Question about GE Advantium 120 Convection/Microwave Oven
Does not work after speedcooking bacon.
My girlfriend has an Advantium 120 GE convection/microwave. It's about 5 years old, she had an issue with this before and the service guy replaced something called the TCO, part # wb21x10046. It happened again about 7 months ago and I want to fix it for her. Anyone out there that can give me a reference to where this part is on the chassis and any insight to a quick easy repair/replacement? Appreciate it,
  • handy50 Jul 26, 2008
    My TCO has failed twice. It is located inside the upper section of the box. You have to remove the outer shell ( about 20 screws) and the everything else to get to the upper left front corner of the outside of the chamber. The TCO is inconveniently secured with two small screws that will easily fall inside the unit so stand the whole beast on its left side while removing them.
    I would like to see if there is an alternate part that has a higher cutout temp or see if there is another solution to spending about an hour replacing the TCO. (after you get the part and put the whole unit on a sturdy table)
  • GE Master
  • 9,098 Answers
Most repair warranties are only 30-90 days, but you might consider asking the servicer if they'll cover it. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your actual model number (like SCA1000DBB03, not Advantium 120) here: http://tinyurl.com/gv383 That part is the thermal cutout (TCO) or thermal fuse. It's reference number 1430 on the first diagram listed there.
Posted on May 08, 2007
Ge microwave ceramic element
The service manual is here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
You can download GE owner's manuals and installation instructions here.
Dec 27, 2013 | GE Microwave Ovens
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Hello, I have a 7 year old GE Advantium oven that the microwave has quit working on. The power and timer come on but the actually cooking element of the microwave is not working. When testing the oven...
I would first suspect the primary interlock (top door switch) or maybe that switch's mount is loose or broken.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
We have the service manual and have uploaded it here to help you.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
Aug 19, 2010 | GE Advantium 120 Convection/Microwave Oven
Replace fuse on GE Advantium Speedcooker Oven
there is a fuse located underneath the outer cover, its called a ceramic fuse and is of cartridge type about 1" long by 1/8" diameter and has a white body and 2 silver ends and you can take it to a hardware store they have them but make sure to get correct amperage rating 15 or 20 amp
Sep 05, 2009 | GE Advantium 120 Convection/Microwave Oven
Need to replace fuse in GE Profile advantium oven
remove outer shell/cover, the fuse will be in a fuse holder about 1" long X 1/8" in diameter and is called a ceramic fuse,take it out,look on ends for current rating go to hardware store they have repl fuses, if the new fuse blows it could be your h.v. diode, capacitor, or the magnetron tube
GE Advantium 120 Speedcook Oven
THERE IS NO EXTERNAL VENT NO NEED TO CUT ANY HOLES GO TO THERE WEB SITE AND YOU WILL FIND THE MODEL YOU WANT, THERE ARE SEVERAL--IF IT IS VENTED IT HAS TO BE IN THE UNIT NO OUTSIDE VENT, IT IS A HOLEGEN LIGHT BULD WITH A MICROWAVE
May 29, 2009 | GE Advantium 120 Convection/Microwave Oven
Microwave part of my GE Sensor Convection Microwave doesn't work
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Dec 22, 2008 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
366 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
