Question about AEG Favorit 50500 Built-in Dishwasher
Leaking leaks from door
    President:
  • 1,462 Answers
Could be due to goalpost seal in poor condition or door latch needs adjusting
Posted on May 09, 2007
I have changed to door seas but still leaking, what other seals are there that could be leaking
If the door seals are not replaced _exactly_ right, it will leak like a sieve. Otherwise, the water control valve is located right up front and may be leaking, and tricking you into thinking it was the door seals.
Apr 06, 2016 | Dishwashers
My dishwasher is leaking from the bottom of the front door. I can't seem to get to the drain filter. Can that be removed? I think there may be a clog in it.
If the leak is from the bottom of the front door than it is most likely the door seal. If the leak is from beneath the unit and appearing to leak out from the front there are many sources for the water.
Check the seal around the door. It may have some residue that has collected prohibiting the seal. The water in the machine actually sits in a tub. The seal on the door prohibits the water leaking as the spray arm rotates.
To test the door seal start the cycle and stop the unit as soon as the machine begins the spray cycle. Open the door and observe that the tub is full but still below the edge. Dry the seal around the door. Place colored paper towels or cloth beneath the door as close to the door seal as possible, Continue with the cycle and observe for water leaks. Stop allow the unit to sit a few seconds open door and observe the seal. You are looking for the location that it is leaking.
If you can confirm that the seal is leaking you can purchase replacement seals, On some models they can be easily replaced.
In my experience I have not seen a filter in the return line. If there is a blocked return hose the unit would not leak. The tub would remain filled after the cycle. There is an overflow switch that prohibits the tub from overfilling if the tub has not emptied between cycles.
Nov 21, 2015 | Dishwashers
Water leak in front left corner of unit. Rusty leveler near strainer.
Is the leak on the same side as the hinges? If yes I'm guessing someone overstressed the hinge when opening the door too widely or by leaning on the open door and the seal is just barely tight enough now. Crack the door open half an inch and eyeball the door gap from top to bottom on the open side to see if the door is unevenly hinged - you can use a ruler to help measure but you need to keep the door immobile while comparing top and bottom gap widths. Tape a hard wedge in place in the doorframe to help with that. Fix for that? Pressure on the door in the right direction to straighten the hinge mount.
Feb 25, 2014 | LG WM2688HWM TROMM SteamWasher
Samsung dishwasher leaking when not running
First, try to find the source of the leak. Leaks most often appear at the door of the dishwasher or underneath. Leaks can be caused by a number of issues: worn door gasket, water temperature, leaking drain hose, worn gaskets, or a corroded tub. For help identifying the cause and finding a solution, see the troubleshooting chart at Dishwater leaking for more information. Good luck!
Aug 17, 2012 | Samsung Dishwashers
Whirlpool dishwasher leaks
Just about all dishwashers will leak a little around the door seal over time but should not leak to the point of wetting the floor. With the door open, check in the front of the tub, under the door. Lots of gunk? Clean this area out well plus take a soft damp rag and clean the door gasket while feeling for any damage. Then go along the mating surface of the door and look for any nicks. If it leaked all the time I would suspect the door hinges have been sprung. Hope this helps, Ken
Apr 26, 2009 | Dishwashers
Leaks under left hand side of door; I've installed 2 new gaskets in last 2 weeks & new float switch; doesn't leak underneath
Check for cracks in the inside liner of the door itself. Seal anything that looks like a potential leak with silicone sealer. I'm providing this advice because you have already eliminated the other possibilities I can think of. If it has a soap dispenser on the door check for leaks around that especially.
Jan 14, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Duet 6hw9150p leaks when i put a full load
Is the door seal dirty?
A dirty door seal can cause a leak. Remove and clean any dirt or deposits around the inner door seal with a damp cloth. The door glass seals against the rubber seal; dirt or deposits can prevent a proper seal and cause leaks.
Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bosch SHV45M03UC dishwasher door leaking
the latching mechinisum is at fault or the door is bent.
Apr 07, 2017 | Dishwashers
AEG Favorit 50500 Built-in Dishwasher Logo
195 people viewed this question
Top AEG Dishwashers Experts
Paul Carew
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
