Question about Air Tools & Compressors
Air escapeing through triger assembly
I have a porter/cable 15 gauge angle finish nailer,I bought 2nd hand.It works 25% of the time.The problem being air escapes through the trigger assembly when I pull the tigger only!I bought a rebuild kit from porter/cable,and replaced 100% of all seals,including the whole triger assembly,and it still does the same thing.I went per instructions.There is"nt a wole lot to these guns to repair.I know the problem is simple to fix if I could figure it out.But in the mean time the gun is worthless to me as is.Hope you can help??Thanks for your help on my compressor problem!It works GOOD now!Thank you!!!!........Dane
  • Dane Lanne
    Dane Lanne Jan 03, 2009
    Thanks for your solution!My gun works 100% like new now.
    THANK YOU VERY MUCH!!........Dane
    President:
  • 1,388 Answers
The problem that you are describing usually occurs when fine scratches in the head allow air pressure to bypass the orings. Here are a couple of simple tests. Remove the trigger from the gun to give access to the trigger valve plunger. Remove the nails from the gun. While pointing the gun away from you, connect the air supply. There should be no air leaks. Now quickly depress the trigger pin all the way in. This must be done with a very rapidly movement. If the gun fires, then the safety foot is not pushing the trigger pin all the way in. Check for worn trigger or safety mech. When the safety foot is depressed against the work, the trigger pin should be depressed all the way into the trigger valve for the gun to fire. Hold the trigger closed tightly and very firmly depress the gun against the work, the gun should fire. If it does not fire try next test. Remove the head from the gun. Hold it in your hand and depress the headvalve all the way into the head with you thumb. While holding the headvalve in, place a finger over the small venthole on the mating surface of the head and release the headvalve. Vacuum should hold the headvalve in the head for a moment until you release the vent hole. If the headvalve springs back with finger over venthole you must remove the headvalve and inspect the surfaces with maginfing lens for fine scratches. Remove scratches with very fine paper to obtain smooth polished surface. Lube surface with silicone lube (looks like vaseline, sold in small container at Lowes plumbing department used for lubing faucet orings ) re-assemble gun and make sure that you tighten headbolts firmly. You should be ready to work. Good Luck!
Posted on Jan 03, 2009
How do I replace the trigger valve assembly on a Porter Cable DA250C nail gun
There is one pin with a retaining o-ring that must be removed holding the trigger arm in - then there are 2 roll pins that must be driven out with a small punch that hold the trigger valve. Once the 2 pins are removed the trigger valve can be pulled straight out.
When you install the new trigger make sure the recesses in the trigger line up with the holes for the retaining pins.
Porter Cable DA250C Type 1 15 Ga 2 1 2 34 Angle Finish Nailer Parts
Feb 12, 2015 | Porter Cable Air Tools & Compressors
Freeman PFN1564 shoots air when you disengage safety and pull trigger
if you mean it only shoots air when you pull trigger and not a nail , disconect from air supply and open side of nail mag. (two screws on side) look for forign object in front towards head end , sometimes the paper that nails are wrapped in gets stuck in there , also there is a small spring metal clip at front of mag is this broken off and is unusually short ?
Sep 22, 2014 | Freeman 15 Gauge 34 Degree Angle Finish...
Describe your 2 - 1/2"
Not sure what you question is however Porter Cable and Bostitch are now part of Dewalt. Parts and owners manuals as well as other documents are available at the web address below.
http://servicenet.dewalt.com/
Aug 24, 2011 | Porter Cable 2 - 1/2" 15 - Gauge Angle...
We purchased a Porter Cable Staple Gun, Model # DA250B. Unfortunetly, it does not explain how to load the staples into the gun! Could you please help us. Thank you, ...
Porter-Cable/Delta has an excellent support site, where you can find pdf manuals, part numbers, etc.
http://servicenet.deltaportercable.com/
Porter-Cable DA250B is an angled finish nailer- it drives 15 gauge brad nails, and won't work with staples. There are some smaller pneumatic tools that can drive both brads or staples, they are typically the smaller 18 gauge fasteners.
If you have the correct 15 gauge angled nails, the DA250B manual has nice pictures showing how to insert them.
http://servicenet.deltaportercable.com/Products/Detail?productNumber=DA250B
Jul 16, 2011 | Garden
What is the angle of the 15 gauge nails for this gun and what nails are compatable
You did not mention the brand or model of your gun, however, you can determine the angle needed by placing a straight edge in line with the path of the driver and measure the angle from this edge to rails.. If the straight edge to the rails measure 90 degrees or makes a right angle, you need "0 degree" nails, if it measures 80 degrees, you need "15 degree" etc. Most generic nials 15 gauge nails will work. No need to by branded nails unless your gun requires an unusual angle. Good luck.
Jul 31, 2010 | Porter Cable 18 - Gauge Brad Nailer and...
Need owners manual for Porter Cable FN250C 16 Ga. nailer
Here's a link for PDF file download of your manual.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Porter-Cable/N027636,DA250C.pdf
Apr 15, 2010 | Porter Cable 16 - Gauge Finish Brad Nailer...
Driver blade won't retract to shoot the next nail
Sounds like you have something caught in the guide causing it to jam a lil.
These guns are allmost disposable and have a short life span.
Mar 31, 2010 | Porter Cable 2 - 1/2" 15 - Gauge Angle...
My gun is leaking air ... a have 2 finish nailers and are leaking air , please can u tell me where can send those to fix?? i'm in north south carolina my sip code is 29536
The closest loction to you is in Charlotte:
DELTA | PORTER-CABLE/DEWALT FACTORY SERVICE #042
3557-B WILKINSON BOULEVARD
CHARLOTTE, NC 28208
US
704-392-0245
Oct 01, 2009 | Porter Cable 2 - 1/2" 15 - Gauge Angle...
Finger trigger has come apart. Diagram needed to reassemble.
go to this site .and you will be able to get a break down . http://www.toolpartsdirect.com/portercable/portercable-4.html
Apr 11, 2009 | Porter Cable-Cable FN250C 1-inch...
Porter/Cable 15 gauge angle finish nailer
The driver assembly can sometimes get bent or the tip can get a little deformed causing it to hang up in the nose. Other than that, not much else it could be if you rebuilt the whole thing
Dec 31, 2008 | Porter Cable 16 - Gauge Finish Brad Nailer...
Air Tools & Compressors Logo
537 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
