Want to enable wireless on my advent 5421
I have wireless broadband but my comp wont allow me wireless access i have to be connected directly to the router. i dont have a user manual for the computer
  • Jeff May 11, 2010
    Okay, what is the computer? Make, model and any specific product number? Then we can figure out what needs to be done
    Also, you said wireless BROADBAND? That is different than wireless 802.11. Wireless broadband is cellular and requires that you set up an account with the carrier whose embedded modem is in your computer.
    If you have wireless broadband, you likely also have wireless 802.11, which can connect to the access point you have once we know what your computer is.
  • 32 Answers
RESTART YOUR COMPUTER, ON REBOOT, CLICK F10 WHEN YOUR CHANGE BOOT OPTIONS SCREEN COMES UP. YOU MUST PRESS F10 QUICKLY OR IT WILL LOAD WINDOWS AND YOU WILL HAVE TO RESTART AGAIN. ONCE YOU GET INTO THE BIOS SETUP UTILITY GO TO SYSTEM CONFIGURATION, SCROLL DOWN TO BOOT OPTIONS CLICK ENTER. GO DOWN TO INTERNAL NETWORK ADAPTER BOOT AND ENABLE IT. GO TO EXIT AND SAVE.. THIS SHOULD WORK.
Posted on Jul 02, 2009
ADVENT 4211-B KEEPS DROPPING WIRELESS CONNECTION
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls, mirrors, fish tanks and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Apr 06, 2013 | Advent 4211c Notebook
Wireless broadband will not connect to my advent note book do i have to switch anything on, on my notebook to go wireless
You need to have your access codes for the router, and yes, most laptops have a way to turn off the wireless, a switch usually.
Oct 08, 2010 | Microsoft Windows Vista Home Premium...
Need to enable security -- had a power failure -- the computer with direct cable connection has internet access, but my laptop with a wireless connection no longer works -- says the network "is unsecured...
Log in to the router, check Wireless settings, Security is in the same area. I find that WPA-PSK[TKIP] is the easiest type to use, as you can use pretty much any sort of password longer than 7 characters. This can be done with the wired connection.
Nov 09, 2009 | Linksys Wireless-G Broadband Router
Wireless network card in advent 5421 keeps losing
Check the propeties on the device and set to max performance and NOT to sleep mode at all. If still trouble buy a good Intel card on
www.ebay.com
Oct 10, 2009 | Computers & Internet
All works fine but computer will not go online, either by usb modem or broadband connection
Go to control panel, then go to internet properties. Make sure your device is enabled. Including wireless and LAN connections.
Keep in mind that you will have to unplug your router for 10 seconds and plug back in to remove static discharge. This is commom
Sep 16, 2009 | Advent Netbook
How to turn off wireless on Advent 5421
You can disable the wireless adopter
Type ncpa.cpl in run command
It opens the network adopters in ur laptop.
Right click the wireless adopter and disable
Thanks
Siju
Aug 28, 2009 | Dell Inspiron 1525 Laptop
Wireless security
You can disable the network card to block all Internet access.
This doesnt help though when you want to check your email etc.
Try turning off Windows Automatic updates, and any antivirus automatic updates, these two things are the bane of wireless broadband users as it will use most of their data before they even realise.
Aug 21, 2009 | Computers & Internet
My iBook wont connect to my Linksys wireless G router
try removing the passkey and security on the linksys
then enable reverse authenication, by allowing only specific MAC addresses to access the router. ( MAC FILTERING ) ONLY ALLOW
then add the MAC addresses of your IBOOK and what ever else you have..
simple and secure :)
Aug 21, 2009 | Linksys Wireless-G Broadband Router
I cant get virgin netgear router to connect to my medion laptop, i get to the last part of the installation process when it says attempting to connect to newtork and it comes up move your connections...
Have you accessed and setup your wireless part of the modem?
To access the router settings menu, you will first need to log into the Wireless router following the steps below:
Open Internet Explorer
In the address bar type the following address:
192.168.0.1
You will be prompted to enter a Username and Password to access the interface, please use the following default details:
Username: This can be found on the bottom of the router
Password: This can be found on the bottom of the router
From the list on the left hand side, click on ‘Router Status’.
Within the Router Status section there are two areas you will be able to access:
Show Statistics
Connection Status
The Router Status page gives you a detailed status overview of the connection configured on the Wireless router.
Click ‘Connection Status’ to see more information on the broadband connection.
If you have already configured your broadband, you are able to establish/terminate the connection by clicking Connect/Disconnect.
You can also click ‘Show Statistics’ to show you current connection speed and more information on your Broadband connection.
Clicking on Basic Settings enables you to check all the Internet settings of your Broadband connection. Including the Login name (username) and password, IP address and type of connection.
Clicking on ‘Test’ will perform a standard check of your Internet connection and settings.
ADSL SETTINGS
The ‘ADSL Settings’ section provides you with some more information about your Internet connection. These are:
Multiplexing Method
VPI
VCI
WIRELESS SETTINGS
This section gives you full information regarding the Wireless connection. From here, you can change security settings, the SSID (Name) of the router and the access control list. Options list from:
Name(SSID) virgin broadband (default)
Region Europe(default)
Channel 11(default)
Mode g&b(default)
Enable Wireless Access point
Allow broadcast name
Security options (None, WEP and WPA)
- hope this helps
Jul 03, 2008 | Computers & Internet
Computers & Internet Logo
808 people viewed this question
David Payne
David Payne
