Question about Indesit WA 115 Front Load Washer
Indesit Hi we have a indesit WIL163s when we turn it on the door lock light and 2 other LEDs start to flash, we have tried switching it on and off at the wall but to no avail, if it helps we did have a trip on our elec today but at the time the washer was not in use, any help would be great. Many thanks
  • 2 more comments
  • nicole van May 10, 2007
    Thank you for your help.
  • windypops Jan 25, 2008
    yes, we have the same problem and would appreciate some informtaion on a resolve. model number: indesit widl 126 uk
    Any assistance would be great.
    Thanks
    windypops.
  • Anonymous Mar 16, 2014
    I have an Indesit wil163 and once machine filled , door closed, it is programmed and the start button is pressed, the door then locks and then nothing happens.
    Help please.
    Help please.
    President:
  • 1,294 Answers
Click above (ie. below the Fixya symobol, on yr model No. You will come to Troubleshooting & Support. There is a posting by "again". First 5 postings?
Posted on May 08, 2007
  • prem mathew Jun 05, 2008
    Try some WD40 on the mechanism of the lock, not on door. And open & close a few times, while disconnected from the mains.
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
Indesit model iwe7125b problem f06 what does it means?
F06 : DOOR LOCK fails to close/open, door lock triac open/closed, frequency signal fault.
Action: Switch off the device. Disconnect power. Wait about 3 minutes. Open the door, then close, reconnect device to the network. Start device
Dado
Dec 20, 2014 | Indesit Washing Machines
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
Indesit WIA121 Flashing Door Lock, Prewash and Spin Lights - Machine not draining
hi something similar has started happening to our washer, after the initial wash starts the machine doesn't do anything for a while then the red door light flashes on and off very quickly as does the 1st and 3rd green wash cycle light?
Jul 04, 2012 | Washing Machines
Iwde12 indesit, not selecting programmes not releasing water, not drying
Hi, I have an indesit IWDE12, I programme the washer which then starts to spin with no water, after 2-3 mins the rinse light, the clock light and the door lock light start to flash and tha washing stops. Does anyone know what this problem could be?
Jun 15, 2010 | Indesit W 123 Front Load Washer
Lights flashing on indesit WIL123S
Hi, sounds like you need to change the door interlock located where the door catch pushes into.
Take the top off and undo the two screws with a tork screwdriver
and replace.
(Remember to turn off the supply and pull out the plug top)
May 09, 2009 | Indesit W 123 Front Load Washer
Door lock led flashing plus 2 other leds
This is an error code, to know what the error is, you need to provide more information. Make and model of the unit and which lights are flashing.
Sgt 48
Jun 06, 2008 | Indesit Washing Machines
Indesit widl 126 uk
Turn the control knob to a black dot leave the door open and press the on off button in and out quickly and look for a change in the lilght,, it should blink 3 times rapidly once it does ,, then the machine is reset and ready to use,,,
if you have any problems let me know im here for another hour..
Jan 25, 2008 | Indesit WA 115 Front Load Washer
INDESIT WIA 101
Press "end of cycle" for 3 seconds, & tell me what happened.
You will rate me also.
Jan 19, 2008 | Indesit WA 115 Front Load Washer
Indesit WIL143S flashing lights
sounds like your power board is damaged. Did you get any washes out of it before it went wrong
Oct 08, 2007 | Washing Machines
Indesit WA 115 Front Load Washer Logo
724 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
