Question about Uniden DECT 2080-5 Quint Phone
Four way function key not working on Uniden DECT 2080 handsets
I have a Uniden 2080 system with 6 handsets. It came with four handsets and we added 2 more about 6 months ago. Over time the four way function keys on all of the old handsets have stopped working. Is there any way to fix this or use other keys to scroll?
  • Anonymous Jan 08, 2009
    Have the same problem, and the buttons on both handsets stopped workin at around the same time.
5 Suggested Answers
SOURCE: On 2 of the 4 handsets on my Uniden DECT 2080, the
After having the same trouble with my DCX200 and not finding a solution online for the problem, I set out to find a solution of my own. The fix I describe below is probably more of a band-aid than permanent fix but it appears to be working great. The problem, I believe, is caused by the metallic compound that the manufacturer used on the push button contacts in this model of phones and more specifically with the large multi-function button. This compound appears to wear off quite easily with repeated use of the keypad. Along with this I think that the design of the multi-function button did not take into consideration the environment in which it would be used. Not everyone washes their hands and face before using a phone (does anyone?) and between grease, make-up and natural oils of the skin building up and eventually making their way down into the components, this may be a contributor to why these buttons are so susceptible to failure.
_889.jpg What you will need:
1) Small Phillips head screw driver.
2) Small flat head screw driver (not shown).
3) Goo-Gone, Isopropyl Alcohol or some other degreaser/cleaner.
4) Hole punch, preferably smaller than a "standard" hole punch. I found the one I used in my wife's craft supplies.
5) Cotton swabs.
6) Metallic or foil tape. Can be found at any home improvement or hardware store.
Step 1. Remove battery and two screws circled in red with your small Phillips head screw driver.
Step 2. Pry off the dark grey back of the phone case with your flat head screw driver. I found that starting at the base of the phone and working around the sides was easiest.
Step 3. Being mindful the the wires that attach to speaker take the dark grey back off of the phone. Next remove the screw circled in red below:
Removing this screw will allow you to remove the circuit board from the front face of the phone to expose the numeric keypad as shown below. There is a thin white plastic keypad component that will either remain affixed to the keypad or the circuit board when you remove the circuit board from the front face of the phone. Be sure not to damage that.
Take the white plastic sheet and affix it to the circuit board side (if not already on it), with the small black button contact points facing down onto the circuit board as shown below:
Now soak one side of your cotton swab in your Goo-Gone or Alcohol solution and clean both the four small black push button contacts of the large multi-function button on the back side of the keypad and also the contact points on the circuit board. Then take the dry side of the cotton swab and remove any excess cleaner on the button contacts and the contact points. This step is critical. This cleans the surfaces and makes the push button contacts on the back side of the keypad ready to receive the foil tape.
Pictured below is the cleaning of the push button contacts of the multi-function button on the back side of the keypad:
Also clean the contact points on the circuit board using the white plastic sheet as a guide to where to clean. Don't forget to use the dry side of the swab to remove any excess cleaner:
Now the part that requires of bit of dexterity. Using your hole punch punch out four pieces of the foil tape. If you do not have a hole punch or are using a "standard" sized hole punch, you will want to try and use a scissors to cut out a small piece of foil tape that will fit over the black push button contacts of the multi-function key on the back side of the keypad:
Harvest the small circles of foil tape that the hole punch punched out of the foil tape.
You can see a couple of them on my finger below:
Now using your finger nail, gently remove the foil tape backing on these small circles. Yes, this can be a bit tricky, but I found it to be easier than I expected. With the backing off of the foil tape, affix your small foil circle onto the push button contacts of the multi-function button on backside of the keypad as shown below. Do not affix these to the circuit board contacts:
Do this for all four contacts of the multi-function button on the keypad. The picture below shows the finished repair to the push button contacts. I also placed the white plastic film component onto the keypad side to underscore the fact that you place the foil onto the keypad and NOT the circuit board:
Now place the circuit board back onto the front side of the phone (silver side) and fasten down with the screw you took out in step 3 above.
Affix the dark grey back of the phone onto the front side. There is a small plastic tongue at the top of the dark grey back that fits into a groove on the top of the front silver side of the phone. Get that tongue into place first then the rest of the back will snap into place.
After the back has been snapped back onto the front of the phone, fasten it down with the two screws you took out in step 1 in the battery compartment.
Put the battery back in, wait for the phone to turn on and try the keypad out. Below, you can see that I am checking the caller ID side of the mult-function button:
This fix appears to work quite well. I don't know how long the repair will last but it would be easy enough to do again if needed.
Posted on Mar 06, 2011
  • 22 Answers
SOURCE: will not register
Hold the power key & the * together for 5-10 seconds. De-register handset/base. Off ya go
Posted on Jul 03, 2009
  • 38 Answers
SOURCE: I have a Uniden DECT 6.0 phone set. I damaged one
On the base, open the menu and select Register Handset. The display should say Handset Registering.
On the handset you want to register, press and hold # until the handset display says Handset Registering (about 2 seconds).
1.
2.
DSL filterTelephone cordTelephone wall jack
45
In about 30 seconds, the handset display should say Registration Complete. Press Talk/fl ash and make sure you get a dial tone.
If...
Try...
you don't hear a dial tone
the display says Registration Failed --
Making sure the handset is fully charged, then start over at step 1.
Posted on Sep 08, 2009
SOURCE: uniden 2080
I have same problem
Posted on Nov 19, 2009
How do i take silent mode off an uniden dect 6.o cordless phone
Hold the "Silent Button" down for a while. It is shared with the # key.
Mar 07, 2012 | Uniden DECT 2080-5 Quint Phone
I have lost my manual and i dont know how to record a personal message on my answering machine and how to enter the code to retrieve my messages from another phone.
From your handset, you just have to press the mute button, your phone should start telling you the time, date, ect. press the #5 key and then the #8 key and start recording your message. When finished press the # 8 key again. Hope this helps
Mar 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
Uniden 2080
I have same problem
Nov 16, 2009 | Lands Phones
Will not register
Jul 03, 2009 | Uniden DECT 6.0 Cordless Telephone...
Need for DSL filters with DECT 6.0?
Yes - you need the DSL filter in jack you plan to use (you need them in any jack with a phone/fax connection. It matters not that the handset is cordless - the connection to the wall needs the filter or your DSL will a) not work or b) work poorly
Aug 26, 2008 | Uniden DECT 6.0 Cordless Telephone...
Uniden DECT 6.0 2080-2 rings for no reason
These DECT 6.0 phones work on 1.9 Ghz frequency and should not have any interference other than from another DECT 6.0 phone that can be within 150 ft of your phone. That means that somebody, a neighbor that has a DECT 6.0 phone close by is causing this problem. It also means that they are also getting these phantom phone rings. The best solution? Go to a 5.8 Ghz phone and your problem should go away.
Mar 13, 2008 | Panasonic KX-TGA101S Cordless Handset
Uniden DECT 2080-5 Quint Phone Logo
600 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
