Question about Brother LS-2125 Mechanical Sewing Machine
I have a White 3300 embroidery machine. The thread just started bunching up on the underside of the fabric. It got stuck in the plate opening where the needle goes into. I removed the plate to get the thread dislodged. Now the top thread will not catch the bobbin thread. Any suggestions?
I think you need to change your needle if it got damaged when it jammed it cant pick up the thread
Posted on Jan 09, 2009
Singer Q7469 confidence sewing machine
Hey Shari,
When you say, "thread bunches up" does that happen under the needle plate? Or on top of the fabric at the needle? This can be several things like, installing the correct needle for that machine and proper threading.
I might be able to help more if I had more information like make and model machine you are using, and a response to the question above.
Cheers,
Embroidery Services
San Diego, CA
Jul 28, 2016 | Singer Sewing Machines
Having trouble with tension on my Husqvarna Viking E 20
Be sure to RAISE the presser foot BEFORE threading the upper thread. (Remove the upper thread and rethread from the beginning.) Upper thread malfunctions commonly occur if it is not threaded correctly or the thread is not seated in the tension disk properly.
Install a brand new needle if you haven't already done so.
If it continues, this information about bird nesting could be helpful:
Sewing Machine Thread Bunching Up Here Why
Why Do Get Bunched Up Thread Under My Fabric
8 Tips to Fix Birdnesting in Embroidery
Why Is the Thread Getting Tangled Up Under My Material When Use My Sewing...
Jan 22, 2016 | Husqvarna Sewing Machines
Fixing my white 3300 embroidery machine
First change that needle, it's probably bent. Then double check the bobbin/shuttle area for threads wrapped around moving parts.
Oct 24, 2012 | White Sewing W3300 Computerized Sewing...
I have a WHITE 3300 EMBROIDERY MACHINE and the thread bunches up at the bobbin site. I have tried a new needle, adjusted upper thread tension , changed bobbin threads and nothing helps, it keeps bunching...
Refer to your machine for cleaning the bobbin area.
You will need to clean this area often as lint and thread snips can build up can cause the bobbin feed to malfunction.
If this continues after you have cleaned the machine, the timing may need to be adjusted by a sewing machine tech.
Mar 18, 2010 | White Sewing W3300 Computerized Sewing...
Top thread won't catch the bobbin thread
First check the upper and lower tension adjustments according to link below and then check the knob (bobbin case) that makes the bobbin tension which lies inside the shuttle if it is too loose. Restricted it with the sheet metals around it so that it shouldn't move so freely up and down or back and forward. Be careful it should move freely a little but not too much.
http://www.wikihow.com/Adjust-the-Tension-on-a-Sewing-Machine
@ytac...
Feb 24, 2010 | White Sewing W3300 Computerized Sewing...
Bobbin thread tangling up
are you doing embroidery? if so turn off jump stitch cutting if possible. is the machine threaded correctly (pull needle thread out of machine and thread again with presser foot raised.
check for foreign matter in needle tension assembly. ensure there is sufficient needle thread tension.
the thread you see caught up underneath the fabric will be needle thread and indicates insufficient needle thread tension or something preventing the needle thread from being pulled up into the fabric (maybe a damaged bobbin case, or bobbin case position finger, or damaged needle plate hole).
goodluck,
scott
Jul 27, 2009 | Baby Lock Ellure
Thread from bobin doesn`t leave smooth sewing on bottom of fabric
hi make sure pressure foot is raised before you start to thread machine ortherwise thread will not slide between tension discs this will cause bunching underside of fabric ...good idea to replace needle good luck
mary h
Jan 05, 2009 | Husqvarna Viking 1
I have a White 3300 embroidery machine not catching bobbin thread
Try putting a new sewing machine needle in and make sure the eye of the needle is facing the right way. Needles look like they should go just anyway, but if they aren't in right, it could cause the problem you are having.
Jan 01, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother Embroidery machine thread keeps breaking
the needle thread tension is wrong
bunching up under the material indicates that it is too loose
Nov 17, 2017 | Sewing Machines
Singer CE-100 Embroidery thread bunches up underneath fabric
I had this problem and it all came down to using the wrong backing. I kep trying to use tearaway on everything but WRONG. Using the proper backing corrects most problems. Good Luck!
Oct 30, 2007 | Singer CE-100 Futura Computerized Sewing...
Brother LS-2125 Mechanical Sewing Machine Logo
210 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
