Question about Garden
Strimmer Starter strip
My strimmer starter cord will not rewind. To avoid manually rewinding it, how do I strip the starter to check for and replace any broken part and, if necessary, lubricate it, please?
  • 50 Answers
You will need to take the housing off to expose the rewind mechanism. The most likely cause will be a broken rewind spring. Go on the WEB and search for your model and a part list. Locate the spring and order it. Once you install the spring, you will need to pre-tension the spring by by pulling the cord part way out and ciol it on the spool. Good luck
Posted on Jan 03, 2009
The pull cord on my Roybi rtl30ces will not retract. How do I access to repair?
Hi Kathy - more likely than not there's a little "tab" on the end of the spring that slips it to a tab in the plastic to maintain spring tension.
These break off fairly regularly and you can easily bend the spring steel to a 90 degree to "fix it" and place it back in the tab.
I've included a teardown / rebuild video that should be very helpful when repairing your weedeater - it's a "generic" ryobi video but they're all really, really similar.
Don't be intimidated - they're super easy to work on! How to Fix the Starter on Ryobi Trimmer
Sep 03, 2016 | Ryobi Garden
How do I change champion strimmer cord
this is the pdf user manual for it
Champion Strimmer Manual - Strimmer Manual - homelite: operator's manual 25cc string trimmers - owneriq - read your operator?¢?€?™s manual your manual ...
Jul 17, 2016 | Garden
Champion strimmer 25 cc cord
its a pdf
Champion Strimmer Manual - operator's manual 25cc string trimmers - owneriq - read your operator?¢?€?™s ... kimmel manual kawasaki petrol strimmer tg24 manual ' champion ...
The line has come out of my strimmer. When I rewind it, it doesn't click into place.
look for GRASS in the way .or even some wacker cord sticking out too far
May 04, 2015 | Garden
How do I replace a pull cord for pm 605 mcculloch chainsaw?
First remove the pull starter housing.
The next part is tricky. You'll have to release and unwind the spring that rewinds the pull starter cord. Remember how you do this because after replacing the cord, you'll have to rewind the cord and spring before inserting it back in the housing.
re-attach the pull cord housing to the chain saw.
Hope this helps.
Oct 19, 2014 | McCulloch Pro Mac 605 610 645 650 655...
The starter cord jammed on recoiling, after attempting got release it the recoil spring rewound, now the cord and spring are interlocked. I'm looking to strip the recoil mechanism but I believe I
Its an easy opperation to undertake if you know how. Take note of where everything goes during the stripping down of the recoil assembly. Use eye protection when trying to recoil the rewind spring, they have a tendency to jump back out at you while coiling them back in. easiest way is to start by putting the hooked end into the plastic housing and work your way inwards coiling it back in. Then place the starter cord roller in on top, adding the one or two black sliders, the washer and the spring clip to hold it all in place.
Feb 16, 2013 | Stihl Trimmer Oe Rewind Starter Spring 36...
Starter cord has jammed
You will have to remove the starter rewind mechanism and rewind the cord around the pulley, then pre- load a certain amount of tension on the rewind spring.
Apr 17, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
Starter cord won't rewind
The starter cord is spring loaded. When the spring breaks your cord won't rewind. Usually the whole starter cord assembly is easily replaced and readily available at your local gardening goods retailer. They might even install it for you for a nominal fee. I hope you find this solution helpful. Please rate it and thanks for using Fixya.
Nov 05, 2009 | Sewing Machines
I need a manual for aoleo mac 730s strimmer
Petrol oil mix 25:1 or 50:1 oleo macs own
Starting lock trottle half way (put On/off to start position and depress lever ) prime bulb x 5 choke back fully and pull chord till starts
plug rcj-7y
Apr 03, 2009 | Garden
Garden Logo
272 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
