V cordless screwdriver
I would say that a output voltage of not more than 2.8 volt and the output amp should not exceed 60% of the Amp hour rating of the battery. Example if the battery is a 2000 mah battery the charging amp should not be more than 1400 milli amp or 1.4 amp
Jan 12, 2014 | Black & Decker 9072CTN Cordless...
I need to replace the batteries but I can't get the old batteries out of the screwdriver. I've pried and pried and the pack is part way out.
buy some Johnson&Evenrude lubricant (marine) .Spray up into the cylinder. then use vice grips to pull the battery out. Maybe wedge a nail into the push prongs to hold them in.
Oct 21, 2010 | Black & Decker Pivot Plus Cordless...
Black & Decker Nickel Cadmimum replacement battery
Check the store where you purchased the screwdriver but you will find its cheaper to buy a new screwdriver with new batteries than to buy just the batteries.
Jul 12, 2010 | Black & Decker 9072CTN 2.4V Cordless...
My old black & decker power screw driver will not accept a charge. I cannot get it charged up.
Black & Decker stopped doing battery packs for the older screwdrivers, like the 9018, some time ago so you cannot get them.
However you can still buy replacement NiCad, Sub C, 1.2v, tagged batteries that will do the job on the older 2.4v models as NiCad batteries for use in power tools are exempt under the European ban on importing NiCad batteries where used in power tools (Specific Exemption).
When you open up the screwdriver look at the positioning of the batteries and the tags/connectors and solder them together the same way.
So all you need is a soldering iron to join the centre tags together and then trim the end tags, top and bottom, to the width of the live/negative connectors and you have got a new battery pack.
It doesn't have to be pretty but after a small investment and a little effort it sure beats paying out £30 to £50 for a new screwdriver. I have done this for my older Black & Decker and Bosch screwdrivers which all work like new again.
Apr 08, 2010 | Black & Decker Pivot Plus Cordless...
this one dosn't charge. It takes batterys. how do i change them
Dec 20, 2008 | Black & Decker Pivot Plus Cordless...
My cordless Black & Decker Pivot screwdriver, stopped working. It is completely charged, but will not work.
Most likely it is the switch has gone bad or just a loose connection on the switch . you can take it apart and check the switch connections and make sure they all have a good connection.If they do then you should take a volt meter and make sure that when you puch the button they get proper voltage if not then order a switch and replace it .
Aug 23, 2008 | Black & Decker 9072CTN Cordless...
Black & Decker 9072CTN 2.4V Cordless Screwdriver Logo
2,225 people viewed this question
Top Black & Decker Hand Tools Experts
Robert Monigold
Robert Monigold
Don Numinen
Don Numinen
Are you a Black & Decker Hand Tool Expert? Answer questions, earn points and help others
