Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Need guide to use th6000 honeywell thermostat
Where can i get a guide to use new thermostar
  • 75 Answers
Right here. (http://customer.honeywell.com/techlit/pdf/69-0000s/69-2026.pdf)
Posted on Jan 01, 2009
My upstairs temperature is 80 degrees and the downstairs is 69 Honeywell focus pro th6000 is set at 69. Why is the upstairs so drastically hot?unit is located upstairs& thermostat is downstairs
if there is no control of air movement between floors and you have it on cooling then any cold air will go down to the lower floor
or alternately if you have it set on heating all the hot air will rise to the upper floor
where is the system located (upstairs or down stairs ) and where is the thermostat located
to get control close any upstairs to down stairs doors or erect a heavy curtain across the stair well
Dec 17, 2016 | Honeywell Heating & Cooling
Th6000 - how do I change from celsius to fahrenheit display?
Here is the Installer Manual. Follow the Set-up menu instructions found on pages 6 & 7. Setup Function #14 needs to be changed from "1" to "0".
Please offer Fixya feedback.
I hope you find this information to be very helpful to you moving forward. :-)
Apr 29, 2010 | Honeywell Programmable Thermostat Heater
Honeywell th6000 thermostat installed. It shows only heat-or off- no cool. The fan doesn't show up as auto or on. Now air conditioner has turned on and it is -15
If you just installed the stat, you need to enter installers programing to set it up. To do thi, press and hold "UP" and "FAN" until a number on the left and right show up. The left number is the function and the right number is the setting. You do not specify what type of system you have, so i cannot tell you exactly what settings. But here is a link to the installers manual. the installers program settings is about half way down. http://www.forwardthinking.honeywell.com/related_links/thermostats/focuspro_6000/install/69_1920es.pdf
Feb 06, 2010 | Honeywell Programmable Thermostat Heater
I have a honeywell t stat th6000 for htg only having problem get my gas valve to go onfurnace is working but no heat
As long as this is a 24 volt thermostat, remove the thermostat from the sub base and connect the wires that are connected to terminals R & W. If the furnace works the problem is in the thermostat. Have you tried new batteries
Oct 29, 2009 | Honeywell Electronic Programmable...
Honeywell TH6000 series thermostat does not turn Fan on.
It's one of two issues; either the wiring to the thermostat is incorrect, or possibly you have an open ground. Depending on your system the wires at the thermostat end might have to pair up on one lead. go to where your unit is and look at the schematic for the control board, it will let you know what color you are looking for on the blower lead -- then make sure the corresponding color matches at the thermostat. Knowing the make and model of you unit and the board on it would allow me to be more specific, hope this helps you out some in the meantime.
Jun 17, 2009 | Honeywell Focus 6300B 5-2 Days...
Need a "trouble shooting" guide for FocusPRO TH6000
i have the heat set at 73 the temp in the house is getting colder it is at 67 now and it won't come on . why?
Jun 12, 2009 | Honeywell Electronic Programmable...
Wiring Honeywell TrueIAQ w/ a non-powered Honeywell humidifier
the soliniod requires 24v to open so if you dont have the power then its not wire properly. Are you using a current sensing relay to allow the humidifier to only come on whe the fan is operatin? if you do have 24v on solinoid and its not opening then you got a bad solinoid. sometimes the humidistat will be a universal, for a power humidifier . A bypass requires external power and the humidistat will need to be switched to BYPASS to regonize this
Apr 14, 2009 | Humidifiers
Thermostat auto-changeover mode unavailable
when you programed it did you go through all the setup #1-0 ,#3-0 ,#5-5 ,#12-1
Nov 24, 2008 | Honeywell Electronic Programmable...
User instruction guide
Don't think it's a Honeywell product
http://www.gotoplumbing.com/uploads/Ethos-3654c.pdf
Jan 07, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
461 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
