Question about Nikon D40x Digital Camera
Nikon d40x Hi my nikon is acting very weird ... my flash is going off but every second or third picture is either over exposed or under exposed very dark .. is my flash about to die ?? My camera is a year and a couple weeks old so Im not even sure if I have warenty. Does any know how much something like this will cost? and how long it takes to get repaired?
  • dmargo864 Jan 18, 2009
    Nikon DSLR's last for about a year. You are not doing anything wrong. The cameras are not made to last much longer. They are basically an $800 disposable camera, otherwise Nikon would be doing the honorable thing which is to replace the bad cameras. I am stuck with a D40X that cannot take a picture in Auto mode, the same thing happens. Once in a while the flash fires but so bright the entire image is white.
  • egp07 Feb 04, 2009
    I have the same problem with my d40x too! When a take a pic on auto and it flashes my image turns almost completely white :( does that mean i have to get it fixed at the shop?
  • 88 Answers
It sounds like your flash capacitor isn't fully charged up and your taking a photo and there isn't enough power charged up, so your photos turn out too dark. Take a photo, wait for a minute or til you see the flash icon inside the viewfinder lit up and then try taking another photo.
Posted on Jan 08, 2009
Why my flash of Nikon D40 doesnt work?
hi did you impact your camera some where?...that is most of. or natural defective. There will be three cause. first is built in flash charging switch out of place. second is flash circuit defective. third is shutter unit sync defective. you local repair shop would charge you around $65 to 195 depend on what really they want to charge. Good luck with you!
May 21, 2011 | Nikon D40x Digital Camera
I have a nikon d40 that works great ewxcept for one day i was taking pictures and all of a sudden the camera would not take a picture in auto or manual and theres a warning sign flashing "r11" where the...
Slow down your shooting. The "R11" indicates that you can take 11 more images before the buffer is full and the camera will stop functioning until the images are moved to the memory card.
Select a smaller file size. Nikon cameras allow you to select from several sizes of JPEG as well as a RAW and a RAW + JPEG file. These files vary in size. If you select a smaller file size, the buffer will take longer to fill, allowing you to shoot longerTurn off long exposure noise reduction. This function causes the camera to expose twice for every image, and this can fill up the buffer quickly as those images are processed and written to the card.
  • Step 3 Select a smaller file size. Nikon cameras allow you to select from several sizes of JPEG as well as a RAW and a RAW + JPEG file. These files vary in size. If you select a smaller file size, the buffer will take longer to fill, allowing you to shoot longer.
  • Step 4 Turn off long exposure noise reduction. This function causes the camera to expose twice for every image, and this can fill up the buffer quickly as those images are processed and written to the card.
  • Read more: How to Fix the R11 Error on a Nikon D40x Digital Camera | eHow.com http://www.ehow.com/how_6327343_fix-nikon-d40x-digital-camera.html#ixzz0wC3WxqrT
    Aug 10, 2010 | Nikon D40x Digital Camera
    My D40x pictures are all under exposed even in auto mode can someone help me in this should i need to buy additional flash for it
    Hi there if in auto mode youe camera gives you under exposer its mean the camera sensor not working properly. May be its damaged. I suggest you before buying the new flash just check your camera from service center. Thanks.
    Apr 05, 2010 | Nikon D40x Digital Camera
    Hi there, my Nikon D40x flash suddenly stopped working (popping up but not flashing) after I was fooling around with the manual settings, now no matter what I do the "no flash" icon appears beside the...
    Try turning camera on,
    Then press both Green buttons for a count of 10. This should restore factory reset.
    Some models also have a reset button under a connector flap, or go into your menu. Under Custom Setting Menu, choose Menu Reset.
    One of these methods should work.
    Sep 22, 2009 | Nikon D40x Digital Camera
    Can't take pictures in low light/no flash with my Nikon D40X
    First of all you need a tripod to cut down on the movement . Next use the mode dail and select a nigt setting .
    You can even use a shutter speed in Aperature Prioity .Ypu might want to use exposure comp .
    This should work for you.
    Apr 07, 2009 | Nikon D40x Digital Camera
    Nikon D40X built in flash doesn't pop up automatically
    This is a common fault with the D40x. You will need to contact Nikon for repair details.
    Mar 31, 2009 | Nikon D40x Digital Camera
    The Flash on my Nikon D40X will not operate
    Sounds like flash board is bad, Needs to fix by a repair shop.TC
    Dec 09, 2008 | Nikon D40x Digital Camera
    LCD Screen
    to turn this setting off just press the down arrow button when reviewing your photos. you will scroll through a number of ways to view tho photo including histogram, and one of the settings is just the picture.
    Mar 05, 2008 | Nikon D40x Digital Camera
    D40X flash problems
    As the manual warns, never operate the camera (or any device, in general) if you notice something like that. Remove the battery, and send your camera for service
    One can only guess what was the source of the problem. Did you drop the camera, expose it to high temperatures (e.g. left it inside a car in 40 degrees Celsius) or expose it to torrential rain?
    In any case, how long it will take to repair it (or, more likely, replace it) depends on your local Nikon service department.
    Dec 08, 2007 | Nikon D40x Digital Camera
    Nikon D40X inbuilt flash
    If it's withing 30 days, get it exchanged. I have a D70s and it's been working fine for me, maybe something with the D40x with other customers? Take it back to the store and let an "instructor" try it out to make sure it's not a setting.
    It's great for the manufacturer to know about any problems so they can get a good sample of problems to help many people. Good luck.
    Nov 16, 2007 | Nikon D40x Digital Camera
    Nikon D40x Digital Camera Logo
    124 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Jeff Marcus
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
